Results 1 to 1 of 1
Thread: How to assign sensors to I2C buses T4.1? :confused:
    Oct 2020
    10
    Sensors not found through Multiplexer on T4.1?
    Hi All, and thanks for the help so far!
    I'm trying to connect two MPU6050s to a T4.1 via i2c and the Adafruit TCA9548A. I am able to use a modified i2c scanner and see the sensors, but when I use the following sketch it fails to connect to the sensors. I've meticulously checked the wiring so I don't think that's it (but I've included a fritzing just in case). I'm also including the i2c scanner I used that was able to detect the sensors.
    Thank you for any help!!!
    Sketch that is not working:
    #include "MPU6050.h"
    #define TCAADDR 0x70
    MPU6050 mpu1;
    MPU6050 mpu2;
    int16_t ax, ay, az;
    int16_t gx, gy, gz;
    void tcaselect(uint8_t i) {
      if (i > 7) return;
      Wire.beginTransmission(TCAADDR);
      Wire.write(1 << i);
      Wire.endTransmission();
    void setup(void)
      Serial.begin(38400);
      Serial.println("2 MPU 6050s on multiplexer Test"); Serial.println("");
      Serial.println("Initializing I2C devices...");
      /* Initialise the sensors */
      tcaselect(2);
      mpu1.initialize();
      Serial.println(mpu1.testConnection() ? "MPU1 connection successful" : "MPU1 connection failed"); // returns connection failed
      tcaselect(6);
      mpu2.initialize();
      Serial.println(mpu2.testConnection() ? "MPU2 connection successful" : "MPU2 connection failed"); // returns connection failed
      Serial.println("");
      delay(3000);
    void loop(void)
      tcaselect(2);
      mpu1.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
      Serial.print("Sensor 1 accel:\t");
      Serial.print(ax); Serial.print("\t");
      Serial.print(ay); Serial.print("\t");
      Serial.print(az); Serial.print("\t");
      Serial.print(gx); Serial.print("\t");
      Serial.print(gy); Serial.print("\t");
      Serial.println(gz);
      tcaselect(6);
      mpu2.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
      Serial.print("Sensor 2 accel:\t");
      Serial.println(gz);
    Modified i2c scanner:
     * TCA9548 I2CScanner.pde -- I2C bus scanner for Arduino
     * Based on code c. 2009, Tod E. Kurt, http://todbot.com/blog/
    #include "Wire.h"
    extern "C"
    uint8_t twi_writeTo(uint8_t address, uint8_t* data, uint8_t length, uint8_t wait, uint8_t sendStop)
            if (!wait) return 4;
            Wire.beginTransmission(address);
            while (length) {
                    Wire.write(*data++);
                    length--;
            return Wire.endTransmission(sendStop);
      if (i > 7) return;
      Wire.write(1 << i);
    // standard Arduino setup()
        while (!Serial);
        Wire.begin();
        Serial.println("\nTCAScanner ready!");
        for (uint8_t t=0; t<8; t++) {
          tcaselect(t);
          Serial.print("TCA Port #"); Serial.println(t);
          for (uint8_t addr = 0; addr<=127; addr++) {
            if (addr == TCAADDR) continue;
            uint8_t data;
            if (! twi_writeTo(addr, &data, 0, 1, 1)) {
               Serial.print("Found I2C 0x");  Serial.println(addr,HEX);
        Serial.println("\ndone");
