Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 26 to 50 of 66
Thread: Teensyduino 1.54 Beta #4
  1. #26
    7,863
    Is it this card?
    https://www.amazon.com/Samsung-Micro.../dp/B06XWN9Q99
    If so, I'll buy a couple and test here.
    (and is it just me, or does the existence of 512GB and 1TB micro SD cards seem kinda surreal?)
    Just got back on-line. 512GB and 1TB = very surreal. When I ordered the 512GB samsung was kind of nervous but worked, was nervous about the 1TB card.
    Just ordered the pair that of 32GB that was posted - should get on Friday.
  2. #27
    9,997
    @Paul and others...
    And again something completely random...
    Over the last few days, been hit again with people needing to increase the RX and/or TX buffers of Serial ports to get there stuff to work. Fixed it for T4... Wondering if worth it for T3.x/LC -
    So far I hacked up the same type changes for Serial 1 (have not done 2-8 yet) as not sure if this is something desired or not
    I pushed up the changes into the branch: https://github.com/KurtE/cores/tree/...ialX_AddMemory
    Again only Serial1 done so far. Question is, is it worth completing?
    Also would probably need some help testing once completed.
    Again played a little more and did the changes for Serial2-6 have not done the LPUART (Serial6 on T3.6). Ran simple test code USBToSerial to make sure I could at least ring back each of the serial ports.
    /* USB to Serial - Teensy becomes a USB to Serial converter
       http://dorkbotpdx.org/blog/paul/teensy_as_benito_at_57600_baud
       You must select Serial from the "Tools > USB Type" menu
    // set this to the hardware serial port you wish to use
    #define HWSERIAL Serial5
    uint8_t tx_buffer[128];
    uint8_t rx_buffer[128];
    unsigned long baud = 19200;
    const int reset_pin = 4;
    const int led_pin = 13;  // 13 = Teensy 3.X & LC
                             // 11 = Teensy 2.0
                             //  6 = Teensy++ 2.0
      pinMode(led_pin, OUTPUT);
      digitalWrite(led_pin, LOW);
      digitalWrite(reset_pin, HIGH);
      pinMode(reset_pin, OUTPUT);
      Serial.begin(baud);	// USB, communication to PC or Mac
      HWSERIAL.begin(baud);	// communication to hardware serial
      HWSERIAL.addMemoryForRead(rx_buffer, sizeof(rx_buffer));
      HWSERIAL.addMemoryForWrite(tx_buffer, sizeof(tx_buffer));
    long led_on_time=0;
    byte buffer[80];
    unsigned char prev_dtr = 0;
      unsigned char dtr;
      int rd, wr, n;
      // check if any data has arrived on the USB virtual serial port
      rd = Serial.available();
      if (rd > 0) {
        // check if the hardware serial port is ready to transmit
        wr = HWSERIAL.availableForWrite();
        Serial.printf("(%d : %d)\n", rd, wr);
        if (wr > 0) {
          // compute how much data to move, the smallest
          // of rd, wr and the buffer size
          if (rd > wr) rd = wr;
          if (rd > 80) rd = 80;
          // read data from the USB port
          n = Serial.readBytes((char *)buffer, rd);
          // write it to the hardware serial port
          HWSERIAL.write(buffer, n);
          // turn on the LED to indicate activity
          digitalWrite(led_pin, HIGH);
          led_on_time = millis();
      // check if any data has arrived on the hardware serial port
      rd = HWSERIAL.available();
      if (rd > 0) {
        // check if the USB virtual serial port is ready to transmit
        wr = Serial.availableForWrite();
        if (wr > 0) {
          // read data from the hardware serial port
          n = HWSERIAL.readBytes((char *)buffer, rd);
          // write it to the USB port
          Serial.write(buffer, n);
      // check if the USB virtual serial port has raised DTR
      dtr = Serial.dtr();
      if (dtr && !prev_dtr) {
        digitalWrite(reset_pin, LOW);
        delayMicroseconds(250);
      prev_dtr = dtr;
      // if the LED has been left on without more activity, turn it off
      if (millis() - led_on_time > 3) {
      // check if the USB virtual serial wants a new baud rate
      if (Serial.baud() != baud) {
        baud = Serial.baud();
        if (baud == 57600) {
          // This ugly hack is necessary for talking
          // to the arduino bootloader, which actually
          // communicates at 58824 baud (+2.1% error).
