Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 70
Thread: Teensyduino 1.54 Beta #3
    Administrator Paul's Avatar
    Oct 2012
    390
    Here is a third beta test for Teensyduino 1.54.
    Linux 32 bit:
    https://www.pjrc.com/teensy/td_154-b...nstall.linux32
    Linux 64 bit:
    https://www.pjrc.com/teensy/td_154-b...nstall.linux64
    Linux ARM:
    https://www.pjrc.com/teensy/td_154-b...stall.linuxarm
    Linux ARM64:
    (sorry, something is broken on my Jetson TX2....)
    MacOS 10.10 to 10.15:
    https://www.pjrc.com/teensy/td_154-b...S_Catalina.zip
    MacOS 10.8 to 10.14:
    https://www.pjrc.com/teensy/td_154-b...inoInstall.dmg
    Windows:
    https://www.pjrc.com/teensy/td_154-b...inoInstall.exe
    Changes since Teensyduino 1.54-beta2:
    Add File base class and FS.h header
    Add SdFat-beta library
    Replace SD library with wrapper which uses SdFat
    SoftwareSerial improvements on Teensy 3.5, 3.6, 4.1
    Germany
    1,429
    To avoid confusion with users of 3rd party uploaders I want to mention that (in Serial mode) this update changes the usb device from a CDC class on device level to a composite device with a CDC class function (see also https://forum.pjrc.com/threads/63695...l=1#post257339).
    At least the tyTools under Win10 get confused by this change (a issue is already opened). For the tyTools you can work around by using dual or triple serial mode which work as usual. Other 3rd party uploaders / port detection code (e.g. TeensySharp) might also be affected.
    13,747
    Win 10 :: Installing TD 1.54b3 over current install left SRC files etc in the SD folder >> T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\SD\
    Manually deleted CORES and LIBRARIES and reinstalled and it looks right now.
    13,747
    Looking to get ILI9341 and Audio card SD on SPI tested with new SD library:
    Building Sketch: ".\Part_3_03_TFT_Display.ino"
    Using board 'teensy31' from platform in folder: T:\arduino-1.8.13_t54\hardware\teensy\avr
    Using core 'teensy3' from platform in folder: T:\arduino-1.8.13_t54\hardware\teensy\avr
    First result is this:
    "-IT:\\arduino-1.8.13_t54\\hardware\\teensy\\avr\\libraries\\SPI" "T:\\TEMP\\arduino_build_Part_3_03_TFT_Display.ino\\sketch\\Part_3_03_TFT_Display.ino.cpp" -o "T:\\TEMP\\arduino_build_Part_3_03_TFT_Display.ino\\sketch\\Part_3_03_TFT_Display.ino.cpp.o"
    T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\Audio\examples\Tutorial\Part_3_03_TFT_Display\Part_3_03_TFT_Display.ino: In function 'void setup()':
    T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\Audio\examples\Tutorial\Part_3_03_TFT_Display\Part_3_03_TFT_Display.ino:70:17: error: 'AudioMemory' was not declared in this scope
       AudioMemory(10);
    T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\Audio\examples\Tutorial\Part_3_03_TFT_Display\Part_3_03_TFT_Display.ino:71:3: error: 'sgtl5000_1' was not declared in this scope
       sgtl5000_1.enable();
    T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\Audio\examples\Tutorial\Part_3_03_TFT_Display\Part_3_03_TFT_Display.ino:75:9: error: 'SD' was not declared in this scope
    T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\Audio\examples\Tutorial\Part_3_03_TFT_Display\Part_3_03_TFT_Display.ino: In function 'void loop()':
    T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\Audio\examples\Tutorial\Part_3_03_TFT_Display\Part_3_03_TFT_Display.ino:87:7: error: 'playSdWav1' was not declared in this scope
       if (playSdWav1.isPlaying() == false) {
    T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\Audio\examples\Tutorial\Part_3_03_TFT_Display\Part_3_03_TFT_Display.ino:97:9: error: 'peak1' was not declared in this scope
         if (peak1.available() && peak2.available()) {
    T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\Audio\examples\Tutorial\Part_3_03_TFT_Display\Part_3_03_TFT_Display.ino:97:30: error: 'peak2' was not declared in this scope
    Using library ILI9341_t3 at version 1.0 in folder: T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\ILI9341_t3
    Using library SPI at version 1.0 in folder: T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\SPI
    exit status 1
    [Finished in 3.5s]
    23,989
    Arduino is supposed to ignore the old files in the library directory if a "src" folder is present. It's supposed to only use the stuff in "src". Did it get confused? Or is this just cleanup so the folder look nice?
