Results 1 to 6 of 6
Thread: Connect read from each i2c bus T4.1
    Oct 2020
    10
    Hi All,
    I'm wiring three MPU6050s to a Teensy 4.1. Because they all have the same address 0x68, I'm using the three i2c buses on the T4.1. I am able to set up Wire, Wire1 and Wire2 and scan for the sensors on an i2c scanner, however, when I try to read data from the sensors I only get data from the first one. I suspect that I'm not correctly assigning the sensors to the wire or calling the wire even though I've tried everything that I can think of. I've tried this with a multiplexer as well, but have not been able to get it to work with a similar problem. I'd really appreciate any help!
    I've included the sketch below along with some comments and arrows pointing to likely trouble spots.
    #include "I2Cdev.h"
    #include "MPU6050.h"
    #include "Wire.h"
    MPU6050 accelgyro1; // <-------------- how do I associate these with a specific instance of Wire or set a unique sensor ID?
    MPU6050 accelgyro2;
    MPU6050 accelgyro3;
    int16_t ax, ay, az;
    int16_t gx, gy, gz;
      Wire.setSCL(19);  // SCL on first i2c bus on T4.1
      Wire.setSDA(18);  // SDA on first i2c bus on T4.1
      Wire1.setSCL(16); // SCL1 on second i2c bus on T4.1
      Wire1.setSDA(17); // SDA1 on second i2c bus on T4.1
      Wire2.setSCL(24); // SCL2 on second i2c bus on T4.1
      Wire2.setSDA(25); // SDA2 on second i2c bus on T4.1
      Wire.begin();
      Wire1.begin();
      Wire2.begin();
      Serial.println("Initializing I2C device 1...");
      accelgyro1.initialize();
      Serial.println("Testing device 1...");
      Serial.println(accelgyro1.testConnection() ? "MPU6050 1 connection successful" : "MPU6050 1 connection failed"); // <---- this works, if I unplug a sensor the correct one fails
      delay(3000);
      Serial.println("Initializing I2C device...");
      accelgyro2.initialize();
      Serial.println("Testing device 2...");  // <------------------------ for some reason it skips this and the next line
      Serial.println(accelgyro2.testConnection() ? "MPU6050 2 connection successful" : "MPU6050 2 connection failed");
      delay(3000);
      Serial.println("Initializing I2C device 3...");
      accelgyro3.initialize();
      Serial.println("Testing device 3...");
      Serial.println(accelgyro3.testConnection() ? "MPU6050 3 connection successful" : "MPU6050 3 connection failed");
      delay(3000);
      Serial.println("............................................");
        // i2c on first bus starts here
        accelgyro1.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
        Serial.print("MPU_1 a/g:\t");
        Serial.print(ax); Serial.print("\t");
        Serial.print(ay); Serial.print("\t");
        Serial.print(az); Serial.print("\t");
        Serial.print(gx); Serial.print("\t");
        Serial.print(gy); Serial.print("\t");
        Serial.println(gz);
        // i2c on second bus starts here
        accelgyro2.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
        Serial.print("MPU_2 a/g:\t");
        Serial.println(gz);
        // i2c on third bus starts here
        accelgyro3.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
        Serial.print("MPU_3 a/g:\t");
        Serial.println(gz);
    In case it's helpful here's the i2c scanner sketch that is able to correctly identify the sensors:
      Wire.begin();
      Wire1.begin();
      Wire2.begin();
      while (!Serial);
      Serial.println("\nI2C Scanner");
      byte error, address;
      int nDevices;
      Serial.println("Scanning...");
      nDevices = 0;
      for (address = 1; address < 127; address++ )
        // The i2c_scanner uses the return value of
        // the Write.endTransmisstion to see if
        // a device did acknowledge to the address.
        Wire.beginTransmission(address); // i2c on first bus starts here
        error = Wire.endTransmission();
        if (error == 0)
          Serial.print("I2C device found at Wire 0x");
          if (address < 16)
            Serial.print("0");
          Serial.print(address, HEX);
          Serial.println("  !");
          nDevices++;
        else if (error == 4)
          Serial.print("Unknown error at Wire 0x");
          if (address < 16)
            Serial.print("0");
          Serial.println(address, HEX);
        } // i2c on first bus ends here
        Wire1.beginTransmission(address); // i2c on second bus starts here
        error = Wire1.endTransmission();
        if (error == 0)
          Serial.print("I2C device found at Wire1 0x");
          if (address < 16)
            Serial.print("0");
          nDevices++;
          Serial.print("Unknown error at Wire1 0x");
          if (address < 16)
            Serial.print("0");
                                       // i2c on second bus ends here
      Wire2.beginTransmission(address); // i2c on third bus starts here
        error = Wire2.endTransmission();
        if (error == 0)
          Serial.print("I2C device found at Wire2 0x");
          if (address < 16)
            Serial.print("0");
          nDevices++;
          Serial.print("Unknown error at Wire2 0x");
          if (address < 16)
            Serial.print("0");
      }                                 // i2c on third bus ends here
      if (nDevices == 0)
        Serial.println("No I2C devices found\n");
        Serial.print("number of devices found = ");
      Serial.println(nDevices);  // this prints the total number of i2c devices found
      Serial.println("done\n");
      delay(2000);           // wait 2 seconds for next scan
    I've also included a fritzing of my wiring
    Thank You!!
    Dec 2015
    LA
    191
    Don't think the MPU6050 library is setup to handle anything but wire.
    Rather than rewrite the library Iv'e delt with this by putting: #define Wire Wire1 into the offending.cpp library and put that library into the projects folder so it gets used. This worked great for 3 different libraries. In your case their all
    the same library so it wouldn't work. You'd have to rename them. Not really the way to do it.
    Adafruit has a MPU6050 library with a proper begin:
    bool Adafruit_MPU6050::begin(uint8_t i2c_address, TwoWire *wire,
    int32_t sensor_id) {
    Oct 2020
    10
    Thanks bicycleguy! BTW I'm a bicycleguy as well!
    I have the adafruit library, they are actually Adafruit MPU6050s, can you give me an example of how I assign the sensors in the sketch?
    I'm guessing this takes place at the mpu1.begin. Looking at the function I see:
    uint8_t i2c_address = 0x68?
    TwoWire *wire = Wire, Wire1, etc.?
    int32_t sensor_id = ??? is this something I need to define earlier? If so I don't know how to assign a unique sensor id.
    Thanks again for the help!
    May 2015
    USA
    817
    You can change the address of one of them by using the AD0 - I2C Address pin.
    Oct 2020
    10
    I'll actually have 4 but didn't make that a point since it won't be an issue with the one with a different address.
    Dec 2015
    LA
    191
    Might be better to change the addresses I don't know.
    Otherwise:
    In your sketch above change something like:
    change MPU6050 to Adafruit_MPU6050 everywhere
    accelgyro1.initialize(); to accelgyro1.begin();
    accelgyro2.initialize(); to accelgyro2.begin(&Wire1);
    accelgyro3.initialize(); to accelgyro2.begin(&Wire2);