          // Teensyduino will configure the UART for
          // the closest baud rate, which is 57143
          // baud (-0.8% error).  Serial communication
          // can tolerate about 2.5% error, so the
          // combined error is too large.  Simply
          // setting the baud rate to the same as
          // arduino's actual baud rate works.
          HWSERIAL.begin(58824);
    Again would be better to get some more testing, but wondering if this is something we would like in PR?
    Some of the subtle things to test out include things like the watermarks and when to assert the RTS.
  3. #28
    3,367
    Used 512GB without issues with T3.6 (so far) and have to transition to 1TB cards soon (T4.1 with multiple SPI microSD).
  4. #29
    25,491
    Together with the normal cards, I ordered one of the cheap no-name 512GB cards with the assumption it's really just 32 or 64 and would likely get corrupted if more is written. Last night I copied 390GB of MP3 files onto that card. Right now I'm listening to one of the first group copied. I'm still expecting the capacity claim to be a lie, but the fact that it's working at all seems pretty amazing!
  5. #30
    7,863
    Here are 2 different Amazon page with cards that look identical. Both seems to be EVO Select U1.
    https://www.amazon.com/Samsung-Selec...dp/B01DOB6Y5Q/
    https://www.amazon.com/Samsung-Micro...dp/B06XWN9Q99/
    But one is part number "MB-ME32DA/AM", the other is "MB-ME32GA/AM". I have no idea if the "D" vs "G" is meaningful.
    Any idea if the card you're using is either if "DA/AM" or "GA/AM", or maybe even a 3rd part number that also looks identical?
    Just tested both chips on the T4.2 on the BuiltinSDCard and on the T3.2 with an external Card reader, both worked no problem. Also tested with an external card reader on a T4.0.
    T4.1 on Internal Card Reader - Samsung EVO MB-ME32GA/AM
    Cardinfo.ino
    Initializing SD card...Wiring is correct and a card is present.
    Card type: SDHC
    Volume type is FAT32
    Volume size (Kbytes): 31248384
    Volume size (Mbytes): 30516
    ListFiles.ino
    Initializing SD card...initialization done.
    System Volume Information/
    	IndexerVolumeGuid		76
    raven-node-sch.pdf		82781
    IMXRT1050RM.pdf		36713248
    2016-12-22T20_37_57.578Z-teensy-can-dual-pinout.jpg		202297
    Teensy32Node.pdf		84008
    SN65HVD230-CAN-Board-Schematic.pdf		55749
    RavenNode-cca.pdf		67259
    sn65hvd233??.jpg		107405
    5.jpg		10016
    done!
    T3,2 External Card Reader
    5.jpg		10016
    done!
    T3,2 External Card Reader - Samsung EVO MB-ME32DA/AM
    ListFiles.ino
    USB_Host_Shield_Library_2.0_T4/
    	address.h		10297
    	adk.cpp		12820
    	adk.h		4544
    	avrpins.h		42758
    	BTD.cpp		62734
    	BTD.h		25536
    	BTHID.cpp		22599
    	BTHID.h		5438
    	cdcacm.cpp		11286
    	cdcacm.h		9665
    	cdcftdi.cpp		11747
    	cdcftdi.h		5764
    	cdcprolific.cpp		6712
    	cdcprolific.h		6693
    	cdc_XR21B1411.cpp		5872
    	cdc_XR21B1411.h		13301
    	confdescparser.h		10372
    	controllerEnums.h		5090
    	gpl2.txt		18009
    	hexdump.h		2136
    	hidboot.cpp		7955
