Results 1 to 3 of 3
Thread: Problem with multiple WaveformMod objects for teensy polyphonic synth
    May 2018
    3
    Hi, This is my first time posting here. I'm having an issue trying to build a polyphonic (paraphonic technically) synth using the WaveformMod object on a Teensy 3.2. I am trying to get the polyphony up to 32 voices, but when I get past 16 voices I start getting glitches in the audio. Some of the voices won't play, while others sound like they are being frequency modulated in a weird way. Is there a limit to the number of WaveformMod, envelope, or mixer objects that the Teensy 3.2 or Audio shield can handle?
    Any ideas as to what could be causing this issue, or suggestions for how to fix it? I appreciate any input.
    Here is the code:
    #include "note_frequency.h"
    #include "scales.h"
    #include <Bounce.h>
    // 15 = 15 ms debounce time
    Bounce button1 = Bounce(7, 15); // change waveform
    Bounce button2 = Bounce(6, 15); // change LFO destination
    Bounce button3 = Bounce(26, 15); // Hold/Release
    Bounce button4 = Bounce(24, 15);
    // The circuit:
    // - LED attached from pin 13 to ground
    // - pushbutton attached to pin 8 from +5V
    // - 10K resistor attached to pin 8 from ground
    const int buttonPinHold = 8; // the number of the pushbutton pin // Hold
    const int buttonPinRelease = 12; // the number of the pushbutton pin // Release
    int buttonStateHold = 0; // variable for reading the pushbutton status
    int buttonStateRelease = 0; // variable for reading the pushbutton status
    int led1 = 21;
    int led2 = 20;
    int led3 = 25;
    int led4 = 32;
    int current_waveform = 0;
    //Mux control pins
    int s0 = 2; // digital pin 5 is first switch in multiplexer
    int s1 = 3;
    int s2 = 4;
    int s3 = 5;
    //Mux in “SIG” pin
    int SIG_pin = 1;
    int SIG_pin2 = 16;
    int SIG_pin3 = 0;
    int scale_index = 0;//var to keep track fo which scale is being used
    float DeTune = 1.0;
    int current_LFO = 0; // variable for LFO routing
    int holdstate1 = 0; // current state of the hold button for touch sensor 1
    int lastholdstate1 = 0; // variable to change from Hold to Release
    int touchstate1 = 0; // current state of the touch sensor 1
    int lasttouchstate1 = 0; // previous state of the touch sensor 1
    int touchstate2 = 0; // current state of the touch sensor 2
    int lasttouchstate2 = 0; // previous state of the touch sensor 2
    int touchstate3 = 0; // current state of the touch sensor 3
    int lasttouchstate3 = 0; // previous state of the touch sensor 3
    int touchstate4 = 0; // current state of the touch sensor 4
    int lasttouchstate4 = 0; // previous state of the touch sensor 4
    int touchstate5 = 0; // current state of the touch sensor 5
    int lasttouchstate5 = 0; // previous state of the touch sensor 5
    int touchstate6 = 0; // current state of the touch sensor 6
    int lasttouchstate6 = 0; // previous state of the touch sensor 6
    int touchstate7 = 0; // current state of the touch sensor 7
    int lasttouchstate7 = 0; // previous state of the touch sensor 7
    int touchstate8 = 0; // current state of the touch sensor 8
    int lasttouchstate8 = 0; // previous state of the touch sensor 8
    int touchstate9 = 0; // current state of the touch sensor 9
    int lasttouchstate9 = 0; // previous state of the touch sensor 9
    int touchstate10 = 0; // current state of the touch sensor 10
    int lasttouchstate10 = 0; // previous state of the touch sensor 10
    int touchstate11 = 0; // current state of the touch sensor 11
    int lasttouchstate11 = 0; // previous state of the touch sensor 11
    int touchstate12 = 0; // current state of the touch sensor 12
    int lasttouchstate12 = 0; // previous state of the touch sensor 12
    int touchstate13 = 0; // current state of the touch sensor 9
    int lasttouchstate13 = 0; // previous state of the touch sensor 9
    int touchstate14 = 0; // current state of the touch sensor 10
    int lasttouchstate14 = 0; // previous state of the touch sensor 10
    int touchstate15 = 0; // current state of the touch sensor 11
    int lasttouchstate15 = 0; // previous state of the touch sensor 11
    int touchstate16 = 0; // current state of the touch sensor 12
    int lasttouchstate16 = 0; // previous state of the touch sensor 12
    int touchstate17 = 0; // current state of the touch sensor 17
    int lasttouchstate17 = 0; // previous state of the touch sensor 17
    int touchstate18 = 0; // current state of the touch sensor 18
    int lasttouchstate18 = 0; // previous state of the touch sensor 18
    int touchstate19 = 0; // current state of the touch sensor 19
    int lasttouchstate19 = 0; // previous state of the touch sensor 19
    int touchstate20 = 0; // current state of the touch sensor 20
    int lasttouchstate20 = 0; // previous state of the touch sensor 20
    int touchstate21 = 0; // current state of the touch sensor 21
    int lasttouchstate21 = 0; // previous state of the touch sensor 21
    int touchstate22 = 0; // current state of the touch sensor 22
    int lasttouchstate22 = 0; // previous state of the touch sensor 22
    int touchstate23 = 0; // current state of the touch sensor 23
    int lasttouchstate23 = 0; // previous state of the touch sensor 23
    int touchstate24 = 0; // current state of the touch sensor 24
    int lasttouchstate24 = 0; // previous state of the touch sensor 24
    int Attacktime = 0; // Envelope Attack Time
    int Decayreleasetime = 0; // Envelope Decay & Release time
    int fscalefactor1 = -5.8; //adjust this for a linear curve for vibrato rate
    int fscalefactor2 = -8; //adjust this for a linear curve for vibrato depth
    int fscalefactor3 = -6; //adjust this for a linear curve for filter cutoff frequency
    int fscalefactor4 = -4; //adjust this for a linear curve for filter cutoff LFO amount
    int fscalefactor5 = -4; //adjust this for a linear curve for filter resonance
    const int numReadings = 11; // SMOOTHING VARIABLES
    const int numReadings2 = 12; // LFO intensity smoothing
    const int numReadings3 = 13; // Tuning knob smoothing
    int readings[numReadings]; // the readings from the analog input
    int readIndex = 0; // the index of the current reading
    int total = 0; // the running total
    int average = 0; // the average
    int readings2[numReadings2]; // the readings from the analog input
    int readIndex2 = 0; // the index of the current reading
    int total2 = 0; // the running total
