Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 26 to 50 of 66
Thread: malloc/free for EXTMEM and DTCM
  1. #26
    1,210
    From top, this is the first commit which doesn't work
    Commit: 7a458043ea6642c861425095526b24f567385b03 [7a45804]
    Parents: 4da51c16fd
    Author: PaulStoffregen <paul@pjrc.com>
    Date: Sonntag, 25. Oktober 2020 17:49:34
    Committer: PaulStoffregen
    Add experimental interface
    Think maybe the Oct 23rd or 24th commit was 1.54b2 just looking at the how long ago the commits were made?
    Fits to this information
  2. #27
    23,027
    Ok... I'm getting out my Windows laptop to investigate....
  3. #28
    7,901
    I can confirm I see the same thing after sync.
    I updated my install to use the cores
    C:\arduino-1.8.13\hardware\teensy\avr\cores>ren teensy4 teensy4_release
    C:\arduino-1.8.13\hardware\teensy\avr\cores>mklink /D teensy4 d:\GitHub\cores\teensy4
    symbolic link created for teensy4 <<===>> d:\GitHub\cores\teensy4
    And simple program did not print anything:
    xtern "C" uint8_t external_psram_size;
    void setup () {
      while (!Serial && millis() < 4000) ;
      Serial.begin(115300);
      Serial.println(F_BUS_ACTUAL, DEC);
      Serial.printf("PSRAM: %d\n", external_psram_size);
    Then I exited Arduino, restored back to using the released version of core:
    C:\arduino-1.8.13\hardware\teensy\avr\cores>ren teensy4 teensy4_github
    C:\arduino-1.8.13\hardware\teensy\avr\cores>ren teensy4_release teensy4
    And it is printing...
  4. #29
    1,210
    if I undo your changes from 'Add experimental interface' in usb_desc.h:
    I.e.,
    #define NUM_INTERFACE		2   // back to 2 instead of 3
    //#define EXPERIMENTAL_INTERFACE 2  // commented
    it works again.
  5. #30
    7,901
    I am now doing a comparison of the two directories
    It sees these files are different:
  6. #31
    23,027
    Testing now with Windows 7. I see it here too.
  7. #32
    5,893
    I.e.,
    it works again.
    Confirmed. Working again
  8. #33
    5,893
    With that said just tried Triple_Serial_test and only seeing 1 Serial port in Windows 10 with T4.1 and t4.0
  9. #34
    23,027
    Ugh, looks like several minor descriptor problems have crept in. And my little experiment a few days ago wasn't such a good idea. Here's a fix.
    https://github.com/PaulStoffregen/co...7e2321d27c6b2e
    With this, I'm seeing all 3 serial ports appear on Windows 7. Will need to re-image this machine to test Windows 10....
  10. #35
    5,893
    Just updated the core on a Win 10 x64 confirmed all 3 ports seen and printxx working
  11. #36
    7,901
    It is working now on T4.1 For simple Serial.
    I also tried out my USBToSerialMulti sketch - Wonder if we should add something like this to examples:
    Serial -> Serial1
    SerialUSB1 -> Serial2
    SerialUSB2 -> Serial3
    Or which ever serial ports you define... And it appears to be working:
    /* USB to Serial - Teensy becomes a USB to Serial converter
       http://dorkbotpdx.org/blog/paul/teensy_as_benito_at_57600_baud
       You must select Serial from the "Tools > USB Type" menu
    // set this to the hardware serial port you wish to use
    #define HWSERIAL Serial1
    #define HWSERIAL1 Serial2
    #define HWSERIAL2 Serial3
    unsigned long baud[3] = {19200, 19200, 19200};
    unsigned char prev_dtr[3] = {0, 0, 0};
    const int reset_pin[3] = {4, 3, 4};
    const int led_pin = 13;  // 13 = Teensy 3.X & LC
    // 11 = Teensy 2.0
    //  6 = Teensy++ 2.0
      pinMode(led_pin, OUTPUT);
      digitalWrite(led_pin, LOW);
      digitalWrite(reset_pin[0], HIGH);
      pinMode(reset_pin[0], OUTPUT);
      Serial.begin(baud[0]);	// USB, communication to PC or Mac
      HWSERIAL.begin(baud[0]);	// communication to hardware serial
    #if defined(USB_DUAL_SERIAL) || defined(USB_TRIPLE_SERIAL)
      digitalWrite(reset_pin[1], HIGH);
      pinMode(reset_pin[1], OUTPUT);
      SerialUSB1.begin(baud[1]);
      HWSERIAL1.begin(baud[1]);
    #if defined(USB_TRIPLE_SERIAL)
      digitalWrite(reset_pin[2], HIGH);
      pinMode(reset_pin[2], OUTPUT);
      SerialUSB2.begin(baud[2]);
      HWSERIAL2.begin(baud[2]);
    long led_on_time = 0;
    #define BUFFER_SIZE 512
    byte buffer[BUFFER_SIZE];
      // first do the simple stuff.