    	hidboot.h		21296
    	hidcomposite.cpp		12848
    	hidcomposite.h		3614
    	hidescriptorparser.cpp		58835
    	hidescriptorparser.h		6899
    	hiduniversal.cpp		13307
    	hiduniversal.h		3636
    	hidusagestr.h		54645
    	hidusagetitlearrays.cpp		28774
    	keywords.txt		7989
    	library.json		1185
    	library.properties		773
    	macros.h		3986
    	masstorage.cpp		42701
    	masstorage.h		19504
    	max3421e.h		6166
    	max_LCD.cpp		7110
    	max_LCD.h		3045
    	message.cpp		3016
    	message.h		2579
    	parsetools.cpp		2292
    	parsetools.h		3933
    	printhex.h		2237
    	PS3BT.cpp		32398
    	PS3BT.h		9712
    	PS3Enums.h		4246
    	PS3USB.cpp		22951
    	PS3USB.h		11651
    	PS4BT.h		4711
    	PS4Parser.cpp		6149
    	PS4Parser.h		14364
    	PS4USB.h		4915
    	PSBuzz.cpp		3652
    	PSBuzz.h		6843
    	README.md		20303
    	settings.h		6508
    	sink_parser.h		1173
    	SPP.cpp		47409
    	SPP.h		8473
    	Usb.cpp		35086
    	Usb.h		1177
    	UsbCore.h		13389
    	usbhid.cpp		4897
    	usbhid.h		7496
    	usbhost.h		20866
    	usbhub.cpp		14143
    	usbhub.h		12062
    	usbh_midi.cpp		22363
    	usbh_midi.h		3793
    	usb_ch9.h		9649
    	version_helper.h		4783
    	Wii.cpp		73759
    	Wii.h		17918
    	WiiCameraReadme.md		913
    	xboxEnums.h		1683
    	XBOXOLD.cpp		12016
    	XBOXOLD.h		6729
    	XBOXONE.cpp		17687
    	XBOXONE.h		9447
    	XBOXRECV.cpp		23171
    	XBOXRECV.h		11050
    	XBOXUSB.cpp		13099
    	XBOXUSB.h		8567
    	examples/
    		acm/
    			acm_terminal/
    				acm_terminal.ino		2325
    				pgmstrings.h		2803
    		adk/
    			adk_barcode/
    				adk_barcode.ino		2095
    			ArduinoBlinkLED/
    				ArduinoBlinkLED.ino		2873
    			demokit_20/
    				demokit_20.ino		2381
    			term_test/
    				term_test.ino		1678
    			term_time/
    				term_time.ino		1410
    		Bluetooth/
    			BTHID/
    				BTHID.ino		1880
    				KeyboardParser.h		3358
    				MouseParser.h		1203
    			PS3BT/
    				PS3BT.ino		5995
    			PS3Multi/
    				PS3Multi.ino		5476
    			PS3SPP/
    				PS3SPP.ino		5314
    			PS4BT/
    				PS4BT.ino		5365
    			SPP/
    				SPP.ino		1648
    			SPPMulti/
    				SPPMulti.ino		2390
    			Wii/
    				Wii.ino		3638
    			WiiBalanceBoard/
    				WiiBalanceBoard.ino		1731
    			WiiIRCamera/
    				WiiIRCamera.ino		4832
    			WiiMulti/
    				WiiMulti.ino		4595
    			WiiUProController/
    				WiiUProController.ino		3533
    		board_qc/
    			board_qc.ino		13849
    		cdc_XR21B1411/
    			XR_terminal/
    				XR_terminal.ino		2155
    		ftdi/
    			USBFTDILoopback/
    				pgmstrings.h		2803
    				USBFTDILoopback.ino		2155
    		HID/
    			le3dp/
    				le3dp.ino		1063
    				le3dp_rptparser.cpp		1167
    				le3dp_rptparser.h		819
    			scale/
    				scale.ino		1350
    				scale_rptparser.cpp		3010
    				scale_rptparser.h		1030
    			SRWS1/
    				SRWS1.cpp		1961
    				SRWS1.h		3129
    				SRWS1.ino		5890
    			USBHIDBootKbd/
    				USBHIDBootKbd.ino		2983
    			USBHIDBootKbdAndMouse/
    				USBHIDBootKbdAndMouse.ino		4331
    			USBHIDBootMouse/
    				USBHIDBootMouse.ino		1798
    			USBHIDJoystick/
