Results 1 to 3 of 3
Thread: Programming from the USB host T3.6
    Is it possible to use the host to program? I messed up and made some PCB's based on the idea I could use those. I thought they were a break out but I was wrong. Any chance of salvaging that idea?
    Thanks,
    23,750
    No, sorry, the bootloader only supports programming over the main USB device port.
    Thanks for the quick response. I soldered to the D- D+ pads and just took the 5v out. Seems like thats probably the easiest/quickest fix. 2 wires and 3 cut traces..