    int average2 = 0; // the average
    int readings3[numReadings3]; // the readings from the analog input
    int readIndex3 = 0; // the index of the current reading
    int total3 = 0; // the running total
    int average3 = 0; // the average
    #include <SerialFlash.h>
    AudioSynthWaveform waveform1; //xy=115.57479095458984,1430.8572034835815
    AudioAmplifier amp1; //xy=295.57479095458984,1432.8572034835815
    AudioSynthWaveformModulated waveformMod3; //xy=529.2890701293945,308.00000190734863
    AudioSynthWaveformModulated waveformMod2; //xy=530.2890701293945,246.00000190734863
    AudioSynthWaveformModulated waveformMod1; //xy=533.2890701293945,181.00000190734863
    AudioSynthWaveformModulated waveformMod4; //xy=536.2890701293945,370.00000190734863
    AudioSynthWaveformModulated waveformMod10; //xy=536.2890701293945,802.0000019073486
    AudioSynthWaveformModulated waveformMod7; //xy=537.2890701293945,590.0000019073486
    AudioSynthWaveformModulated waveformMod11; //xy=536.2890701293945,855.0000019073486
    AudioSynthWaveformModulated waveformMod9; //xy=537.2890701293945,748.0000019073486
    AudioSynthWaveformModulated waveformMod12; //xy=537.2890701293945,908.0000019073486
    AudioSynthWaveformModulated waveformMod8; //xy=540.2890701293945,646.0000019073486
    AudioSynthWaveformModulated waveformMod6; //xy=542.2890701293945,526.0000019073486
    AudioSynthWaveformModulated waveformMod5; //xy=546.2890701293945,462.00000190734863
    AudioSynthWaveformModulated waveformMod16; //xy=546.2890701293945,1113.0000019073486
    AudioSynthWaveformModulated waveformMod17; //xy=546.2890701293945,1169.0000019073486
    AudioSynthWaveformModulated waveformMod21; //xy=545.736699785505,1522.8795216424126
    AudioSynthWaveformModulated waveformMod14; //xy=549.2890701293945,1009.0000019073486
    AudioSynthWaveformModulated waveformMod15; //xy=549.2890701293945,1059.0000019073486
    AudioSynthWaveformModulated waveformMod20; //xy=548.5938153948102,1458.5938245228358
    AudioSynthWaveformModulated waveformMod18; //xy=551.6840362548828,1342.2395629882812
    AudioSynthWaveformModulated waveformMod19; //xy=551.4509789603097,1402.8795760018486
    AudioSynthWaveformModulated waveformMod25; //xy=552.5156173706055,1784.0158405303955
    AudioSynthWaveformModulated waveformMod22; //xy=553.5156631469727,1630.0156574249268
    AudioSynthWaveformModulated waveformMod23; //xy=554.5156784057617,1681.0159015655518
    AudioSynthWaveformModulated waveformMod24; //xy=554.5156478881836,1728.0156574249268
    AudioEffectEnvelope envelope2; //xy=713.2890701293945,245.00000190734863
    AudioEffectEnvelope envelope1; //xy=718.2890701293945,181.00000190734863
    AudioEffectEnvelope envelope6; //xy=719.2890701293945,523.0000019073486
    AudioEffectEnvelope envelope7; //xy=721.2890701293945,588.0000019073486
    AudioEffectEnvelope envelope5; //xy=722.2890701293945,461.00000190734863
    AudioEffectEnvelope envelope3; //xy=723.2890701293945,313.00000190734863
    AudioEffectEnvelope envelope8; //xy=727.2890701293945,640.0000019073486
    AudioEffectEnvelope envelope9; //xy=727.2890701293945,742.0000019073486
    AudioEffectEnvelope envelope4; //xy=730.2890701293945,370.00000190734863
    AudioEffectEnvelope envelope12; //xy=729.2890701293945,906.0000019073486
    AudioEffectEnvelope envelope11; //xy=730.2890701293945,853.0000019073486
    AudioEffectEnvelope envelope10; //xy=734.2890701293945,798.0000019073486
    AudioEffectEnvelope envelope24; //xy=737.515625,1782.015625
    AudioEffectEnvelope envelope21; //xy=741.515625,1630.015625
    AudioEffectEnvelope envelope22; //xy=741.5156364440918,1679.015718460083
    AudioEffectEnvelope envelope23; //xy=741.5156173706055,1727.015718460083
    AudioEffectEnvelope envelope15; //xy=746.2890701293945,1116.0000019073486
    AudioEffectEnvelope envelope14; //xy=748.2890701293945,1063.0000019073486
    AudioEffectEnvelope envelope18; //xy=747.1652145385742,1402.8795595169067
    AudioEffectEnvelope envelope16; //xy=750.2890701293945,1170.0000019073486
    AudioEffectEnvelope envelope13; //xy=752.2890701293945,1010.0000019073486
    AudioEffectEnvelope envelope17; //xy=751.4509124755859,1342.8795909881592
    AudioEffectEnvelope envelope20; //xy=752.8795013427734,1524.3079586029053
    AudioEffectEnvelope envelope19; //xy=754.3080520629883,1460.022367477417
    AudioMixer4 mixer1; //xy=904.2890701293945,550.0000019073486
    AudioMixer4 mixer4; //xy=919.2890701293945,812.0000019073486
    AudioMixer4 mixer2; //xy=929.2890701293945,271.00000190734863
    AudioMixer4 mixer7; //xy=932.4510440826416,1699.8796730041504
    AudioMixer4 mixer6; //xy=935.2890701293945,1080.0000019073486
    AudioMixer4 mixer8; //xy=932.8796081542969,1894.3082809448242
    AudioMixer4 mixer9; //xy=937.1654090881348,2154.3082847595215
    AudioMixer4 mixer5; //xy=942.8795471191406,1427.8796844482422
    AudioMixer4 mixer3; //xy=1110.2890701293945,662.0000019073486
    AudioMixer4 mixer10; //xy=1167.165241241455,1524.308122907366
    AudioMixer4 mixer11; //xy=1435.736607142857,678.5937499999999
    AudioSynthWaveformModulated waveformMod13; //xy=1493.57474899292,844.2857494354248
    AudioAmplifier amp13; //xy=1530.57474899292,919.2857494354248
    AudioAmplifier amp14; //xy=1682.57474899292,879.2857494354248
    AudioFilterStateVariable filter1; //xy=1717.57474899292,672.2857494354248
    AudioOutputI2S i2s1; //xy=1869.57474899292,660.2857494354248
    AudioConnection patchCord1(waveform1, amp1);
    AudioConnection patchCord2(amp1, 0, waveformMod1, 0);
    AudioConnection patchCord3(amp1, 0, waveformMod2, 0);
    AudioConnection patchCord4(amp1, 0, waveformMod3, 0);
    AudioConnection patchCord5(amp1, 0, waveformMod4, 0);
    AudioConnection patchCord6(amp1, 0, waveformMod5, 0);
    AudioConnection patchCord7(amp1, 0, waveformMod6, 0);
    AudioConnection patchCord8(amp1, 0, waveformMod7, 0);
    AudioConnection patchCord9(amp1, 0, waveformMod8, 0);
    AudioConnection patchCord10(amp1, 0, waveformMod9, 0);
    AudioConnection patchCord11(amp1, 0, waveformMod10, 0);
    AudioConnection patchCord12(amp1, 0, waveformMod11, 0);
    AudioConnection patchCord13(amp1, 0, waveformMod12, 0);
    AudioConnection patchCord14(amp1, 0, waveformMod14, 0);
    AudioConnection patchCord15(amp1, 0, waveformMod15, 0);
    AudioConnection patchCord16(amp1, 0, waveformMod16, 0);
    AudioConnection patchCord17(amp1, 0, waveformMod17, 0);
    AudioConnection patchCord18(amp1, 0, waveformMod19, 0);
    AudioConnection patchCord19(amp1, 0, waveformMod20, 0);
