Teensy 4.1 RAM issu
yoc1983
New member
I got my first teensy 4.1 for a project that required it and it does weird things.
so i wrote a simple sketch to check the RAM
The sketch is simply writing numbers to an array
then it goes over the array and prints them to the serial
When i am using an array of a size around more then 4000 things get weird
example1: array of 3000 (graph_size=3000)
prints ok to serial every time last value is 2999
example2: array of 10,000 (graph_size=10,000)
doesn't print all the array every time
serial prints for each loop stops randomly at certain numbers:
4621, 4963, 5304, 7011, 7352, 9999
also sometimes it prints some gibberish on the way
would be happy to get some idea what i am missing..
*****this is the sketch:****
const int graph_size=10000;
int graph[graph_size];
for(int i = 0; i < graph_size ; i++)
graph=i;
Serial.println(graph);
delay(2000);
Just noticed you have not braced your loops {} so you are overwriting data
{graph=i;}
{Serial.println(graph);}
It is running and complete before the computer has USB Serial connected to display the prints.
Also the printing is going faster than the PC can make sense of.
  while( !Serial && millis() <4000 ); // wait up to 4 seconds for Serial to connect to PC
    graph[i]=i;
  for(int i = 0; i < graph_size ; i++) {
    Serial.println(graph[i]);
    if ( !(i%40) ) // selective delay to assure PC can keep up
      delay( 1 );
  delay(2000);
CODE block '#' blocking used to show formatting
Code not tested ... but should give proper result
@MikeA > if , for and while execute a single statement - in this case those are single statements, braces are needed to make a single statement when multiple 'lines' / statements are present.
{graph=i;}
wasn't aware of that
you mean it might write data in RAM that in still need?
    graph[i]=i;
      delay( 1 );
  delay(2000);
OK,thanks yes seems like a nice solution
the 4 sec waiting for serial is a must?
i never used it and didn't got problems but maybe in some scenario it can help?
Four second wait allows for a couple things - but that code will leave the while() and continue as soon as Serial is online whether under 1 second or up to 4 seconds - at 4 seconds it leaves even if no Serial has connected.
> PC usually connects to the PC when millis() is about 400 - maybe up to 700 depending on machine when the SerMon is active and waiting.
> But if SerMon wasn't started when the upload completes then 4 seconds allows it to wait for user to click SerMon and for it to connect
Note the Delay(1) is a long time - there is a finer granularity where perhaps delayMicroseconds(100); would be a better starting point and allow it to complete faster.
Teensy is easy to play with printing anything - the only issues are:
> Teensy can connect before the PC connects USB
> Teensy - especially the 4.x - can overwhelm the PC with output faster than it can be processed and displayed on a PC
