Results 1 to 3 of 3
Thread: SD open issue
    SD open issue
    Can someone tell me why this compiles ok on my 3.2
    myFile = SD.open("filename", FILE_WRITE);
    But this doesn't compile?
    String filename = "asdf.txt";
    myFile = SD.open(filename, FILE_WRITE);
    Caused errors compiling.
    23,015
    The reason why is involves some history of Arduino. It's really just C++ and from the beginning everything used ordinary C strings. Even though the String C++ class was added to Arduino about 10 years ago, the reality is most libraries still only accept C type strings.
    So to give a C++ String to a function which wants a C string, you need this:
    myFile = SD.open(filename.c_str(), FILE_WRITE);
    Never mind. Figured it out. it seems i cannot us a String variable there.
    Thanks Paul!