    				hidjoystickrptparser.cpp		2704
    				hidjoystickrptparser.h		808
    				USBHIDJoystick.ino		876
    			USBHIDMultimediaKbd/
    				USBHIDMultimediaKbd.ino		1671
    			USBHID_desc/
    				pgmstrings.h		2803
    				USBHID_desc.ino		1524
    		hub_demo/
    			hub_demo.ino		11742
    			pgmstrings.h		2803
    		max_LCD/
    			max_LCD.ino		806
    		pl2303/
    			pl2303_gprs_terminal/
    				pl2303_gprs_terminal.ino		2469
    			pl2303_gps/
    				pl2303_gps.ino		2517
    			pl2303_tinygps/
    				pl2303_tinygps.ino		6523
    			pl2303_xbee_terminal/
    				pl2303_xbee_terminal.ino		2885
    		PS3USB/
    			PS3USB.ino		4722
    		PS4USB/
    			PS4USB.ino		4571
    		PSBuzz/
    			PSBuzz.ino		1317
    		testusbhostFAT/
    			Makefile		1901
    			README.md		1229
    			testusbhostFAT.ino		31718
    		USBH_MIDI/
    			bidirectional_converter/
    				bidirectional_converter.ino		3584
    			eVY1_sample/
    				eVY1_sample.ino		1726
    			USBH_MIDI_dump/
    				USBH_MIDI_dump.ino		2149
    			USB_MIDI_converter/
    				USB_MIDI_converter.ino		1821
    			USB_MIDI_converter_multi/
    				USB_MIDI_converter_multi.ino		2016
    		USB_desc/
    			pgmstrings.h		2803
    			USB_desc.ino		9507
    		Xbox/
    			XBOXOLD/
    				XBOXOLD.ino		3718
    			XBOXONE/
    				XBOXONE.ino		4064
    			XBOXRECV/
    				XBOXRECV.ino		4469
    			XBOXUSB/
    				XBOXUSB.ino		3599
    5.jpg		10016
    069_181.pdf		2919298
    74HC_HCT1G125.pdf		198107
    301_canopen (1).pdf		1313731
    done!
    T4.2 Builtin-SDCARD - ListFiles.ino
    	address.h		10297
    	adk.cpp		12820
    	adk.h		4544
    	avrpins.h		42758
    	BTD.cpp		62734
    	BTD.h		25536
    	BTHID.cpp		22599
    	BTHID.h		5438
    	cdcacm.cpp		11286
    	cdcacm.h		9665
    	cdcftdi.cpp		11747
    	cdcftdi.h		5764
    	cdcprolific.h		6693
    	gpl2.txt		18009
    	hexdump.h		2136
    	hidboot.cpp		7955
    	hidboot.h		21296
    	hidcomposite.h		3614
    	hiduniversal.h		3636
    	hidusagestr.h		54645
    	keywords.txt		7989
    	library.json		1185
    	macros.h		3986
    	masstorage.h		19504
    	max3421e.h		6166
    	max_LCD.cpp		7110
    	max_LCD.h		3045
    	message.cpp		3016
    	message.h		2579
    	parsetools.cpp		2292
    	parsetools.h		3933
    	printhex.h		2237
    	PS3BT.cpp		32398
    	PS3BT.h		9712
    	PS3Enums.h		4246
    	PS3USB.cpp		22951
    	PS3USB.h		11651
    	PS4BT.h		4711
    	PS4Parser.cpp		6149
    	PS4Parser.h		14364
    	PS4USB.h		4915
    	PSBuzz.cpp		3652
    	PSBuzz.h		6843
    	README.md		20303
    	settings.h		6508
    	sink_parser.h		1173
    	SPP.cpp		47409
    	SPP.h		8473
    	Usb.cpp		35086
    	Usb.h		1177
    	UsbCore.h		13389
    	usbhid.cpp		4897
    	usbhid.h		7496
    	usbhost.h		20866
    	usbhub.cpp		14143
    	usbhub.h		12062
    	usbh_midi.cpp		22363
    	usbh_midi.h		3793
    	usb_ch9.h		9649
    	Wii.cpp		73759
    	Wii.h		17918
    	xboxEnums.h		1683
    	XBOXOLD.cpp		12016
    	XBOXOLD.h		6729
    	XBOXONE.cpp		17687
    	XBOXONE.h		9447
    	XBOXRECV.cpp		23171
    	XBOXRECV.h		11050
    	XBOXUSB.cpp		13099
    	XBOXUSB.h		8567
    	examples/
    		acm/
    			acm_terminal/
    				pgmstrings.h		2803