    AudioConnection patchCord20(amp1, 0, waveformMod21, 0);
    AudioConnection patchCord21(amp1, 0, waveformMod18, 0);
    AudioConnection patchCord22(amp1, 0, waveformMod22, 0);
    AudioConnection patchCord23(amp1, 0, waveformMod23, 0);
    AudioConnection patchCord24(amp1, 0, waveformMod24, 0);
    AudioConnection patchCord25(amp1, 0, waveformMod25, 0);
    AudioConnection patchCord26(waveformMod3, envelope3);
    AudioConnection patchCord27(waveformMod2, envelope2);
    AudioConnection patchCord28(waveformMod1, envelope1);
    AudioConnection patchCord29(waveformMod4, envelope4);
    AudioConnection patchCord30(waveformMod10, envelope10);
    AudioConnection patchCord31(waveformMod7, envelope7);
    AudioConnection patchCord32(waveformMod11, envelope11);
    AudioConnection patchCord33(waveformMod9, envelope9);
    AudioConnection patchCord34(waveformMod12, envelope12);
    AudioConnection patchCord35(waveformMod8, envelope8);
    AudioConnection patchCord36(waveformMod6, envelope6);
    AudioConnection patchCord37(waveformMod5, envelope5);
    AudioConnection patchCord38(waveformMod16, envelope15);
    AudioConnection patchCord39(waveformMod17, envelope16);
    AudioConnection patchCord40(waveformMod21, envelope20);
    AudioConnection patchCord41(waveformMod14, envelope13);
    AudioConnection patchCord42(waveformMod15, envelope14);
    AudioConnection patchCord43(waveformMod20, envelope19);
    AudioConnection patchCord44(waveformMod18, envelope17);
    AudioConnection patchCord45(waveformMod19, envelope18);
    AudioConnection patchCord46(waveformMod25, envelope24);
    AudioConnection patchCord47(waveformMod22, envelope21);
    AudioConnection patchCord48(waveformMod23, envelope22);
    AudioConnection patchCord49(waveformMod24, envelope23);
    AudioConnection patchCord50(envelope2, 0, mixer2, 1);
    AudioConnection patchCord51(envelope1, 0, mixer2, 0);
    AudioConnection patchCord52(envelope6, 0, mixer1, 1);
    AudioConnection patchCord53(envelope7, 0, mixer1, 2);
    AudioConnection patchCord54(envelope5, 0, mixer1, 0);
    AudioConnection patchCord55(envelope3, 0, mixer2, 2);
    AudioConnection patchCord56(envelope8, 0, mixer1, 3);
    AudioConnection patchCord57(envelope9, 0, mixer4, 0);
    AudioConnection patchCord58(envelope4, 0, mixer2, 3);
    AudioConnection patchCord59(envelope12, 0, mixer4, 3);
    AudioConnection patchCord60(envelope11, 0, mixer4, 2);
    AudioConnection patchCord61(envelope10, 0, mixer4, 1);
    AudioConnection patchCord62(envelope24, 0, mixer7, 3);
    AudioConnection patchCord63(envelope21, 0, mixer7, 0);
    AudioConnection patchCord64(envelope22, 0, mixer7, 1);
    AudioConnection patchCord65(envelope23, 0, mixer7, 2);
    AudioConnection patchCord66(envelope15, 0, mixer6, 2);
    AudioConnection patchCord67(envelope14, 0, mixer6, 1);
    AudioConnection patchCord68(envelope18, 0, mixer5, 1);
    AudioConnection patchCord69(envelope16, 0, mixer6, 3);
    AudioConnection patchCord70(envelope13, 0, mixer6, 0);
    AudioConnection patchCord71(envelope17, 0, mixer5, 0);
    AudioConnection patchCord72(envelope20, 0, mixer5, 3);
    AudioConnection patchCord73(envelope19, 0, mixer5, 2);
    AudioConnection patchCord74(mixer1, 0, mixer3, 1);
    AudioConnection patchCord75(mixer4, 0, mixer3, 2);
    AudioConnection patchCord76(mixer2, 0, mixer3, 0);
    AudioConnection patchCord77(mixer7, 0, mixer10, 1);
    AudioConnection patchCord78(mixer6, 0, mixer3, 3);
    AudioConnection patchCord79(mixer8, 0, mixer10, 2);
    AudioConnection patchCord80(mixer9, 0, mixer10, 3);
    AudioConnection patchCord81(mixer5, 0, mixer10, 0);
    AudioConnection patchCord82(mixer3, 0, mixer11, 0);
    AudioConnection patchCord83(mixer10, 0, mixer11, 1);
    AudioConnection patchCord84(mixer11, 0, filter1, 0);
    AudioConnection patchCord85(waveformMod13, amp13);
    AudioConnection patchCord86(amp13, amp14);
    AudioConnection patchCord87(amp14, 0, filter1, 1);
    AudioConnection patchCord88(filter1, 0, i2s1, 0);
    AudioConnection patchCord89(filter1, 0, i2s1, 1);
    AudioControlSGTL5000 sgtl5000_1; //xy=775.2890701293945,85.00000190734863
    AudioMemory(20);
    sgtl5000_1.enable();
    sgtl5000_1.volume(0.9);
    //pinMode(2, INPUT_PULLUP); //Button pins
    pinMode(6, INPUT_PULLUP);
    pinMode(7, INPUT_PULLUP);
    pinMode(26, INPUT_PULLUP);
    pinMode(24, INPUT_PULLUP);
    pinMode(buttonPinHold, INPUT); // Hold button setup
    pinMode(buttonPinRelease, INPUT); // Release button setup
    // pinMode(led1, OUTPUT);
    // pinMode(led2, OUTPUT);
    // pinMode(led3, OUTPUT);
    // pinMode(led4, OUTPUT);
    current_waveform = WAVEFORM_SAWTOOTH;
    waveformMod1.begin(current_waveform);
    waveformMod2.begin(current_waveform);
    waveformMod3.begin(current_waveform);
    waveformMod4.begin(current_waveform);
    waveformMod5.begin(current_waveform);
    waveformMod6.begin(current_waveform);
    waveformMod7.begin(current_waveform);
    waveformMod8.begin(current_waveform);
    waveformMod9.begin(current_waveform);
    waveformMod10.begin(current_waveform);
    waveformMod11.begin(current_waveform);
    waveformMod12.begin(current_waveform);
    waveformMod14.begin(current_waveform);
    waveformMod15.begin(current_waveform);
    waveformMod16.begin(current_waveform);
    waveformMod17.begin(current_waveform);
    waveformMod18.begin(current_waveform);
    waveformMod19.begin(current_waveform);
    waveformMod20.begin(current_waveform);
    waveformMod21.begin(current_waveform);
    waveformMod22.begin(current_waveform);
    waveformMod23.begin(current_waveform);
    waveformMod24.begin(current_waveform);
    waveformMod25.begin(current_waveform);
    waveformMod13.begin(WAVEFORM_TRIANGLE);
    pinMode(s0, OUTPUT);
    pinMode(s1, OUTPUT);
    pinMode(s2, OUTPUT);
    pinMode(s3, OUTPUT);
    digitalWrite(s0, LOW);
    digitalWrite(s1, LOW);
    digitalWrite(s2, LOW);
    digitalWrite(s3, LOW);
    mixer1.gain(0, 0.3);
    mixer1.gain(1, 0.3);
    mixer1.gain(2, 0.3);
    mixer1.gain(3, 0.3);
    mixer2.gain(0, 0.3);
    mixer2.gain(1, 0.3);
    mixer2.gain(2, 0.3);
    mixer2.gain(3, 0.3);
    mixer4.gain(0, 0.3);
    mixer4.gain(1, 0.3);
    mixer4.gain(2, 0.3);
    mixer4.gain(3, 0.3);
    mixer6.gain(0, 0.3);
    mixer6.gain(1, 0.3);
    mixer6.gain(2, 0.3);
    mixer6.gain(3, 0.3);
    mixer3.gain(0, 0.3); // First 16 Mixer //
    mixer3.gain(1, 0.3);
    mixer3.gain(2, 0.3);
    mixer3.gain(3, 0.3);
    mixer5.gain(0, 0.3);
    mixer5.gain(1, 0.3);
