Results 1 to 6 of 6
Thread: a float = 223.98 prints 223.9799957
    I'm trying to convert a float to char -- long story.
    goals
    float char
    1.2 1.2
    23.007 23.007
    1234.1 1234.1
    but
    float n1 = 223.98;
    Serial.println(n1, 7); // prints 223.9799957
    and
    sprintf(dn, "%f", data);
    Serial.println(dn); // prints 223.979996
    Any thoughts?
      while (!Serial) {}
      float n1 = 223.98; // double isn't any better
      ItBreaks(n1);
    void ItBreaks(float data) {
      char dn[20];
      Serial.print("Converted to a char:");
    May 2015
    USA
    728
    I always get 223.98 when using a double. "%.2f" works even with a float.
    Germany
    1,213
    Are you confused that you don't get 223.98 back or that println and printf give different results?
    In the first case:
    Most floating point numbers can not be stored correctly in float/double variables. Which is clear since there is an infinite number of floating point numbers but you can only store 2^32 different values in 4 bytes. I recommend to have a look here: https://www.h-schmidt.net/FloatConverter/IEEE754.html. If you enter 223.8 in the converter you get 223.9799957275390625 as actual and correct representation of 223.8. So, your statement float n1 = 223.98 actually stores the value 223.9799957275390625 in your n1 variable which corresponds to the output of printf/println.
    In the second case:
    your println statement rounds the stored number to 7 digits and sprintf rounds to 6 digits per default. try %.7f which should round to 7 digits in sprintf and you should get the same results (untested...)
    2,900
    Is that not what one would expect?
    All data are store in binary form, this is also valid for the mantissa. I guess that 223.98 cannot be expressed in binary form (binary exponent and mantissa).
    I understand that the times of a base10 computer were only short
    Feb 2020
    Dublin, Ireland
    48
    Here's one suggestion. This
    int n = 7-ceil(log10(data));
      sprintf(dn, "%.*f",n, data);
    will convert 7 significant figures, which are all that are accurately stored in a float, but will include trailing zeros. You'll have to remove those.
    Thanks to all, i'll try some of the suggestions.
