SD card datalogger
This example shows how to log data from three analog sensors
to an SD card using the SD library.
The circuit:
* analog sensors on analog ins 0, 1, and 2
* SD card attached to SPI bus as follows:
** MOSI - pin 11, pin 7 on Teensy with audio board
** MISO - pin 12
** CLK - pin 13, pin 14 on Teensy with audio board
** CS - pin 4, pin 10 on Teensy with audio board
created 24 Nov 2010
modified 9 Apr 2012
by Tom Igoe
// #include <SPI.h>
// On the Ethernet Shield, CS is pin 4. Note that even if it's not
// used as the CS pin, the hardware CS pin (10 on most Arduino boards,
// 53 on the Mega) must be left as an output or the SD library
// functions will not work.
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
// Teensy audio board: pin 10
// Teensy 3.5 & 3.6 & 4.1 on-board: BUILTIN_SDCARD
// Wiz820+SD board: pin 4
// Teensy 2.0: pin 0
// Teensy++ 2.0: pin 20
const int chipSelect = 4,
justTest = FILE_WRITE_BEGIN; // Will not compile.
//UNCOMMENT THESE TWO LINES FOR TEENSY AUDIO BOARD:
//SPI.setMOSI(7); // Audio shield has MOSI on pin 7
//SPI.setSCK(14); // Audio shield has SCK on pin 14
while (!Serial) {
; // wait for serial port to connect.
Serial.print("Initializing SD card...");
// see if the card is present and can be initialized:
if (!SD.begin(BUILTIN_SDCARD)) {
Serial.println("Card failed, or not present");
while (1) {
// No SD card, so don't do anything more - stay stuck here
Serial.println("card initialized.");
// make a string for assembling the data to log:
String dataString = "";
// read three sensors and append to the string:
for (int analogPin = 0; analogPin < 3; analogPin++) {
int sensor = analogRead(analogPin);
dataString += String(sensor);
if (analogPin < 2) {
dataString += ",";
// open the file.
File dataFile = SD.open("datalog.txt", FILE_WRITE);
// if the file is available, write to it:
if (dataFile) {
dataFile.println(dataString);
dataFile.close();
// print to the serial port too:
Serial.println(dataString);
// if the file isn't open, pop up an error:
Serial.println("error opening datalog.txt");
delay(100); // run at a reasonable not-too-fast speed
