Results 1 to 4 of 4
Thread: Using a DAC(mcp4821) with teensy that I have tested with an arduino uno.
    Oct 2020
    14
    I am trying to get a dac working with the teensy 4.0 I have. I was successful getting it to work on an arduino uno, but it does not work on the teensy. I noticed in the documentation for spi that SPI.setClockDivider is outdated, so I tried using a bit of their SPI settings code, that in this version is commented out. I was using this tutorial http://www.kerrywong.com/2012/07/25/...p4821-mcp4822/ and everything is wired to the arduino like in that photo, except for the capacitor. When I change out the teensy I wire the pins to the same pin numbers as on the arduino. I was worried it might be the 3.3v instead of the 5v on the arduino but it works on 3.3 volts with the arduino. I'm a little out of my depth with digital communication stuff. Any help you could provide would be very helpful.
    Here is the code I was working with.
    const int PIN_CS = 10;
    const int GAIN_1 = 0x1;
    const int GAIN_2 = 0x0;
    //SPISettings settingsA(2000000, MSBFIRST, SPI_MODE1);
    pinMode(PIN_CS, OUTPUT);
    SPI.begin();
    SPI.setClockDivider(SPI_CLOCK_DIV2);
    //assuming single channel, gain=2
    void setOutput(unsigned int val)
    byte lowByte = val & 0xff;
    byte highByte = ((val >> 8) & 0xff) | 0x10;
    PORTB &= 0xfb;
    SPI.transfer(highByte);
    SPI.transfer(lowByte);
    PORTB |= 0x4;
    void setOutput(byte channel, byte gain, byte shutdown, unsigned int val)
    byte highByte = ((val >> 8) & 0xff) | channel << 7 | gain << 5 | shutdown << 4;
    PORTB &= 0xfb;
    //SPI.beginTransaction(settingsA);
    PORTB |= 0x4;
    //high-res triangular wave
    /*for (int i=0; i < 4096; i+=32)
    //setOutput(0, GAIN_2, 1, i);
    setOutput(i);
    setOutput(2000);
    23,997
    As a quick test, I ran this here on a Teensy 4.0. I don't have that particular DAC, so I just viewed the waveforms with my oscilloscope.
    Amazingly it seems to be working, except that SPI_CLOCK_DIV2 is giving 12 MHz SPI clock speed.
    If you change to SPI_CLOCK_DIV8, you'll get 2 MHz SPI clock (yes, I verified with my scope).
    You might also want to add a delay at the end of loop(). Teensy 4.0 is much faster than those old AVR chips. Without a delay the CS pin stays high for only about 60 ns.
    Oct 2020
    14
    That makes a lot of sense. I have tried your suggestion and am still not having any luck. here is my modified code, which still works for arduino uno, but not for teensy. Thanks a ton for the help. Also if I am going about this in an outdated way, or if you have a suggestion for a better solution I am all ears.
    SPI.begin();
    SPI.setClockDivider(SPI_CLOCK_DIV8);
    PORTB &= 0xfb;
    PORTB |= 0x4;
    PORTB &= 0xfb;
    PORTB |= 0x4;
    setOutput(i);
    setOutput(1000);
    delay(10);
    8,889
    Might help to see pictures of your setup.
    Maybe a wire missing or, soldering issues or...
    Also if it were me I would get away from using PORTB stuff here and instead just do digitalWrite(10, HIGH) or digitalWriteFast(10, HIGH)... and LOW...
