Results 1 to 6 of 6
Thread: Teensy 3.2 with AD7606
    Oct 2020
    4
    I have a problem with my little project
    In a small analog to CAN interface , I use a AD7606 with a arduino mega.
    Now I want to update to a teensy for some more processing capacity and of course the onboard CAN .
    The problem is , I can not get the AD7606 to run on my Teensy
    I tried with a 2nd one but also not running.
    I have the feeling it is a SPI problem.
    I use the following sketch to test :
    #define SCALE_FACTOR 0.000152587890625
    // 10/(2^16) = 0.000152587890625
    #define BUSY 3
    #define RESET 4
    #define START_CONVERSION 5
    #define CHIP_SELECT 10
    #define MISO 12
    #define LED 13
    #define TOTAL_RAW_BYTES 16
    int bytesToRead = TOTAL_RAW_BYTES;
    byte raw[TOTAL_RAW_BYTES];
    signed long parsed[8];
      pinMode(BUSY, INPUT);
      pinMode(RESET, OUTPUT);
      pinMode(LED, OUTPUT);
      pinMode(START_CONVERSION, OUTPUT);
      pinMode(MISO, INPUT);
      SPI.begin();
      digitalWrite(START_CONVERSION, HIGH);
      digitalWrite(CHIP_SELECT, HIGH);
      digitalWrite(RESET, HIGH);
      delay(1);
      digitalWrite(RESET, LOW);
      int i;
      digitalWrite(START_CONVERSION, LOW);
      delayMicroseconds(10);
      while (digitalRead(BUSY) == HIGH) {
        // wait for conversion to complete
      digitalWrite(CHIP_SELECT, LOW);
      while (bytesToRead > 0) {
        raw[TOTAL_RAW_BYTES - bytesToRead] = SPI.transfer(0x00);
        bytesToRead--;
      parseRawBytes();
      //Serial.write(raw, 16);
      for(i=0; i<8; i++) {
        Serial.print((float)parsed[i] * SCALE_FACTOR, 5);
        Serial.print(",");
      Serial.print("\r\n");
    void parseRawBytes() {
      parsed[0] = (raw[0] << 8) + raw[1];
      parsed[1] = (raw[2] << 8) + raw[3];
      parsed[2] = (raw[4] << 8) + raw[5];
      parsed[3] = (raw[6] << 8) + raw[7];
      parsed[4] = (raw[8] << 8) + raw[9];
      parsed[5] = (raw[10] << 8) + raw[11];
      parsed[6] = (raw[12] << 8) + raw[13];
      parsed[7] = (raw[14] << 8) + raw[15];
    I suppose I,m doing something wrong for a teensy ?
    the same AD7606 and sketch is working with arduino Mega so I,m very certain the wiring is correct (SPI).
    I had a pullup resistor over the Cs pin 10 .
    The SPI seems to work as I have tested with a Max31855 on the SPI bus.
    Regards Klass
    May 2015
    USA
    836
    This is a different ADC, but the AD7689_read_array() below should be helpful as a model.
    https://gitlab.com/our-sci/reflectan...src/AD7689.cpp
    Oct 2020
    4
    That code has SPI transactions implemented,
    Tried that in my code above but it made no difference (it has only the AD7606 on the SPI so no noise from others)
    the code above works on Arduino Mega (but very slow) but I thougt the code itself was more or less ok ?
    Oct 2020
    4
    studying that AD7689 now , the complete conversion protocol is a bit different as it uses no busy ?
    Feb 2018
    Corvallis, OR
    286
    Is it possible that the T3.2 and the Arduino Mega have different default settings for SPI clock phase and polarity?
    Oct 2020
    4
    I have this code working now, thanks for all the help.
       Teensy 3.2  AD7606 SPI
    uint32_t start, stop;
    #define BUSY 3
    #define RESET 4
    #define MISO 12
    #define MOSI 11
    #define LED 13
    SPISettings _spiSettings;
    uint16_t parsed[8];
    int x = 0;
      pinMode(CHIP_SELECT, OUTPUT);
      SPI.begin();
      start = micros();
      int i;
      delayMicroseconds(100);
        delayMicroseconds(1);
      SPI.beginTransaction(_spiSettings);
        bytesToRead--;
      SPI.endTransaction();
      parseRawBytes();
      for (int i = 0; i < 8; i++) {
        Serial.print(",");
      stop = micros();
      Serial.print("time:\t\t");
      Serial.println(stop - start);
