Results 1 to 2 of 2
Thread: rawHID for teensy 4.0 Compling c files for Matlab
    Oct 2020
    1
    Hi
    I am new to this so please accept my apologies if my questions are naive. Basically what I want to do it to complete your c codes with MATLAB and make mex function that I can use in my Matlab scripts and transfer data between Teensy 4 and the computer. I used serial before but that requires specifying the serial port.
    What I did, I downloaded your c source files from https://www.pjrc.com/teensy/rawhid.html and tried to compile them in Matlab with mex ('hid_WINDOWS.c') command. (I selected MinGW64 Compiler (C) ) . I receive the following error:
    fatal error: ddk/hidsdi.h: No such file or
    directory
    #include <ddk/hidsdi.h>
    compilation terminated.
    it looks those files are not included in the newer versions of the MinGW compiler. I found a solution to change those including to the followings:
    #include <hidsdi.h>
    #include <hidpi.h>
    however, when I am trying to compile I get this error:
    Building with 'MinGW64 Compiler (C)'.
    Error using mex
    Cannot export mexFunction: symbol not defined
    C:\Users\AppData\Local\Temp\mex_2019355346950168_6 584\hid_WINDOWS.obj:hid_WINDOWS.c:(.text+0xbe):
    undefined reference to `HidD_GetHidGuid'
    C:\Users\AppData\Local\Temp\mex_2019355346950168_6 584\hid_WINDOWS.obj:hid_WINDOWS.c:(.text+0xd2):
    undefined reference to `__imp_SetupDiGetClassDevsA'
    C:\Users\AppData\Local\Temp\mex_2019355346950168_6 584\hid_WINDOWS.obj:hid_WINDOWS.c:(.text+0xfe):
    undefined reference to `__imp_SetupDiGetDeviceInterfaceDetailA'
    C:\Users\AppData\Local\Temp\mex_2019355346950168_6 584\hid_WINDOWS.obj:hid_WINDOWS.c:(.text+0x135):
    undefined reference to `__imp_SetupDiEnumDeviceInterfaces'
    C:\Users\AppData\Local\Temp\mex_2019355346950168_6 584\hid_WINDOWS.obj:hid_WINDOWS.c:(.text+0x1fa):
    undefined reference to `HidD_GetAttributes'
    C:\Users\AppData\Local\Temp\mex_2019355346950168_6 584\hid_WINDOWS.obj:hid_WINDOWS.c:(.text+0x24e):
    undefined reference to `HidD_GetPreparsedData'
    C:\Users\AppData\Local\Temp\mex_2019355346950168_6 584\hid_WINDOWS.obj:hid_WINDOWS.c:(.text+0x25f):
    undefined reference to `HidP_GetCaps'
    C:\Users\AppData\Local\Temp\mex_2019355346950168_6 584\hid_WINDOWS.obj:hid_WINDOWS.c:(.text+0x28a):
    undefined reference to `HidD_FreePreparsedData'
    C:\Users\AppData\Local\Temp\mex_2019355346950168_6 584\hid_WINDOWS.obj:hid_WINDOWS.c:(.text+0x334):
    I am kinda lost. basically, I want to convert these c functions into Matlab functions and use them in my code, but I am not sure, where should I start.
    I would greatly appreciate any hint and help.
    Thank you,
    David
    2,997
    I would start with https://github.com/libusb/hidapi
    and first try to get a standalone program working and then generate a mex file
