Results 1 to 3 of 3
Thread: PIN_Dx definitions are causeng errors
    Aug 2020
    17
    Arduino: 1.8.13 (Windows 10), TD: 1.53, Board: "Teensy 4.0, Serial, 600 MHz, Faster, US English"
    In the past I believe I have used Teensy IO pin definitions like PIN_Dx bu now when I try it gives the error:
    'PIN_D2' was not declared in this scope
    I tried reinstalling Arduino 1.8.13 and Teensyduino but those definition still generate errors.
    Is there something I need to include to use these definitions?
    Nov 2015
    Cold hollow VT
    169
    You probably need to do something like
    #define PIN_D2 2
    Aug 2020
    17
    The problem seems to be the PIN_Dx definitions are only valid for older Teensy's. This link shows the ones that are valid for them: https://www.pjrc.com/teensy/td_digital.html
    I tried them on Teensy 3.2 and 4.0 but apparently they are not valid there.
