Results 1 to 2 of 2
Thread: CPU Cycle Counter Formula in AudioStream
    Oct 2015
    Vermont, USA
    265
    I love how the Audio library lets you see what fraction of the processor is being consumed by different blocks in your audio processing chain. But, in looking at the formula, I don't understand how the calculation is done...
    From AudioStream.h, I see this formula:
    #define CYCLE_COUNTER_APPROX_PERCENT(n) (((n) + (F_CPU / 32 / AUDIO_SAMPLE_RATE * AUDIO_BLOCK_SAMPLES / 100)) / (F_CPU / 16 / AUDIO_SAMPLE_RATE * AUDIO_BLOCK_SAMPLES / 100))
    I understand the scaling by the sample rate and block size. The part that I don't understand is the bit in red. Why is there this additive term?
    Chip
    23,030
    Quote Originally Posted by chipaudette View Post
    It rounds to the nearest integer. Or at least it did in the days when AUDIO_SAMPLE_RATE was expressed as an integer.
