Results 1 to 13 of 13
Thread: Teensy 4.0: Sending MIDI through USB
    I want to use a Teensy 4.0 board to send MIDI messages through USB. I'm trying to connect it with LMMS. I have a simple sketch where bytes of data is sent on the press of a button. The code compiles and the sketch uploads to the board without error. LMMS is able to see the board as "Teensy MIDI" when selecting the board as input for a preset. But no sound is generated from the program when I press a button.
    The header pins are already soldered to the board. I'm running the code in the Arduino IDE, with "USB Type" set to "MIDI" in the tools menu and using the correct port.
    I feel like I'm overlooking something. Here is my code:
    #include <Arduino.h>
    #include <Metro.h>
    #include <Bounce.h>
    #include <Encoder.h>
    #define btn0 22
    #define led0 14
    const long DEBOUNCE_DELAY = 5;
    const byte MIDI_LISTEN_CH = 4;
    const byte VELOCITY = 127;
    const byte MIDI_CH = 1;
    byte note[] = {36,37,38,39,40,41};
    Metro buttonPress = Metro(3);
    Bounce btn_0 = Bounce(btn0, DEBOUNCE_DELAY);
      pinMode(btn0, INPUT_PULLUP);
      pinMode(led0, OUTPUT);
      usbMIDI.begin();
      if(buttonPress.check()){
        btn_0.update();
        if(btn_0.fallingEdge()) {
          Serial.println("Button 0 Released");
          digitalWrite(led0, HIGH);
          usbMIDI.sendNoteOn(note[0], VELOCITY, MIDI_CH);
        if(btn_0.risingEdge()) {
          Serial.println("Button 0 Pressed");
          digitalWrite(led0, LOW);
          usbMIDI.sendNoteOff(note[0], VELOCITY, MIDI_CH);
      while (usbMIDI.read()) {} //read and ingnore incoming messages
    I've also referenced these guides and videos numerous times:
    https://www.pjrc.com/teensy/td_midi.html
    https://www.youtube.com/watch?v=E_GdsxTm6aM
    I'm also using MIDI-OX to try and monitor midi inputs. But the console never outputs any messages when I press the button.
    Senior Member oddson's Avatar
    Feb 2013
    Isle in the Salish Sea
    1,378
    I've not used Metro but maybe it's stopping bounce from seeing the tranistions.
    I think you would test timing limit after transitions but bounce is usually sufficient on its own to avoid multiple messages so I'm not sure it's needed at all.
    Is this original code or did you copy it?
    1,492
    I made these changes
    #define btn0 2
    #define led0 LED_BUILTIN
    and your code works on a Teensy2 - I see the MIDI messages with Midi-Ox on my windows PC and also the messages to the Serial monitor.
    It also works if I remove the Metro stuff so it doesn't seem to do anything useful.
    P.S. It also works on T4.0
    Pete
    Quote Originally Posted by oddson View Post
    I've not used Metro but it maybe it's stopping bounce from seeing the tranistions.
    I would thought you would test timing after transitions but bounce is usually sufficient on its own to avoid multiple messages so I'm not sure it's needed at all.
    The code was made in reference to the pjrc Transmit Example. I was using Metro for protothreading. I went and commented out the metro library and everything involving it. LMMS isn't generating sound still, with it gone.
    #define btn0 2
    Pete
    I'm glad to hear that it works. But its odd. My MIDI-OX isn't picking up any messages. Is it possible my anti virus is interfering? I'm using Vipre Anti Virus. This code is a small piece of my project. I guess for this sketch metro isn't needed.
    1,492
    When using MIDI-OX, have you selected Teensy MIDI in Options|MIDI devices. If you don't click on it to highlight it, MIDI-OX will ignore it.
    Pete
    I don't know why this would affect things, but I had my USB cable plugged into a USB hub. When I plugged it directly into my pc, MIDI-OX was able to respond. And LMMS now generates sound
    23,069
    Can you name (and shame) this troublesome USB hub? Or give us a photo, if it's some generic no-name thing without a clear model number?
    If it's still on the market, I might buy one for testing. I'd really like to know what that hub is doing to cause this problem.
    I'm using a 7-Port USB 2.0 Multi Charger Hub + High Speed Adapter ON/OFF Switch Laptop PC US, I bought off eBay.
    https://www.ebay.com/sch/i.html?_fro...PC+US&_sacat=0
    Senior Member ETMoody3's Avatar
    Mar 2014
    New Ulm, Mn
    150
    Yikes. I have two of those *useless* units. They backfeed the host, and behave erratically.