    mixer5.gain(2, 0.3);
    mixer5.gain(3, 0.3);
    mixer7.gain(0, 0.3);
    mixer7.gain(1, 0.3);
    mixer7.gain(2, 0.3);
    mixer7.gain(3, 0.3);
    mixer8.gain(0, 0.3);
    mixer8.gain(1, 0.3);
    mixer8.gain(2, 0.3);
    mixer8.gain(3, 0.3);
    mixer9.gain(0, 0.3);
    mixer9.gain(1, 0.3);
    mixer9.gain(2, 0.3);
    mixer9.gain(3, 0.3);
    mixer10.gain(0, 0.3); // Second 16 Mixer //
    mixer10.gain(1, 0.3);
    mixer10.gain(2, 0.3);
    mixer10.gain(3, 0.3);
    mixer11.gain(0, 0.3); // Full 32 Mixer //
    mixer11.gain(1, 0.3);
    mixer11.gain(2, 0);
    mixer11.gain(3, 0);
    waveform1.frequency(1); //// LFO ////
    waveform1.amplitude(0.1);
    waveformMod1.frequency(440); //// Voices ////
    waveformMod1.amplitude(0.75);
    envelope1.attack(1000);
    envelope1.hold(1);
    envelope1.decay(1500);
    envelope1.sustain(0.5);
    envelope1.release(1000);
    waveformMod2.frequency(440);
    waveformMod2.amplitude(0.75);
    envelope2.attack(1000);
    envelope2.hold(1);
    envelope2.decay(1500);
    envelope2.sustain(0.5);
    envelope2.release(1000);
    waveformMod3.frequency(440);
    waveformMod3.amplitude(0.75);
    envelope3.attack(1000);
    envelope3.hold(1);
    envelope3.decay(1500);
    envelope3.sustain(0.5);
    envelope3.release(1000);
    waveformMod4.frequency(440);
    waveformMod4.amplitude(0.75);
    envelope4.attack(1000);
    envelope4.hold(1);
    envelope4.decay(1500);
    envelope4.sustain(0.5);
    envelope4.release(1000);
    waveformMod5.frequency(440);
    waveformMod5.amplitude(0.75);
    envelope5.attack(1000);
    envelope5.hold(1);
    envelope5.decay(1500);
    envelope5.sustain(0.5);
    envelope5.release(1000);
    waveformMod6.frequency(440);
    waveformMod6.amplitude(0.75);
    envelope6.attack(1000);
    envelope6.hold(1);
    envelope6.decay(1500);
    envelope6.sustain(0.5);
    envelope6.release(1000);
    waveformMod7.frequency(440);
    waveformMod7.amplitude(0.75);
    envelope7.attack(1000);
    envelope7.hold(1);
    envelope7.decay(1500);
    envelope7.sustain(0.5);
    envelope7.release(1000);
    waveformMod8.frequency(440);
    waveformMod8.amplitude(0.75);
    envelope8.attack(1000);
    envelope8.hold(1);
    envelope8.decay(1500);
    envelope8.sustain(0.5);
    envelope8.release(1000);
    waveformMod9.frequency(440);
    waveformMod9.amplitude(0.75);
    envelope9.attack(1000);
    envelope9.hold(1);
    envelope9.decay(1500);
    envelope9.sustain(0.5);
    envelope9.release(1000);
    waveformMod10.frequency(440);
    waveformMod10.amplitude(0.75);
    envelope10.attack(1000);
    envelope10.hold(1);
    envelope10.decay(1500);
    envelope10.sustain(0.5);
    envelope10.release(1000);
    waveformMod11.frequency(440);
    waveformMod11.amplitude(0.75);
    envelope11.attack(1000);
    envelope11.hold(1);
    envelope11.decay(1500);
    envelope11.sustain(0.5);
    envelope11.release(1000);
    waveformMod12.frequency(440);
    waveformMod12.amplitude(0.75);
    envelope12.attack(1000);
    envelope12.hold(1);
    envelope12.decay(1500);
    envelope12.sustain(0.5);
    envelope12.release(1000);
    envelope13.attack(1000);
    envelope13.hold(1);
    envelope13.decay(1500);
    envelope13.sustain(0.5);
    envelope13.release(1000);
    waveformMod14.frequency(440);
    waveformMod14.amplitude(0.75);
    envelope14.attack(1000);
    envelope14.hold(1);
    envelope14.decay(1500);
    envelope14.sustain(0.5);
    envelope14.release(1000);
    waveformMod15.frequency(440);
    waveformMod15.amplitude(0.75);
    envelope15.attack(1000);
    envelope15.hold(1);
    envelope15.decay(1500);
    envelope15.sustain(0.5);
    envelope15.release(1000);
    waveformMod16.frequency(440);
    waveformMod16.amplitude(0.75);
    envelope16.attack(1000);
    envelope16.hold(1);
    envelope16.decay(1500);
    envelope16.sustain(0.5);
    envelope16.release(1000);
    waveformMod17.frequency(440);
    waveformMod17.amplitude(0.75);
    envelope17.attack(1000);
    envelope17.hold(1);
    envelope17.decay(1500);
    envelope17.sustain(0.5);
    envelope17.release(1000);
    waveformMod18.frequency(440);
    waveformMod18.amplitude(0.75);
    envelope18.attack(1000);
    envelope18.hold(1);
    envelope18.decay(1500);
    envelope18.sustain(0.5);
    envelope18.release(1000);
    waveformMod19.frequency(440);
    waveformMod19.amplitude(0.75);
    envelope20.attack(1000);
    envelope20.hold(1);
    envelope20.decay(1500);
    envelope20.sustain(0.5);
    envelope20.release(1000);
    waveformMod20.frequency(440);
    waveformMod20.amplitude(0.75);
    waveformMod21.frequency(440);
    waveformMod21.amplitude(0.75);
    waveformMod13.frequency(2); // LFO for filter //
    waveformMod13.amplitude(1);
    waveformMod13.offset(-0.232); ///// use offset to modulate from -1 to 0 so that filter freq doesn't go too high
    // amp1.gain(1.); // Stop modulation from affecting pitch when filter mod engaged
    amp14.gain(0.); // Stop modulation from affecting filter when pitch mod engaged
    filter1.resonance(0.705); // Filter Resonance
    filter1.octaveControl(7); // Number of octaves a control sig. of 1 will shift filter
    // initialize all the readings to 0:
    for (int thisReading = 0; thisReading < numReadings; thisReading++) {
    readings[thisReading] = 0;
    int amps_setting = 0;
    float FilterResMin = 0.7;
    ///////////////////// Change Waveform ////////////////
    button1.update();
    if (button1.fallingEdge()) {
    switch (current_waveform) {
    case WAVEFORM_SINE:
    Serial.println("Sawtooth");
    case WAVEFORM_SAWTOOTH:
    current_waveform = WAVEFORM_SQUARE;
    Serial.println("Square");
    case WAVEFORM_SQUARE:
    current_waveform = WAVEFORM_TRIANGLE;
    Serial.println("Triangle");
    case WAVEFORM_TRIANGLE:
    current_waveform = WAVEFORM_SINE;
    Serial.println("Sine");
    ///////////////////// Change LFO destination ////////////////
    digitalWrite(led1, HIGH); // turn the LED on (HIGH is the voltage level)
    delay(1000); // wait for a second
    digitalWrite(led1, LOW); // turn the LED off by making the voltage LOW
    button2.update();
    // Button 2 changes the LFO destination by switching the input levels on mixers feeding mod destinations
    if (button2.fallingEdge()) { // LFO to Filter
    if (amps_setting == 0) {
    amp1.gain(0);
    amp14.gain(1); // 2nd LFO amp
    FilterResMin = 1.1;
    Serial.println("LFO Filter");
    amps_setting = 1;
    else if (amps_setting == 1) { // LFO to Pitch & Filter
