Results 1 to 7 of 7
Thread: Teensy 3.5 SerialCom doesn't read
    Oct 2020
    3
    Hi
    I have a Teensy 3.5 and I need its 4 SerialCom Port.
    The problame that I can use RX-TX 1, 2 and 3 but it doesn't communicate throught the 4 and 5 (pin 31-32, 34-33) Ports.
    What could be the problem?
    THX
    12,701
    Those ports have full function when properly wired GND and proper RX<>TX association to a 3.3v UART device - as long as nothing else in software touches those pins beyond Serial4.begin() of Serial5.begin()
    Write a simple sample of some sort crossing Serial 4 or 5 pins to itself or to each other to check function - that was done in Beta to confirm full function.
    Without code or images to see the usage or soldering to help ...
    Perhaps confirm with a pin test on those pins able to switch HI and LOW as outputs and read HI and LOW as inputs.
    23,041
    Quote Originally Posted by questioner View Post
    It could be wires not connected properly. Or it might be a mistake or misunderstanding in the code. Yeah, I know that's pretty obvious and covers all the bases, could be either hardware or software. But really, what kind of an answer can I possibly give?
    I can confirm Serial4 definitely does work on Teensy 3.5. In fact, I retested it just now using a FTDI TTL level USB-serial cable. It it is wired up on my workbench.
    I ran a trivial program which just prints each byte received from Serial4 to the USB port, and vice versa. Here you can see it working when I typed "test" into the serial monitor and "hellow" into the seyon terminal emulator window (for the FTDI cable).
    Oct 2020
    3
    The connections are perfect.
    In code, I tried Serial 1, 2, 3 and these work, so the code is ok but I tested with a simple software and they can't send datas.
    So, if I connect the 31 to 33 and 32 to 34, they don't talk. (It doesn't write out C character.)
    BUT if I connect 0 to 10 and 1 to 9, they CAN talk. (It succesfully write out C character.)
    23,041
    Ah, now we can see a detail you didn't mention earlier. You're using SoftwareSerial. On Teensy 3.5, looks like SoftwareSerial only "knows" the pin numbers for Serial1 to Serial3.
    To use Serial4 and Serial5, you need to use the actual serial names, not SoftwareSerial.
    Oct 2020
    3
    Oh sorry, I didn't believe that it is important.
    I am going to try it.
    Thanks for the fast help.
    EDIT:
    Yes, it's work.
    23,041
    I've updated SoftwareSerial, so future versions of Teensyduino will "know" how to use the Serial4-Serial6 pins on Teensy 3.5 & 3.6, and also Serial8 on Teensy 4.1.
    https://github.com/PaulStoffregen/So...d1f2390e2a7359
    Of course it's always slightly more efficient to just use the hardware serial ports directly. This SoftwareSerial support for use of the underlying hardware serial is mostly meant for projects & library already hard-coded to require SoftwareSerial.
