Results 1 to 10 of 10
Thread: PulsePosition not working
    Sep 2020
    7
    Hello!
    I am trying the LoopBack example on Teensy 3.2 and Arduino 1.8.5 OSX. I downloaded the newest version from GitHub but still it won't work. There is nothing popping up in the serial console.
    I want to READ from a RC receiver and with another, easy interrupt based example like this:
    // Define which pin we’re using to accept the signal
    #define RCPIN 1
    // We have to declare as volatile as this will be modified
    // by the interrupt routine, and read outside of it
    volatile uint16_t channel;
    uint16_t channel_start;
    Serial.println("Starting…");
    // Mark the pin as an INPUT
    pinMode(RCPIN, INPUT);
    // Attach an interrupt handler to be called whenever
    // the pin changes from LOW to HIGH or vice versa
    attachInterrupt(RCPIN, RCchannel, CHANGE);
    // Output the channel value
    Serial.print("RC channel:\t");
    Serial.println(channel);
    delay(50);
    void RCchannel() {
    // If the pin is HIGH, start a timer
    if (digitalRead(RCPIN) == HIGH) {
    channel_start = micros();
    // The pin is now LOW so output the difference
    // between when the timer was started and now
    channel = (uint16_t) (micros() – channel_start);
    It works! So no electrical issue. Any idea where to start debugging?
    2,593
    You might try updating to the latest IDE. On my T3.2 I ran PulsePosition lib loopback example with pin 9 jumpered to pin 10. I also added while(!Serial); as the first thing in setup(). Sketch works for me on 1.8.13/1.53
    239 :  600.02  1500.00  759.23  1500.00  1500.00  1234.54
    240 :  600.02  1500.00  759.23  1500.00  1500.00  1234.54
    241 :  600.02  1500.00  759.23  1500.00  1500.00  1234.54
    242 :  600.02  1500.00  759.23  1500.00  1500.00  1234.54
    https://github.com/PaulStoffregen/PulsePosition
    Sep 2020
    7
    Hi!
    I realised that PPM means that several servo channels are somewhat encoded in one wire? My receiver has 3 outputs with a servo channel each.. so I guess it is a different technology? PWM vs. PPM?
    7,872
    In many cases like this, it might help to know more information, like what receiver you are using... Also how you have it hooked up and the like.
    Sep 2020
    7
    Hello!
    Connection:
    GND<-->GND
    CH1 <-> PIN10
    5V <-> 5V
    7,872
    I could be wrong, but I think you will only receive one channel pin pin, with a simple pulse that centers around 1500us
    You can probably get the value using: pulseIn (https://www.arduino.cc/reference/en/...ed-io/pulsein/)
    There are other ways as well, like setting up interrupts, but may not be very accurate.
    As PulsePositionInput allows pin 10, I am pretty sure one could create a version of the library that maybe captures the time of when pin goes high and goes low to return the width...
    Sep 2020
    7
    PulseIn looks sufficient for reading one channel. Is the version that is used for Teensy interrupt based?
    7,872
    Nope, just a hard loop.
    If you look at the sources(pins_teensy.c)
    #if defined(KINETISK)
    uint32_t pulseIn_high(volatile uint8_t *reg, uint32_t timeout)
    	uint32_t timeout_count = timeout * PULSEIN_LOOPS_PER_USEC;
    	uint32_t usec_start, usec_stop;
    	// wait for any previous pulse to end
    	while (*reg) {
    		if (--timeout_count == 0) return 0;
    	// wait for the pulse to start
    	while (!*reg) {
    	usec_start = micros();
    	// wait for the pulse to stop
    	while (*reg) {
    	usec_stop = micros();
    	return usec_stop - usec_start;
    uint32_t pulseIn_low(volatile uint8_t *reg, uint32_t timeout)
    	while (!*reg) {
    	while (*reg) {
    	while (!*reg) {
    // TODO: an inline version should handle the common case where state is const
    uint32_t pulseIn(uint8_t pin, uint8_t state, uint32_t timeout)
    	if (pin >= CORE_NUM_DIGITAL) return 0;
    	if (state) return pulseIn_high(portInputRegister(pin), timeout);
    	return pulseIn_low(portInputRegister(pin), timeout);;
    Sep 2020
    7
    Well OK than maybe even my quick and dirty solution from the internet I posted at the beginning is better.
    7,872
    In the past I often started with a quick and dirty, which at times is sufficient depending on how accurate do you need it.
    Something like: (Note typing in on fly so probably issue)...
    volatile uint32_t last_pulse_width = 0;
    uint32_t pulse_start_time = 0;
    void pulse_width_isr() {
        uint32_t isr_time = micros();
        if (digitalReadFast(10) {
            pulse_start_time = isr_time;
            last_pulse_width = isr_time - pulse_start_time;
        attachInterrupt(10, &pulse_width_isr);
        if (last_pulse_width ...
    This is pretty basic, I grab the micros at start of ISR so both paths should hopefully have about same interrupt delay time.