    amp1.gain(1.);
    amp14.gain(1.);
    FilterResMin = 1.1;
    Serial.println("LFO Pitch & Filter");
    amps_setting = 2;
    else if (amps_setting == 2) { // LFO to Pitch
    amp1.gain(1.);
    amp14.gain(0);
    FilterResMin = 0.7;
    Serial.println("LFO Pitch");
    amps_setting = 0;
    // read the state of the Hold button value:
    buttonStateHold = digitalRead(buttonPinHold);
    buttonStateRelease = digitalRead(buttonPinRelease);
    //////// Scale ///////////
    scale_index = 0; // map(analogRead(A19), 0, 1023, 0, 7); // Change Scale
    //Serial.print("Scale = ");
    //Serial.println(scale_index);
    //DeTune = ((float)readMux2(0) / 1023) + 1; // ((float)average3 / 1023) + 1; // Read Mux 2 input 0 and send value to DeTune Oscilators
    DeTune = ((float)average3 / 1023) + 1;
    //Serial.print(readMux2(0));
    // Serial.print(" P0 = ");
    // Serial.println( DeTune);
    // delay(100);
    waveformMod1.frequency((note_frequency[scale[scale_index][0]] * DeTune)); // Tune up one octave
    waveformMod2.frequency((note_frequency[scale[scale_index][1]] * DeTune)); // Tune up one octave
    waveformMod3.frequency((note_frequency[scale[scale_index][2]] * DeTune)); // Tune up one octave
    waveformMod4.frequency((note_frequency[scale[scale_index][3]] * DeTune)); // Tune up one octave
    waveformMod5.frequency((note_frequency[scale[scale_index][4]] * DeTune)); // Tune up one octave
    waveformMod6.frequency((note_frequency[scale[scale_index][5]] * DeTune)); // Tune up one octave
    waveformMod7.frequency((note_frequency[scale[scale_index][6]] * DeTune)); // Tune up one octave
    waveformMod8.frequency((note_frequency[scale[scale_index][7]] * DeTune)); // Tune up one octave
    waveformMod9.frequency((note_frequency[scale[scale_index][8]] * DeTune)); // Tune up one octave
    waveformMod10.frequency((note_frequency[scale[scale_index][9]] * DeTune)); // Tune up one octave
    waveformMod11.frequency((note_frequency[scale[scale_index][10]] * DeTune)); // Tune up one octave
    waveformMod12.frequency((note_frequency[scale[scale_index][11]] * DeTune)); // Tune up one octave
    waveformMod14.frequency((note_frequency[scale[scale_index][12]] * DeTune)); // Tune up one octave
    waveformMod15.frequency((note_frequency[scale[scale_index][13]] * DeTune)); // Tune up one octave
    waveformMod16.frequency((note_frequency[scale[scale_index][14]] * DeTune)); // Tune up one octave
    waveformMod17.frequency((note_frequency[scale[scale_index][15]] * DeTune)); // Tune up one octave
    waveformMod18.frequency((note_frequency[scale[scale_index][16]] * DeTune)); // Tune up one octave
    waveformMod19.frequency((note_frequency[scale[scale_index][17]] * DeTune)); // Tune up one octave
    waveformMod20.frequency((note_frequency[scale[scale_index][18]] * DeTune)); // Tune up one octave
    waveformMod21.frequency((note_frequency[scale[scale_index][19]] * DeTune)); // Tune up one octave
    waveformMod22.frequency((note_frequency[scale[scale_index][20]] * DeTune)); // Tune up one octave
    waveformMod23.frequency((note_frequency[scale[scale_index][21]] * DeTune)); // Tune up one octave
    waveformMod24.frequency((note_frequency[scale[scale_index][22]] * DeTune)); // Tune up one octave
    waveformMod25.frequency((note_frequency[scale[scale_index][23]] * DeTune)); // Tune up one octave
    ///// Envelopes /////
    //check knob and set value as envelope attack time
    Attacktime = map(readMux2(3), 0, 1023, 1, 4000);
    envelope1.attack(Attacktime);
    envelope2.attack(Attacktime);
    envelope3.attack(Attacktime);
    envelope4.attack(Attacktime);
    envelope5.attack(Attacktime);
    envelope6.attack(Attacktime);
    envelope7.attack(Attacktime);
    envelope8.attack(Attacktime);
    envelope9.attack(Attacktime);
    envelope10.attack(Attacktime);
    envelope11.attack(Attacktime);
    envelope12.attack(Attacktime);
    envelope13.attack(Attacktime);
    envelope14.attack(Attacktime);
    envelope15.attack(Attacktime);
    envelope16.attack(Attacktime);
    envelope17.attack(Attacktime);
    envelope18.attack(Attacktime);
    envelope19.attack(Attacktime);
    envelope20.attack(Attacktime);
    envelope21.attack(Attacktime);
    envelope22.attack(Attacktime);
    envelope23.attack(Attacktime);
    envelope24.attack(Attacktime);
    //check knob and set value as decay & release times (and scale sustain level so that short decay = low sustain, long decay = high sustain)
    Decayreleasetime = map(readMux2(4), 0, 1023, 1, 9000);
    //Serial.println(analogRead(A18));
    envelope1.decay(Decayreleasetime);
    envelope1.release(Decayreleasetime);
    envelope2.decay(Decayreleasetime);
    envelope2.release(Decayreleasetime);
    envelope3.decay(Decayreleasetime);
    envelope3.release(Decayreleasetime);
    envelope4.decay(Decayreleasetime);
    envelope4.release(Decayreleasetime);
    envelope5.decay(Decayreleasetime);
    envelope5.release(Decayreleasetime);
    envelope6.decay(Decayreleasetime);
    envelope6.release(Decayreleasetime);
    envelope7.decay(Decayreleasetime);
    envelope7.release(Decayreleasetime);
    envelope8.decay(Decayreleasetime);
    envelope8.release(Decayreleasetime);
    envelope9.decay(Decayreleasetime);
    envelope9.release(Decayreleasetime);
    envelope10.decay(Decayreleasetime);
    envelope10.release(Decayreleasetime);
    envelope11.decay(Decayreleasetime);
    envelope11.release(Decayreleasetime);
    envelope12.decay(Decayreleasetime);
    envelope12.release(Decayreleasetime);
    envelope13.decay(Decayreleasetime);
    envelope13.release(Decayreleasetime);
    envelope14.decay(Decayreleasetime);
    envelope14.release(Decayreleasetime);
    envelope15.decay(Decayreleasetime);
    envelope15.release(Decayreleasetime);
    envelope16.decay(Decayreleasetime);
    envelope16.release(Decayreleasetime);
    envelope17.decay(Decayreleasetime);
    envelope17.release(Decayreleasetime);
    envelope18.decay(Decayreleasetime);
    envelope18.release(Decayreleasetime);
    envelope19.decay(Decayreleasetime);
    envelope19.release(Decayreleasetime);
    envelope20.decay(Decayreleasetime);
    envelope20.release(Decayreleasetime);
    envelope21.decay(Decayreleasetime);
    envelope21.release(Decayreleasetime);
    envelope22.decay(Decayreleasetime);
    envelope22.release(Decayreleasetime);
    envelope23.decay(Decayreleasetime);
    envelope23.release(Decayreleasetime);
    envelope24.decay(Decayreleasetime);
    envelope24.release(Decayreleasetime);
    //// Note ON/OFF ////