    3,120
    Found that too, deleted SD and re-installed TD1.54b3
    13,747
    Just to look nice ??? - not knowing 'that rule' - assumed the old stuff would have been cleaned away.
    13,747
    Opened IDE instead of 'editor' building in IDE gives same errors - note above the added Audio Tools lines copied were still /* commented out */
    Src file of sketch :: T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\Audio\exa mples\Tutorial\Part_3_03_TFT_Display\Part_3_03_TFT _Display.ino
    Compiling sketch...
    "T:\\arduino-1.8.13_t54\\hardware\\teensy/../tools/precompile_helper" "T:\\arduino-1.8.13_t54\\hardware\\teensy\\avr/cores/teensy3" "T:\\TEMP\\arduino_build_314540" "T:\\arduino-1.8.13_t54\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IT:\\arduino-1.8.13_t54\\hardware\\teensy\\avr/cores/teensy3" "T:\\TEMP\\arduino_build_314540/pch/Arduino.h" -o "T:\\TEMP\\arduino_build_314540/pch/Arduino.h.gch"
    "T:\\arduino-1.8.13_t54\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=154 -DARDUINO=10813 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IT:\\TEMP\\arduino_build_314540/pch" "-IT:\\arduino-1.8.13_t54\\hardware\\teensy\\avr\\cores\\teensy3" "-IT:\\arduino-1.8.13_t54\\hardware\\teensy\\avr\\libraries\\ILI9341_t3" "-IT:\\arduino-1.8.13_t54\\hardware\\teensy\\avr\\libraries\\SPI" "T:\\TEMP\\arduino_build_314540\\sketch\\Part_3_03_TFT_Display.ino.cpp" -o "T:\\TEMP\\arduino_build_314540\\sketch\\Part_3_03_TFT_Display.ino.cpp.o"
    Part_3_03_TFT_Display:19: error: 'AudioPlaySdWav' does not name a type
     AudioPlaySdWav           playSdWav1;     //xy=136,65
    Part_3_03_TFT_Display:20: error: 'AudioAnalyzePeak' does not name a type
     AudioAnalyzePeak         peak2;          //xy=348,219
    Part_3_03_TFT_Display:21: error: 'AudioAnalyzePeak' does not name a type
     AudioAnalyzePeak         peak1;          //xy=358,171
    Part_3_03_TFT_Display:22: error: 'AudioOutputI2S' does not name a type
     AudioOutputI2S           i2s1;           //xy=380,92
    Part_3_03_TFT_Display:23: error: 'AudioConnection' does not name a type
     AudioConnection          patchCord1(playSdWav1, 0, i2s1, 0);
    Part_3_03_TFT_Display:24: error: 'AudioConnection' does not name a type
     AudioConnection          patchCord2(playSdWav1, 0, peak1, 0);
    Part_3_03_TFT_Display:25: error: 'AudioConnection' does not name a type
     AudioConnection          patchCord3(playSdWav1, 1, i2s1, 1);
    Part_3_03_TFT_Display:26: error: 'AudioConnection' does not name a type
     AudioConnection          patchCord4(playSdWav1, 1, peak2, 0);
    Part_3_03_TFT_Display:27: error: 'AudioControlSGTL5000' does not name a type
     AudioControlSGTL5000     sgtl5000_1;     //xy=155,192
    Part_3_03_TFT_Display: In function 'void setup()':
    Part_3_03_TFT_Display:68: error: 'AudioMemory' was not declared in this scope
       AudioMemory(10);
    Part_3_03_TFT_Display:69: error: 'sgtl5000_1' was not declared in this scope
    Part_3_03_TFT_Display:73: error: 'SD' was not declared in this scope
    Part_3_03_TFT_Display: In function 'void loop()':
    Part_3_03_TFT_Display:85: error: 'playSdWav1' was not declared in this scope
    Part_3_03_TFT_Display:95: error: 'peak1' was not declared in this scope
    Part_3_03_TFT_Display:95: error: 'peak2' was not declared in this scope
    3,120
    its not only src/ but also utility/ where another SdFat.h is located
    23,989
       AudioMemory(10);
    Did you draw the diagram the audio tutorial PDF shows on page 22 and export it to Arduino? (as the 4 steps on page 22 say to do)
    Or if you want to just copy the code, click File > Examples > Audio > Tutorial > Reference to get all the Design Tool generated code for every part of the tutorial.
    Just know those examples under Audio > Tutorial aren't complete ready-to-run programs. They're the code which supports very specific steps described in the tutorial PDF. You have to actually do those tutorial steps to run those programs.