    		adk/
    			adk_barcode/
    			ArduinoBlinkLED/
    			demokit_20/
    				demokit_20.ino		2381
    			term_test/
    				term_test.ino		1678
    			term_time/
    				term_time.ino		1410
    		Bluetooth/
    			BTHID/
    				BTHID.ino		1880
    				MouseParser.h		1203
    			PS3BT/
    				PS3BT.ino		5995
    			PS3Multi/
    				PS3Multi.ino		5476
    			PS3SPP/
    				PS3SPP.ino		5314
    			PS4BT/
    				PS4BT.ino		5365
    			SPP/
    				SPP.ino		1648
    			SPPMulti/
    				SPPMulti.ino		2390
    			Wii/
    				Wii.ino		3638
    			WiiBalanceBoard/
    			WiiIRCamera/
    			WiiMulti/
    				WiiMulti.ino		4595
    			WiiUProController/
    		board_qc/
    			board_qc.ino		13849
    		cdc_XR21B1411/
    			XR_terminal/
    		ftdi/
    			USBFTDILoopback/
    				pgmstrings.h		2803
    		HID/
    			le3dp/
    				le3dp.ino		1063
    			scale/
    				scale.ino		1350
    			SRWS1/
    				SRWS1.cpp		1961
    				SRWS1.h		3129
    				SRWS1.ino		5890
    			USBHIDBootKbd/
    			USBHIDBootMouse/
    			USBHIDJoystick/
    			USBHID_desc/
    				pgmstrings.h		2803
    		hub_demo/
    			hub_demo.ino		11742
    			pgmstrings.h		2803
    		max_LCD/
    			max_LCD.ino		806
    		pl2303/
    			pl2303_gps/
    				pl2303_gps.ino		2517
    			pl2303_tinygps/
    		PS3USB/
    			PS3USB.ino		4722
    		PS4USB/
    			PS4USB.ino		4571
    		PSBuzz/
    			PSBuzz.ino		1317
    		testusbhostFAT/
    			Makefile		1901
    			README.md		1229
    		USBH_MIDI/
    			eVY1_sample/
    			USBH_MIDI_dump/
    			USB_MIDI_converter/
    		USB_desc/
    			pgmstrings.h		2803
    			USB_desc.ino		9507
    		Xbox/
    			XBOXOLD/
    				XBOXOLD.ino		3718
    			XBOXONE/
    				XBOXONE.ino		4064
    			XBOXRECV/
    				XBOXRECV.ino		4469
    			XBOXUSB/
    				XBOXUSB.ino		3599
    5.jpg		10016
    069_181.pdf		2919298
    done!
  6. #31
    9,997
    Thanks @mjs513,
    Will retest the one I have, maybe with some other external SD reader. Like maybe one on an Adafruit display board... The one I was using was a sparkfun one with level shifters, which should work for 3.3 or 5v, but who knows, maybe something maybe sensitive on these type cards with signals coming and going through TXB104 shifters.
    Note: I just ordered one of each also... Although for the one that supposedly matches the one I already had (cheaper one), I upped it to the 64mb version.
  7. #32
    9,997
    Hi @Paul and @mjs513
    Thanks @mjs513,
    Sort of interesting that I retried the one on the Sparkfun board and it failed again. Several other MicroSds worked. This is a T4
    I then hooked up Adafruit ST7789 display to second T4 and hooked up the SDCS pin from the display to pin 4... And the Samsung EVO SDHC worked... Will be interesting to see when the two other arrive.
  8. #33
    Hi all! The 1.54b4 build worked great for us. We used it for the Pigweed remoticon workshop today: https://hackaday.io/project/175167-r...igweed-a-whirl
    Step by step guide is here: https://pigweed.googlesource.com/pig...shop/README.md
    Thank you for all the hard work getting 1.54 out the door! I'll update to stable when y'all release it.
