Results 1 to 4 of 4
Thread: USBHOST_T36 library is not working on Teensy 4.1 Board
    Oct 2020
    4
    Hi all,
    I have a Teensy 4.1 board. I would like to use 5V and GND pins using USB Host.
    I have downloaded USBHOST_T36 library and uploaded my 4.1 board but throwed an error below:
    #error "USBHost_t36 only works with Teensy 3.6. Please select it in Tools > Boards"
    I need 5V for my project. How can i receive 5V from USB host pin or another pins?
    13,141
    USBHost is included in TeensyDuino. The versions included in TD 1.53 is designed to work with T_3.6 and T_4.x - sounds like an update is needed.
    And remove the local copy. Though TD 1.54b2 has an update - ... though is may get an update for beta 3
    23,383
    Looks like this was duplicated on github
    https://github.com/PaulStoffregen/USBHost_t36/issues/41
    23,383
    This is very likely an old or corrupted software install.
    Please download a fresh copy of Arduino 1.8.13 and Teensduino 1.53. Follow the install steps on this page:
