I have some issues with a Teensy 4.1 / Windows 7. I can program the device fine and it works as expected but switching between USB drivers (serial, midi, serial+midi) the driver does not always load correctly (and Teensy appears as unknown from device manager, also disabling serial monitor).
The only way I found to (sometimes) solve this issue was to use keyboard+mouse+joystick driver, and back to midi+serial (the driver I want to use).
At this point however, I could never load the serial driver on its own (Teensy always shiw up as unknown device)... when it uses to work fine initially!
This seems all pretty unstable. Is there a way to wipe up all drivers / refresh from start or prevent these bugging issues?
