Dynamic allocation of audio objects
idek
New member
(I'm not sure if this forum is the best place to post this, sorry.)
On the Audio Roadmap page, there's this bit of text under "Dynamic Updates & Web Designer Control":
"the audio objects really need to be statically allocated"
Why is this the case? I'd like to allocate them dynamically. Can I do anything to help?
Thanks,
idek
From what I've seen of the codebase (T4 only) it might work to use new and delete, I've not tried myself. I suspect
there's been little testing so some things may work, others not... On the T4 the performance of dynamic memory is
less and I'm not sure what the implications are for DMA, so I'd statically allocate input and output objects anyway.
Others may have some actual experience trying this?!
It also mentions that the constructor is unable to add objects and connections to a live system right now, so it may require extensive code modification.
My current roadblock right now is being unable to find the AudioConnection class in the codebase :$
EDIT: Found it (avr/cores/teensy3/AudioStream.h, avr/cores/teensy4/AudioStream.h)
I've dug around with AudioConnections, and I can see 2 things that could cause issues:
* The connection might not work immediately, only when a new audio block is transmitted by the source. (see: https://github.com/PaulStoffregen/cores/blob/master/teensy4/AudioStream.cpp#L150)
* When the AudioConnection is connected (initialized), it disables IRQ while it adds the connection to the source and destination streams, which might cause brief audio glitches/dropouts? (see: https://github.com/PaulStoffregen/cores/blob/master/teensy4/AudioStream.cpp#L194)
I haven't looked at adding other new Audio objects in detail, but AudioStream also disables IRQ while doing memory stuff when initializing, so that might also be an issue.
Note that I am not very familiar with the codebase, so I might just be blatantly wrong :p
Both these things happen already as the static initialization proceeds AFAICT. Disabling interrupts is absolutely essential to prevent
the datastructures being corrupted during the connection changes, and remember this might last a few 100's of nanoseconds,
whereas the audio related interrupts are every 2.9ms, and audio ISRs are updating buffers for the next 128 samples so
can afford to be delayed for quite a while.
One thing that I could see causing issues dynamically is deleting the AudioStream that's currently got update responsibility - I don't
think this will work (you'd need to iterate over the other active streams and assign a new one if possible, else switch off
the audio system). Pretty sure I didn't see anything like this in the sources.