  9. #34
    Feb 2018
    Corvallis, OR
    355
    A question about the SD wrapper for SDFat: Will I be able to use the sync() function if I use only SD.h? I've found that the sync() function is very helpful in long data logging sessions for two reasons: 1: it updates the directory so you can minimize data loss if the logger loses power in the middle of a logging session, 2: calling sync() puts the SD card into idle mode which significantly reduces power consumption. https://forum.pjrc.com/threads/59526...ync()-in-EXFat
  10. #35
    3,367
    Quote Originally Posted by mborgerson View Post
    Use SD.flush(), which is calling sdfat's sync().
    Or use SD.sdfs.sync();
    SD.sdfs is declared public , so you can use sdfat functions directly.
  11. #36
    9,997
    Quick update: I went ahead and ordered a couple more of the Samsung EVO Select cards and will try them out again. In particular will be interesting to see if the two new ones act different than the ones I ordered maybe two years ago in the top of the picture. The 3 32gb ones are marked in small letters under the EVO Select as HC... The 64 is marked XC
    Again no idea how different they are both will write up to 20mb/s the HC one is marked Read up to 95 and the XC up to 100MB....
  12. #37
    9,997
    Quick update: The Sparkfun adapter appears to be able to work with both of these... So for the heck of it, I am right now using SDFormatter on one of the old ones to completely erase and overwrite it and will see if it likes it then... It is taking awhile to do the full overwrite.
  13. #38
    9,997
    Ok I did a complete low level reformat of one of the older ones, which created one Fat32 drive... I tried it again on the Sparkfun SPI adapter Pin 4 and it failed to initialize again. Tried it on different T4 with Adafruit display and SDCard connected again on Pin 4 and it reads the SD... Maybe I should go ping this to Sparkfun!
    Edit: Emailed Sparkfun... Also including photo of back showing the two old ones and the new one.
    The one on left is new one.. Same top number but different second number... Probably some hardware revision happened.
  14. #39
    Member LitterBug's Avatar
    Nov 2020
    Earth
    24
    I don't have any of the EVO Selects, but I have been doing my own playing and bench testing of cards on a 4.1, 1-54B4, with the Built in reader and FIFO_SDIO. All of these cards have worked. I can even read two "bricked" cards that nothing else seems to want to. (marked with X in bottom of pic. Most of the cards write in the 12-18MB/s range, and almost all of them will read around 22.8MB/s. The old Samsung pro writes faster than the newer one. (20 vs 17 MB/s). All cards tested were empty and freshly formatted with SDCardFormmatterV5.
    These are my fastest cards. these will all write roughly 20.8MB/s, and read at roughly 22.8MB/s. The most consistent between all the tests has been the SanDiskExtreme 16GB U3. The Fastest is one of my older 32GB EVO cards that writes @ 21.3 and reads @ 23.0
    Samsung EVO 32 U1
    size,write,read
    bytes,KB/sec,KB/sec
    512,21288.45,22891.92
    1024,21285.16,22923.83
    2048,21332.41,22983.87
    4096,21374.75,23011.87
    8192,21386.53,23026.59
    16384,21257.38,23056.84
    32768,21392.58,23034.99
    EDIT:
    Interesting. Reformatted the SanDisk Extreme 16GB to ExFat, and both the read and write performance went up
    size,write,read
    bytes,KB/sec,KB/sec
    512,22460.24,22897.86
    1024,22106.87,22930.97
    2048,22570.83,22979.84
    4096,22183.46,23007.13
    8192,22612.27,23020.65
    16384,22181.35,23027.03
    32768,22622.08,23030.95
  15. #40
    Nov 2020
    Earth
    24
    These numbers suggest we are using High Speed Mode (25 MB/s) 50mhz-4bit clocking and not UHS clocking. Wonder if the hardware can handle at least the slower 100Mhz UHS clock and 50MB/s. I won't beg for the 208MHz rate of 104MB/s...
    LB
    The CPU Spec sheet looks promising for even the higher UHS-1 spec
    I've dug through the code and don't see any support for UHS-1. Would probably take a bit of work to do more than a hack job of it. Probably be a good "Feature Request'
  16. #41
    4,110
    From what I've read, to do UHS-1, you would need to drop the voltage from 3.3v to 1.8 on each of the 4 data pins and VDD. UHS-2 requires 0.4v and it has double the pins:
  17. #42
    Nov 2020
    Earth
    24
    From what I'm reading in the CPU specs and manual, That can be done using the SD/SDIO interfaces. Data sheets are here https://www.pjrc.com/teensy/datasheets.html
    High level DataSheet: https://www.pjrc.com/teensy/IMXRT1060CEC_rev0_1.pdf
    Deep dive Manual: https://www.pjrc.com/teensy/IMXRT1060RM_rev2.pdf
    From page 1376 of the processor manual
    24.3 eMMC/eSD/SDIO
    This chip has two Ultra Secured Digital Host Controller (uSDHC) modules for SD/
    eMMC interface. It provides the interface between the host system and the SD/
    SDIO/MMC cards.