    Device ID 05e3: 0606 Genesys logic
    I can run the usbHost debug on it, or any other useful test or probe etc...
    Mar 2014
    New Ulm, Mn
    150
    fwiw here's what the usbHostt36 debug print has to say with only one of those hubs plugged in
    USB Host Testing
    sizeof Device = 36
    sizeof Pipe = 96
    sizeof Transfer = 64
    power up USBHS PHY
     reset waited 5
    USBHS_ASYNCLISTADDR = 0
    USBHS_PERIODICLISTBASE = 1FFF5000
    periodictable = 1FFF5000
    port change: 10001803
        connect
      begin reset
    port change: 10001805
      port enabled
      end recovery
    new_Device: 12 Mbit/sec
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 00 02 09 00 00 08 E3 05 06 06 02 07 01 02 00 01
        VendorID = 05E3, ProductID = 0606, Version = 0702
        Class/Subclass/Protocol = 9(Hub) / 0 / 0
        Number of Configurations = 1
    enumeration:
    enumeration:
    Manufacturer: ALCOR
    enumeration:
    Product: USB Hub 2.0
    enumeration:
    Config data length = 25
    enumeration:
    Configuration Descriptor:
      09 02 19 00 01 01 00 E0 32
        NumInterfaces = 1
        ConfigurationValue = 1
      09 04 00 00 01 09 00 00 00
        Interface = 0
        Number of endpoints = 1
      07 05 81 03 01 00 FF
        Endpoint = 1 IN
        Type = Interrupt
        Max Size = 1
        Polling Interval = 255
    enumeration:
    USBHub memory usage = 960
    USBHub claim_device this=1FFF3B20
    found possible interface, altsetting=0
    number of interfaces found = 1
    USBHub control callback
    09 29 04 09 00 16 64 00 FF 00 00 00 00 00 00 00
    Hub ports = 4
    power turned on to all ports
    device addr = 1
    new_Pipe
    allocate_interrupt_pipe_bandwidth
     best_bandwidth = 3, at offset = 0, shift= 0
    pipe cap1 = F0010101
    HUB Callback (member)
    status = 10
    getstatus, port = 4
    01 01 01 00
    New Port Status
      status=10101  port=4
      state=0
      Device is present:
      Has Power
    Port Status Cleared, port=4
    timer event (19999 us): Debounce Timer, this = 1FFF3B20, timer = 1FFF3E38
    ports in use bitmask = 10
    getstatus, port = 4
    01 01 00 00
    New Port Status
      status=101  port=4
      state=2
      Device is present:
      Has Power
    getstatus, port = 4
    01 01 00 00
    New Port Status
      status=101  port=4
      state=3
      Device is present:
      Has Power
    timer event (20000 us): Debounce Timer, this = 1FFF3B20, timer = 1FFF3E38
    getstatus, port = 4
    01 01 00 00
    New Port Status
      status=101  port=4
      state=4
      Device is present:
      Has Power
    getstatus, port = 4
    01 01 00 00
    New Port Status
      status=101  port=4
      state=5
      Device is present:
      Has Power
    getstatus, port = 4
    01 01 00 00
    New Port Status
      status=101  port=4
      state=6
      Device is present:
      Has Power
    sending reset
    send_setreset
    unhandled setup, message = 40323
    ports in use bitmask = 0
    status = 10
    getstatus, port = 4
    03 01 10 00
    New Port Status
      status=100103  port=4
      state=7
      Device is present:
      Enabled, speed = 12 Mbit/sec
      Has Power
    unhandled setup, message = 140123
    timer event (25000 us): Hello, I'm resettimer, this = 1FFF3B20, timer = 1FFF3E54
    port_doing_reset = 4
    PORT_RECOVERY
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
    enumeration:
    enumeration:
    Manufacturer: ALCOR
    enumeration:
    enumeration:
    enumeration:
        NumInterfaces = 1
        Interface = 0
        Endpoint = 1 IN
        Type = Interrupt
        Max Size = 1
    enumeration:
    USBHub claim_device this=1FFF3EE0
    Hub ports = 4
    device addr = 2
    new_Pipe
     best_bandwidth = 3, at offset = 1, shift= 0
    pipe cap1 = F0010102
    23,069
    I ordered one of those hubs from the first ebay merchant on the list (iokhouse-19).