    ////// read the touch sensor 1 //////////
    if (readMux(0) > 4500)
    touchstate1 = 1;
    if (readMux(0) <= 4500)
    touchstate1 = 0;
    if (touchstate1 != lasttouchstate1) { // if the keystate has changed
    if (touchstate1 == 1) { // if the button was pressed start noteON
    envelope1.noteOn();
    Serial.println("noteon 1");
    else { // if the button was released
    if (buttonStateHold == HIGH) { // if BOTH the key is release AND the Hold button is depressed, no NoteOff message
    // holdstate1 = 1; // holdstate = 1 if note is held
    Serial.println("noteon 1 Held");
    else // if Hold button is Not pressed note is released
    // holdstate1 = 0; // holdstate = 0 if note is NOT held
    envelope1.noteOff();
    Serial.println("noteoff 1");
    delay(1);
    lasttouchstate1 = touchstate1;
    lastholdstate1 = holdstate1; // if butttonState changes make lastButtonState hold that value
    if (buttonStateRelease == HIGH) { // If release was pressed, send note off
    // holdstate1 = 0;
    Serial.println("release");
    else {
    //Serial.println("Nothing");
    ///////////////////////////////////////// read the touch sensor 2 /////////////
    if (readMux(1) > 4500)
    touchstate2 = 1;
    if (readMux(1) <= 4500)
    touchstate2 = 0;
    if (touchstate2 != lasttouchstate2) { // if the keystate has changed
    if (touchstate2 == 1) { // if the button was pressed start noteON
    envelope2.noteOn();
    Serial.println("noteon 2");
    // holdstate2 = 1; // holdstate2 = 1 if note is held
    Serial.println("noteon 3 Held");
    // holdstate2 = 0; // holdstate = 0 if note is NOT held
    envelope2.noteOff();
    Serial.println("noteoff 2");
    delay(1);
    lasttouchstate2 = touchstate2;
    // lastholdstate2 = holdstate2; // if butttonState changes make lastButtonState hold that value
    // holdstate1 = 0;
    else {
    ////// read the touch sensor 3 //////////
    if (readMux(2) > 4500)
    touchstate3 = 1;
    if (readMux(2) <= 4500)
    touchstate3 = 0;
    if (touchstate3 != lasttouchstate3) {
    if (touchstate3 == 1) { // if the key was pressed, start noteON
    envelope3.noteOn();
    Serial.println("noteon 3");
    else { // if the key was released:
    if (buttonStateHold == HIGH) { // if BOTH the key is release AND the Hold button is depressed, NO NoteOff message
    else // if Hold button is Not pressed, note is released
    envelope3.noteOff();
    Serial.println("noteoff 3");
    delay(1);
    lasttouchstate3 = touchstate3;
    else {
    ///////////////////////////////////////// read the touch sensor 4 /////////////
    if (readMux(3) > 4500)
    touchstate4 = 1;
    if (readMux(3) <= 4500)
    touchstate4 = 0;
    if (touchstate4 != lasttouchstate4) {
    if (touchstate4 == 1) { // if the key was pressed, start noteON
    envelope4.noteOn();
    Serial.println("noteon 4");
    Serial.println("noteon 4 Held");
    envelope4.noteOff();
    Serial.println("noteoff 4");
    delay(1);
    lasttouchstate4 = touchstate4;
    else {
    ////// read the touch sensor 5 //////////
    if (readMux(4) > 4500)
    touchstate5 = 1;
    if (readMux(4) <= 4500)
    touchstate5 = 0;
    if (touchstate5 != lasttouchstate5) {
    if (touchstate5 == 1) { // if the key was pressed, start noteON
    envelope5.noteOn();
    Serial.println("noteon 5");
    Serial.println("noteon 5 Held");
    envelope5.noteOff();
    delay(1);
    lasttouchstate5 = touchstate5;
    else {
    ///////////////////////////////////////// read the touch sensor 6 /////////////
    if (readMux(5) > 4500)
    touchstate6 = 1;
    if (readMux(5) <= 4500)
    touchstate6 = 0;
    if (touchstate6 != lasttouchstate6) {
    if (touchstate6 == 1) {
    envelope6.noteOn();
    Serial.println("noteon 6");
    else {
    Serial.println("noteon 6 Held");
    envelope6.noteOff();
    Serial.println("noteoff 6");
    delay(1);
    lasttouchstate6 = touchstate6;
    else {
    ////// read the touch sensor 7 //////////
    if (readMux(6) > 4500)
    touchstate7 = 1;
    if (readMux(6) <= 4500)
    touchstate7 = 0;
    if (touchstate7 != lasttouchstate7) {
    if (touchstate7 == 1) {
    envelope7.noteOn();
    Serial.println("noteon 7");
    else {
    Serial.println("noteon 7 Held");
    envelope7.noteOff();
    Serial.println("noteoff 7");
    delay(1);
    lasttouchstate7 = touchstate7;
    else {
    ///////////////////////////////////////// read the touch sensor 8 /////////////
    if (readMux(7) > 4500)
    touchstate8 = 1;
    if (readMux(7) <= 4500)
    touchstate8 = 0;
    if (touchstate8 != lasttouchstate8) {
    if (touchstate8 == 1) {
    envelope8.noteOn();
    Serial.println("noteon 8");
    else {
    Serial.println("noteon 8 Held");
    envelope8.noteOff();
    Serial.println("noteoff 8");
    delay(1);
    lasttouchstate8 = touchstate8;
    else {
    //////////// read the touch sensor 9 ///////////////////////////////////////////////////////
    if (readMux(8) > 4500)
    touchstate9 = 1;
    if (readMux(8) <= 4500)
    touchstate9 = 0;
    if (touchstate9 != lasttouchstate9) {
    if (touchstate9 == 1) {
    envelope9.noteOn();
    Serial.println("noteon 10");
    else {
    Serial.println("noteon 9 Held");
    envelope9.noteOff();
    Serial.println("noteoff 9");
    delay(1);
    lasttouchstate9 = touchstate9;
    else {
    ///////////////////////////////////////// read the touch sensor 10 /////////////
    if (readMux(9) > 4500)
    touchstate10 = 1;
    if (readMux(9) <= 4500)
    touchstate10 = 0;
    if (touchstate10 != lasttouchstate10) {
    if (touchstate10 == 1) {
    envelope10.noteOn();
    else {
    Serial.println("noteon 10 Held");
    envelope10.noteOff();
    Serial.println("noteoff 10");
    delay(1);
    lasttouchstate10 = touchstate10;
    else {
    ////// read the touch sensor 11 ///////////////////////////////////////////////
    if (readMux(10) > 4500)
    touchstate11 = 1;
    if (readMux(10) <= 4500)
    touchstate11 = 0;
    if (touchstate11 != lasttouchstate11) {
    if (touchstate11 == 1) {
    envelope11.noteOn();
    Serial.println("noteon 11");
    else {
    Serial.println("noteon 11 Held");
    envelope11.noteOff();
    Serial.println("noteoff 11");
    delay(1);
    lasttouchstate11 = touchstate11;
    else {
    ///////////////////////////////////////// read the touch sensor 12 /////////////
    if (readMux(11) > 4500)
    touchstate12 = 1;
    if (readMux(11) <= 4500)
    touchstate12 = 0;
    if (touchstate12 != lasttouchstate12) {
    if (touchstate12 == 1) {
    envelope12.noteOn();