      processUSBToSerial(0, &Serial, &HWSERIAL, Serial.dtr(), Serial.baud());
      processUSBToSerial(1, &SerialUSB1, &HWSERIAL1, SerialUSB1.dtr(), SerialUSB1.baud());
      processUSBToSerial(2, &SerialUSB2, &HWSERIAL2, SerialUSB2.dtr(), SerialUSB2.baud());
      // if the LED has been left on without more activity, turn it off
      if (millis() - led_on_time > 3) {
    // Process for one USB to Serial connection.
    // Wish USB Serial classes derived from common class other than Stream.
    void processUSBToSerial(uint8_t serial_index, Stream* usbStream, HardwareSerial *hwserial,
                            unsigned char dtr, unsigned long usb_baud)
      int rd, wr, n;
      // check if any data has arrived on the USB virtual serial port
      rd = usbStream->available();
      if (rd > 0) {
        // check if the hardware serial port is ready to transmit
        wr = hwserial->availableForWrite();
        if (wr > 0) {
          // compute how much data to move, the smallest
          // of rd, wr and the buffer size
          if (rd > wr) rd = wr;
          if (rd > 80) rd = 80;
          // read data from the USB port
          n = usbStream->readBytes((char *)buffer, rd);
          // write it to the hardware serial port
          hwserial->write(buffer, n);
          // turn on the LED to indicate activity
          digitalWrite(led_pin, HIGH);
          led_on_time = millis();
      // check if any data has arrived on the hardware serial port
      rd = hwserial->available();
      if (rd > 0) {
        // check if the USB virtual serial port is ready to transmit
        wr = usbStream->availableForWrite();
        if (wr > 0) {
          // read data from the hardware serial port
          n = hwserial->readBytes((char *)buffer, rd);
          // write it to the USB port
          usbStream->write(buffer, n);
      // check if the USB virtual serial port has raised DTR
      if (dtr && !prev_dtr[serial_index]) {
        digitalWrite(reset_pin[serial_index], LOW);
        delayMicroseconds(250);
        digitalWrite(reset_pin[serial_index], HIGH);
      prev_dtr[serial_index] = dtr;
      // check if the USB virtual serial wants a new baud rate
      if (usb_baud != baud[serial_index]) {
        baud[serial_index] = usb_baud;
        if (usb_baud == 57600) {
          // This ugly hack is necessary for talking
          // to the arduino bootloader, which actually
          // communicates at 58824 baud (+2.1% error).
          // Teensyduino will configure the UART for
          // the closest baud rate, which is 57143
          // baud (-0.8% error).  Serial communication
          // can tolerate about 2.5% error, so the
          // combined error is too large.  Simply
          // setting the baud rate to the same as
          // arduino's actual baud rate works.
          hwserial->begin(58824);
          hwserial->begin(usb_baud);
  12. #37
    23,027
    If you've got the latest core installed, how's extmem_malloc() look?
  13. #38
    5,893
    Since I don't really play with malloc much I copied and example for malloc and converted for extram_malloc:
    #include "Streaming.h"
    #define cout Serial
      while(!Serial)
      int *ptr;
      ptr = (int*) malloc(5*sizeof(int));
      if(!ptr)
        cout << "Memory Allocation Failed"  << endl;
        exit(1);
      cout << "Initializing values..." << endl << endl;
      for (int i=0; i<5; i++)
        ptr[i] = i*2+1;
      cout << "Initialized values" << endl;
        /* ptr[i] and *(ptr+i) can be used interchangeably */
        cout << *(ptr+i) << endl;
      extmem_free(ptr);
    which gives:
    Initialized values
    1
    3
    5
    7
    9
    which matches the examples output that i copied. Tried this as well:
        while(!Serial) ;
      int i,n;
      char * buffer;
      Serial.printf ("How long do you want the string? ");
      i = 100;
      buffer = (char*) extmem_malloc (i+1);
      if (buffer==NULL) exit (1);
      for (n=0; n<i; n++)
        buffer[n]=rand()%26+'a';
      buffer[i]='\0';
      Serial.printf ("Random string: %s\n",buffer);
      extmem_free (buffer);
    Seems like it works (example from C++ reference.