    13,747
    Just know those examples under Audio > Tutorial aren't complete ready-to-run programs. They're the code which supports very specific steps described in the tutorial PDF. You have to actually do those tutorial steps to make then run.
    Audio code was copied from the :: T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\Audio\exa mples\Tutorial\Reference\Reference.ino
    Opps - did not copy ::
    Getting Closer - it is choosing the adafruit sdFat-Beta in libraries now:
    Multiple libraries were found for "Audio.h"
     Used: T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\Audio
     Not used: T:\tCode\libraries\Audio_-_Adafruit_Fork
     Used: T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\SD
     Not used: T:\arduino-1.8.13_t54\libraries\SD
    Multiple libraries were found for "SdFat.h"
     Used: T:\tCode\libraries\SdFat_-_Adafruit_Fork
     Not used: T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\SdFat-beta
    <EDIT> :: BUILDING NOW - need to open 64GB uSD card and get the files on it ...
    23,989
    Maybe we should replace the 1 SdCardTest program in Audio > HardwareTesting with a folder and put several ready-to-run test programs in there?
    I'm working now to recreate a test from years ago which played 4 short overlapping sound clips. The old SD library was never able to handle it. Back in the days before Teensy 3.5 & 3.6, I wrote that read-only optimized SD lib which could do it, using a cache that could hold several sectors and SPI.beginTransaction & SPI.endTransaction as a sort of mutex for access to the cache.
    13,747
    RUNNING WELL - T_3.2 :: T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\Audio\examples\Tutorial\Part_3_03_TFT_Display\Part _3_03_TFT_Display.ino
    On >> pjrc.com/store/audio_tutorial_kit.html WITH 'small' ILI9341
    > Sounds play and cycles
    > Peak meter running
    NEW FROM PACKAGE :: 64 GB 'TeamGroup' - factory ExFAT formatted
    generally safe to say :: Examples on disk are best when ready to run ... of course I had to find my copies of the SDTEST#.wav's
    ABOVE at 96 MHz :: Runs just as well COMPILED at 24 MHz
    For SIZE ref - ( using DUAL SERIAL so I can use TyCommander from my SublimeText Editor )::
    "T:\\arduino-1.8.13_t54\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-size" -A "T:\\TEMP\\arduino_build_Part_3_03_TFT_Display.ino/Part_3_03_TFT_Display.ino.elf"
    Sketch uses 72232 bytes (27%) of program storage space. Maximum is 262144 bytes.
    Global variables use 12104 bytes (18%) of dynamic memory, leaving 53432 bytes for local variables. Maximum is 65536 bytes.
           upload@1741290-Teensy  Uploading to board '1741290-Teensy' (Teensy 3.2)
           upload@1741290-Teensy  Triggering board reboot
           upload@1741290-Teensy  Firmware: Part_3_03_TFT_Display.ino.teensy32.hex
           upload@1741290-Teensy  Flash usage: 71 kiB (27.6%)
           upload@1741290-Teensy  Uploading...
           upload@1741290-Teensy  Sending reset command
    estack:20008000 ebss:1fffb04c
    [Finished in 40.8s]
    @KurtE : that looks like debug print of estack showing on T_3.2
    <EDIT> Build note it chose Teensy Audio over the AdaF that came with NRF boards - unlike the sdFat-beta above:
    Alternatives for Audio.h: [Audio@1.3 Audio_-_Adafruit_Fork@1.3.1]
    ResolveLibrary(Audio.h)
      -> candidates: [Audio@1.3 Audio_-_Adafruit_Fork@1.3.1]
    "T:\\arduino-1.8.13_t54\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=154 -DARDUINO=10600 -DARDUINO_TEENSY32 -DF_CPU=24000000 -DUSB_DUAL_SERIAL -DLAYOUT_US_ENGLISH "-IT:\\arduino-1.8.13_t54\\hardware\\teensy\\avr\\cores\\teensy3" "-IT:\\arduino-1.8.13_t54\\hardware\\teensy\\avr\\libraries\\ILI9341_t3" "-IT:\\arduino-1.8.13_t54\\hardware\\teensy\\avr\\libraries\\SPI" "-IT:\\arduino-1.8.13_t54\\hardware\\teensy\\avr\\libraries\\Audio" "T:\\TEMP\\arduino_build_Part_3_03_TFT_Display.ino\\sketch\\Part_3_03_TFT_Display.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
    13,747
    Using TeamGroup exFAT 128GB with 4 SDTEST WAV files and same p#13 sketch Part _3_03_TFT_Display.ino have good Audio and Video Peak Meter at both 24 MHz and 120 MHz
    Point to any other samples and they can be tested 64GB or 128GB uSD with :: T_3.2 with PJRC Audio card with SPI SD and SD ILI9341 ...