    Serial.println("noteon 12");
    else {
    Serial.println("noteon 12 Held");
    envelope12.noteOff();
    Serial.println("noteoff 12");
    delay(1);
    lasttouchstate12 = touchstate12;
    else {
    //////////// read the touch sensor 13 ///////////////////////////////////////////////////////
    if (readMux(12) > 4500)
    touchstate13 = 1;
    if (readMux(12) <= 4500)
    touchstate13 = 0;
    if (touchstate13 != lasttouchstate13) {
    if (touchstate13 == 1) {
    envelope13.noteOn();
    Serial.println("noteon 13");
    else {
    Serial.println("noteon 13 Held");
    envelope13.noteOff();
    Serial.println("noteoff 13");
    delay(1);
    lasttouchstate13 = touchstate13;
    else {
    ///////////////////////////////////////// read the touch sensor 14 /////////////
    if (readMux(13) > 4500)
    touchstate14 = 1;
    if (readMux(13) <= 4500)
    touchstate14 = 0;
    if (touchstate14 != lasttouchstate14) {
    if (touchstate14 == 1) {
    envelope14.noteOn();
    Serial.println("noteon 14");
    else {
    Serial.println("noteon 14 Held");
    envelope14.noteOff();
    Serial.println("noteoff 14");
    delay(1);
    lasttouchstate14 = touchstate14;
    else {
    ////// read the touch sensor 15 ///////////////////////////////////////////////
    if (readMux(14) > 4500)
    touchstate15 = 1;
    if (readMux(14) <= 4500)
    touchstate15 = 0;
    if (touchstate15 != lasttouchstate15) {
    if (touchstate15 == 1) {
    envelope15.noteOn();
    else {
    Serial.println("noteon 15 Held");
    envelope15.noteOff();
    Serial.println("noteoff 15");
    delay(1);
    lasttouchstate15 = touchstate15;
    else {
    ///////////////////////////////////////// read the touch sensor 16 /////////////
    if (readMux(15) > 4500)
    touchstate16 = 1;
    if (readMux(15) <= 4500)
    touchstate16 = 0;
    if (touchstate16 != lasttouchstate16) {
    if (touchstate16 == 1) {
    envelope16.noteOn();
    Serial.println("noteon 16");
    else {
    Serial.println("noteon 16 Held");
    envelope16.noteOff();
    Serial.println("noteoff 16");
    delay(1);
    lasttouchstate16 = touchstate16;
    else {
    //////////// read the touch sensor 17 ///////////////////////////////////////////////////////
    if (readMux3(0) > 4500)
    touchstate17 = 1;
    if (readMux3(0) <= 4500)
    touchstate17 = 0;
    if (touchstate17 != lasttouchstate17) {
    if (touchstate17 == 1) {
    envelope17.noteOn();
    Serial.println("noteon 17");
    else {
    Serial.println("noteon 17 Held");
    envelope17.noteOff();
    Serial.println("noteoff 17");
    delay(1);
    lasttouchstate17 = touchstate17;
    else {
    ///////////////////////////////////////// read the touch sensor 18 /////////////
    if (readMux3(1) > 4500)
    touchstate18 = 1;
    if (readMux3(1) <= 4500)
    touchstate18 = 0;
    if (touchstate18 != lasttouchstate18) {
    if (touchstate18 == 1) {
    envelope18.noteOn();
    Serial.println("noteon 18");
    else {
    Serial.println("noteon 18 Held");
    envelope18.noteOff();
    Serial.println("noteoff 18");
    delay(1);
    lasttouchstate18 = touchstate18;
    else {
    ////// read the touch sensor 19 ///////////////////////////////////////////////
    if (readMux3(2) > 4500)
    touchstate19 = 1;
    if (readMux3(2) <= 4500)
    touchstate19 = 0;
    if (touchstate19 != lasttouchstate19) {
    if (touchstate19 == 1) {
    envelope19.noteOn();
    Serial.println("noteon 19");
    else {
    Serial.println("noteon 19 Held");
    envelope19.noteOff();
    Serial.println("noteoff 19");
    delay(1);
    lasttouchstate19 = touchstate19;
    else {
    ///////////////////////////////////////// read the touch sensor 20 /////////////
    if (readMux3(3) > 4500)
    touchstate20 = 1;
    if (readMux3(3) <= 4500)
    touchstate20 = 0;
    if (touchstate20 != lasttouchstate20) {
    if (touchstate20 == 1) {
    envelope20.noteOn();
    Serial.println("noteon 20");
    else {
    Serial.println("noteon 20 Held");
    envelope20.noteOff();
    Serial.println("noteoff 20");
    delay(1);
    lasttouchstate20 = touchstate20;
    else {
    //////////// read the touch sensor 21 ///////////////////////////////////////////////////////
    if (readMux3(4) > 4500)
    touchstate21 = 1;
    if (readMux3(4) <= 4500)
    touchstate21 = 0;
    if (touchstate21 != lasttouchstate21) {
    if (touchstate21 == 1) {
    envelope21.noteOn();
    Serial.println("noteon 21");
    else {
    Serial.println("noteon 21 Held");
    envelope21.noteOff();
    Serial.println("noteoff 21");
    delay(1);
    lasttouchstate21 = touchstate21;
    else {
    ///////////////////////////////////////// read the touch sensor 22 /////////////
    if (readMux3(5) > 4500)
    touchstate22 = 1;
    if (readMux3(5) <= 4500)
    touchstate22 = 0;
    if (touchstate22 != lasttouchstate22) {
    if (touchstate22 == 1) {
    envelope22.noteOn();
    Serial.println("noteon 22");
    else {
    Serial.println("noteon 22 Held");
    envelope22.noteOff();
    Serial.println("noteoff 22");
    delay(1);
    lasttouchstate22 = touchstate22;
    else {
    ////// read the touch sensor 23 ///////////////////////////////////////////////
    if (readMux3(6) > 4500)
    touchstate23 = 1;
    if (readMux3(6) <= 4500)
    touchstate23 = 0;
    if (touchstate23 != lasttouchstate23) {
    if (touchstate23 == 1) {
    envelope23.noteOn();
    Serial.println("noteon 23");
    else {
    Serial.println("noteon 23 Held");
    envelope23.noteOff();
    Serial.println("noteoff 23");
    delay(1);
    lasttouchstate23 = touchstate23;
    else {
    ///////////////////////////////////////// read the touch sensor 24 /////////////
    if (readMux3(7) > 4500)
    touchstate24 = 1;
    if (readMux3(7) <= 4500)
    touchstate24 = 0;
    if (touchstate24 != lasttouchstate24) {
    if (touchstate24 == 1) {
    envelope24.noteOn();
    Serial.println("noteon 24");
    else {
    Serial.println("noteon 24 Held");
    envelope24.noteOff();
    Serial.println("noteoff 24");
    delay(1);
    lasttouchstate24 = touchstate24;
    else {
    ////////// LFO //////////
    /////////////////////////////////////////////// 2nd AVERAGE // to smooth vibrato depth
    // subtract the last reading:
    total2 = total2 - readings2[readIndex2];
    // read from the sensor:
    readings2[readIndex2] = readMux2(2);
    // add the reading to the total:
    total2 = total2 + readings2[readIndex2];
    // advance to the next position in the array:
    readIndex2 = readIndex2 + 1;
    // if we're at the end of the array...