    So now my question is how do you simply get the amount xmem not used?
  14. #39
    7,901
    Currently I find out how much PSRAM is installed with:
    #ifdef ARDUINO_TEENSY41
    extern "C" {
    extern uint8_t external_psram_size;
    and now to retrieve how much was allocated by EXTMEM variables we can do:
    extern unsigned long _extram_start;
    extern unsigned long _extram_end;
    And to find out how much memory is left after that you can do the same calculation that the new heap code does:
    external_psram_size * 0x100000 - ((uint32_t)&_extram_end - (uint32_t)&_extram_start)
    Don't know if there is any way with this pool code to know how much of it was used or not... Like we can do with knowing how large the malloc heap has grown.
  15. #40
    5,893
    @KurtE
    In smalloc.c did notice these functions:
    /* Use these when you use just default smalloc_curr_pool pool */
    vovoid sm_free(void *);
    void *sm_realloc(void *, size_t);
    void *sm_realloc_move(void *, size_t);
    void *sm_calloc(size_t, size_t); /* calls zalloc internally */
    int sm_alloc_valid(const void *p); /* verify pointer without intentional crash */
    size_t sm_szalloc(const void *); /* get size of allocation */
     * get stats: total used, user used, total free, nr. of allocated blocks.
     * any of pointers maybe set to NULL, but at least one must be non NULL.
    int sm_malloc_stats(size_t *, size_t *, size_t *, int *);id *sm_malloc(size_t);
    void *sm_zalloc(size_t); /* guarantee zero memory allocation */
    just not sure how to use them?
  16. #41
    1,210
    Sorry to say, but something is still strange with Serial.
    It works stably with the IDE now. Unfortuantely, TyCommander somehow gets the wrong COM port now. E.g. the IDE reports COM3 which is the same as the device manager reports. If I connect to the teensy with TyCommander it reports (not always) COM4 and of course can't talk to it on that port.
    Winding back to the commit right before the "experimental interface commit" everything works ok and as stably as it always did. Might of course be something on my side. Maybe someone finds time to check with their installation?
    Edit In my setup the old (correct) version always generates COM4 (which works) the new one always COM3 (which only works with the IDE) if that helps.
  17. #42
    5,893
    Just checked for the T4.1 that I am testing with. Both TyCommander and IDE are both showing the same COM port number for the T4.1. Even checked with Triple Serial example.
  18. #43
    23,027
    Good question. I didn't see anything in the smalloc code to query the largest allocation expected to succeed. Unless it has some functionality I missed, getting this capability might involve quite a project to dig into smalloc.
  19. #44
    23,027
    I'm struggling to understand what's wrong here. It kinda sounds like Windows decided to assign COM3 and the port is indeed working as COM3, but TyCommander is still believing it's COM4. Is that right?
    Silly question... have you tried a cold reboot since the change?
  20. #45
    5,893
    There does seem to be some functions in smalloc.c that seem to do it: see post #40
  21. #46
    1,210
    The new version generates this device: USB\VID_16C0&PID_0483&MI_00\7&922067D&0&0000
    The old version generates this device USB\VID_16C0&PID_0483\8077220
    Looks like the standard Serial port is now a interface 0 from a compound device, where as the old version generates the usual stand alone device. Is this intended?
  22. #47
    1,210
    The code in #11 shows how to get stats of the allocated memory.
  23. #48
    1,210
    Dual Serial works here, probably because it always was a compound device.
  24. #49
    1,210
    Sorry didn't see your question. Yes thats right and yes I did a reboot and even deinstalled all old COM ports. I'm quite sure the issue is related to the observation in #46 and 48
  25. #50
    23,027
    Looks like the stats about free space are a little optimistic.
    Here's a quick test which queries the free space, then tries to allocate it all at once. Fails.
    #include "smalloc.h"
      while (!Serial) ;
      Serial.println("EXTMEM Free Space Test");
      extmem_malloc(432);
      Serial.print("Free Space: ");
      size_t total = 0, freespace = 0;
      sm_malloc_stats_pool(&extmem_smalloc_pool, &total, NULL, &freespace, NULL);
      Serial.println(freespace);
      void *p = extmem_malloc(freespace);
      if (p) {
        Serial.println("  able to allocate claimed free space");
        extmem_free(p);
        Serial.println("  can't allocate all the free space");
