Results 1 to 3 of 3
Thread: maximum pulse-frequency from quadrature-encoders on Teensy 4.1
    Oct 2020
    1
    Hello everybody,
    the CPU-clock of the Tennsy 4.1 is real fast (600Mhz). What maxizum pulse-frequency from quadrature-encoders can the Teensy 4.1 handle properly when using two Interrupt-Pins? Or does the Teensy 4.1 have some special quadrature-encoder-hardware-counters?
    Could this maximum-frequency be shifted to higher values when using a encoder to counter interface chip? From a quick search I found the LS7083 / LS7084 which go up to 625 kHz. This seems not to be very fast. Does anybody know of chips that can cope with higherpulse-freuqnecies?
    best regards Stefan
    7,864
    You might take a look at Chapter 55 of the T4 (IMXRT reference manual). Which if you have not already done so you can download from: https://www.pjrc.com/teensy/datasheets.html
    There is an encoder library (QuadEncoder) which ships with Teensyduino which uses this support.
    And manual says: Maximum count frequency equals the peripheral clock rate
    1,210
    If you have a high speed application you could try this library from mjs513: https://forum.pjrc.com/threads/58478...ncoder-Library. It uses the built in hardware decoders and is very fast.
    What speed are you aiming at?
    Edit: ups cross post...