    if (readIndex2 >= numReadings2) {
    // ...wrap around to the beginning:
    readIndex2 = 0;
    // calculate the average :
    average2 = total2 / numReadings2;
    float LFORate = fscale( 0, 1023, 0.08, 65.406, (float)readMux2(1), fscalefactor1); // Scale the vibrato rate
    float LFODepth = fscale(0, 1023, 0, 0.6, average2, fscalefactor2); // Scale the vibrato depth
    float cutoff = fscale(0, 1023, 70, 13900, average, fscalefactor3); // Scale the filter cutoff freq
    float FilterLFOintensity = fscale( 0, 1023, 0, 0.9, average2, fscalefactor4); // Scale the filter LFO intensity
    waveform1.frequency(LFORate); // Pitch LFO //
    waveform1.amplitude(LFODepth);
    waveformMod13.frequency(LFORate); // Filter LFO //
    amp13.gain(FilterLFOintensity);
    // Serial.println(LFODepth);
    /////////// Filter /////////////
    float FilterRes = fscale( 0, 1023, FilterResMin, 5, readMux2(5), fscalefactor5); // Scale the filter resonance
    filter1.resonance(FilterRes); // Filter Resonance
    // Serial.print(" Filter Resonance = ");
    // Serial.println(FilterRes);
    /////////// Smooth values for filter ///////////
    total = total - readings[readIndex];
    readings[readIndex] = readMux2(6);
    total = total + readings[readIndex];
    readIndex = readIndex + 1;
    if (readIndex >= numReadings) {
    readIndex = 0;
    // calculate the average:
    average = total / numReadings;
    // send it to the computer as ASCII digits
    //Serial.println(average);
    //delay(1); // delay in between reads for stability
    // use the average to change the filter frequency
    // int knob = average;
    filter1.frequency(cutoff);
    //Serial.print("frequency = ");
    // Serial.println(cutoff);
    // delay(1);
    /////////////////////////////////////////////// 3rd AVERAGE // to smooth tuning knob
    total3 = total3 - readings3[readIndex3];
    readings3[readIndex3] = readMux2(0);
    total3 = total3 + readings3[readIndex3];
    readIndex3 = readIndex3 + 1;
    if (readIndex3 >= numReadings3) {
    readIndex3 = 0;
    average3 = total3 / numReadings3;
    // Serial.print(average3);
    // delay(100);
    // Serial.print("\t Tune = ");
    // Serial.print(readMux2(9));
    // Serial.print("\t LFODepth = ");
    // Serial.println(readMux2(2));
    // Serial.print("\t Cutoff = ");
    // Serial.println(readMux2(7));
    // delay(1);
    //////// Multiplexer /////////////
    int readMux(int channel){
    int controlPin[] = {s0, s1, s2, s3};
    int muxChannel[16][4]={
    {0,0,0,0}, //channel 0
    {1,0,0,0}, //channel 1
    {0,1,0,0}, //channel 2
    {1,1,0,0}, //channel 3
    {0,0,1,0}, //channel 4
    {1,0,1,0}, //channel 5
    {0,1,1,0}, //channel 6
    {1,1,1,0}, //channel 7
    {0,0,0,1}, //channel 8
    {1,0,0,1}, //channel 9
    {0,1,0,1}, //channel 10
    {1,1,0,1}, //channel 11
    {0,0,1,1}, //channel 12
    {1,0,1,1}, //channel 13
    {0,1,1,1}, //channel 14
    {1,1,1,1} //channel 15
    //loop through the 4 sig
    for(int i = 0; i < 4; i ++){
    digitalWrite(controlPin[i], muxChannel[channel][i]);
    //Serial.println(readMux(1));
    //read the value at the SIG pin
    int val = touchRead(SIG_pin);
    //return the value
    return val;
    //////////////////////////////////////////////////// MUX 2
    int readMux2(int channel2){
    int controlPin2[] = {s0, s1, s2, s3};
    int muxChannel2[16][4]={
    digitalWrite(controlPin2[i], muxChannel2[channel2][i]);
    int val2 = analogRead(SIG_pin2);
    //return the value
    return val2;
    ////////////////////////////////////////// MUX 3
    int readMux3(int channel3){
    int controlPin3[] = {s0, s1, s2, s3};
    int muxChannel3[16][4]={
    digitalWrite(controlPin3[i], muxChannel3[channel3][i]);
    int val3 = touchRead(SIG_pin3);
    //return the value
    return val3;
    // The rest below is the "fscale" code: ///
    float fscale( float originalMin, float originalMax, float newBegin, float
    newEnd, float inputValue, float curve){
    float OriginalRange = 0;
    float NewRange = 0;
    float zeroRefCurVal = 0;
    float normalizedCurVal = 0;
    float rangedValue = 0;
    boolean invFlag = 0;
    // condition curve parameter
    // limit range
    if (curve > 10) curve = 10;
    if (curve < -10) curve = -10;
    curve = (curve * -.1) ; // - invert and scale - this seems more intuitive - postive numbers give more weight to high end on output
    curve = pow(10, curve); // convert linear scale into lograthimic exponent for other pow function
    // Check for out of range inputValues
    if (inputValue < originalMin) {
    inputValue = originalMin;
    if (inputValue > originalMax) {
    inputValue = originalMax;
    // Zero Refference the values
    OriginalRange = originalMax - originalMin;
    if (newEnd > newBegin){
    NewRange = newEnd - newBegin;
    NewRange = newBegin - newEnd;
    invFlag = 1;
    zeroRefCurVal = inputValue - originalMin;
    normalizedCurVal = zeroRefCurVal / OriginalRange; // normalize to 0 - 1 float
    // Check for originalMin > originalMax - the math for all other cases i.e. negative numbers seems to work out fine
    if (originalMin > originalMax ) {
    return 0;
    if (invFlag == 0){
    rangedValue = (pow(normalizedCurVal, curve) * NewRange) + newBegin;
    else // invert the ranges
    rangedValue = newBegin - (pow(normalizedCurVal, curve) * NewRange);
    return rangedValue;
    Aug 2015
    Scotland
    152
    hi
    I just had a quick look at your sketch, think it will need more memory allocated - try increasing the AudioMemory()
    Have a look here at AudioMemoryUsageMax() which you can use to print out the max. usage
    cheers, Paul
    May 2018
    3
    Thank you so much Paul! That was it! I added more memory and now it's working fine.
    Cheers,
    Henry