    23,989
    Looks like the startup problems I was seeing may just be a problem with that particular card, a 128GB Samsung EVO (which happens to be a rather old one, was probably very expensive at the time....)
    I now have 3 large cards. A 256GB Samsung EVO and a 128GB Sandisk Extreme are starting up properly every time with the JPEG slideshow.
    23,989
    Yup, Arduino is supposed to ignore that too, when "src" is present.
    If anyone can show this mess creates an actual problem with any of the 4 supported versions of Arduino on any platform, I'll do something to fix that problem.
    But if the problem is just an aesthetically displeasing mess of files which Arduino ignores, I'm going to just leave the case of installing over an old version as a harmless but unsightly mess.
    13,747
    Confirming fix from : File-abstraction-and-SdFat-integration
    Using "const int chipSelect = 10;" in :: T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\SD\exampl es\CardInfo\CardInfo.ino
    With Above T_3.2 on PJRC Audio tutorial kit - and uncommenting the two SPI MOSI and SCK lines:
    SerMon shows:
    Initializing SD card...Wiring is correct and a card is present.
    Card type: SDHC
    Volume type is FAT64
    Volume size (Kbytes): 61038592
    Volume size (Mbytes): 59608
    Card type: SDHC
    Volume size (Kbytes): 123441152
    Volume size (Mbytes): 120548
    And the 64GB uSD :: Audio Tutorial pots 15,16,17 log on 64GB disk with : ...\SD\examples\Datalogger\Datalogger.ino
    1,979,24
    1,981,25
    1,1019,24
    1,1018,25
    1,1019,24
    1,1019,25
    1,1019,24
    1,1019,24
    1,1019,24
    1,1019,26
    1,1019,26
    1,1019,301
    1,1019,498
    1,1018,771
    1,1019,847
    1,1019,935
    1,1018,1003
    <EDIT> Logger tested at 96 and now 24 MHz to run well
    data okay:
    1023,42,42
    780,51,47
    628,116,104
    561,211,165
    472,332,214
    418,537,215
    401,552,215
    403,552,215
    402,552,215
    395,633,356
    256,864,542
    197,1018,726
    115,1018,842
    1,1018,851
    1,1018,852
    1,1018,857
    1,1019,857
    23,989
    Looks like I found a couple bugs. I added an Audio > HardwareTesting > SD_Card folder, and in that folder added this SimultaneousPlay test program.
    https://github.com/PaulStoffregen/Au...aneousPlay.ino
    23,989
    Here are the 6 WAV files meant to be used with the SimultaneousPlay test.
    Attached Files Attached Files
    13,747
    Indeed problematic.
    Started leftover at 24 MHz T_3.2 and played once through up to FIVE, but prints NUM6 with ms=3500 delay
    Dropping delay 1200 or lower went buzzy starting #3
    Moved to 96 MHz and 1200 ms delay buzzes on #5
    At 96 with delay(3500) = plays 1-5 then silence, but prints NUM6
    Problem is number of open files?
    Setting to this give a very annoying overlapping THREE...
    const int milliseconds = 200;
        playNumber(3);
    TWO FILES OKAY :: Editing above as below - gives okay (annoying) THREE's with intermittent ONE's - some freq ONE's and occasional silence. Then some time later is just went SILENT as I typed this.
        playNumber(1);
        playNumber(3);
    Also I added write of analog Data values to ILI9341 in DataLogger with no issue.
    13,747
    Something is wrong with NUM6.WAV ???
    Not the number of files ... (alone)
    THIS works, unless the while(1) is removed then it dies screaming in loop() on NUM1:
        playNumber(1);
        playNumber(2);
        playNumber(3);
        playNumber(4);
        playNumber(5);
        //playNumber(6);
        while(1);
    Where this does not work - even with fewer files:
        playNumber(1);
    //    playNumber(2);
    //    playNumber(3);
    //    playNumber(4);
    //    playNumber(5);
        playNumber(6);
        while(1);
    Zzzzz's
    23,989
    I do not yet understand what's going so wrong. But I'm pretty sure all 6 files are good. I created them all the same way with Audacity.
    New York
    6,794
    Thats good news but maybe should be a warning or note maybe in the wiki or someplace.
    23,989
    It very well may just be this 1 individual card, rather than all cards of that make & model. Sounds like several of us have more cards incoming this week, so if it is a problem worth warning, I'd imagine we'll see some other cards do it.
    I am planning to write a blog article or web page about the SD / SdFat integration and tips for mixing code and libraries which use the 2 different APIs.
    New York
    6,794
    That will be cool - will definitely help with existing code and developing new code.