    The key features include:
    • Support SD/SDIO standard, up to version 3.0
    • Support MMC standard, up to version 4.5
    • Support 3.3V and 1.8V operation, but do not support 1.2V operation.
    • Supports 1-bit / 4-bit SD and SDIO modes, 1-bit / 4-bit / 8-bit MMC modes
    • Up to 800 Mbps of data transfer for SDIO cards using 4 parallel data lines in
    SDR mode
    • Up to 400 Mbps of data transfer for SDIO card using 4 parallel data lines in
    DDR mode
    • Up to 800 Mbps of data transfer for SDXC cards using 4 parallel data lines in
    SDR mode
    • Up to 400 Mbps of data transfer for SDXC card using 4 parallel data lines in
    DDR mode
    • Up to 1600 Mbps of data transfer for MMC cards using 8 parallel data lines in
    SDR mode
    • Up to 800 Mbps of data transfer for MMC cards using 8 parallel data lines in
    DDR mode
    eMMC/eSD/SDIO
    i.MX RT1060 Processor Reference Manual, Rev. 2, 12/2019
    1376 NXP Semiconductor
    EDIT: So full UHS-1 support "should" be possible on the T4.0 and T4.1 as long as the SD card is connected to one of the two SDIO interfaces.
    EDIT2: There is also a whole section on setting up SD/SDIO boot with UHS-1 support....
    EDIT3: On the T4.0, you need to use the SD Card (4 bit SDIO) flats on the bottom of the board and an SD card Connector/module with NO level converters.
    https://www.digikey.com/en/products/...821852/5823232 or https://www.digikey.com/en/products/...710001/3262277
  18. #43
    4,110
    Cool, thanks for the update.
  19. #44
    15,501
    New TeamGroup 256 GB SD card. From NewEgg : newegg.com/team-128gb-microsdxc
    SD\cardinfo.ino gives:
    Card type: SDHC
    Volume type is FAT64
    Volume size (Kbytes): 250281984
    Volume size (Mbytes): 244416
    ...\teensy\avr\libraries\SdFat-beta\examples\SdInfo\SdInfo.ino gives more info and works:
    type any character to start
    init time: 8 ms
    Card type: SDXC
    Manufacturer ID: 0X12
    OEM ID: 4V
    Product: SD
    Version: 1.0
    Serial number: 0X6B13A014
    Manufacturing date: 9/2014
    cardSize: 256355.86 MB (MB = 1,000,000 bytes)
    flashEraseSize: 128 blocks
    eraseSingleBlock: true
    OCR: 0XC0FF8000
    SD Partition Table
    part,boot,bgnCHS[3],type,endCHS[3],start,length
    1,0X0,0X14,0X11,0X4,0X7,0XFE,0XFF,0XFF,65536,500629504
    2,0X0,0X0,0X0,0X0,0X0,0X0,0X0,0X0,0,0
    3,0X0,0X0,0X0,0X0,0X0,0X0,0X0,0X0,0,0
    4,0X0,0X0,0X0,0X0,0X0,0X0,0X0,0X0,0,0
    Scanning FAT, please wait.
    Volume is exFAT
    sectorsPerCluster: 512
    clusterCount:      977664
    freeClusterCount:  977661
    fatStartSector:    98304
    dataStartSector:   131072
    This sketch won't compile as installed with 'SD_FAT_TYPE = 0' : T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\SdFat-beta\examples\bench\bench.ino
    "T:\\TEMP\\arduino_build_bench.ino\\sketch\\bench.ino.cpp.o"
    T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\SdFat-beta\examples\bench\bench.ino:69:1: error: 'File' does not name a type
     File file;
    T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\SdFat-beta\examples\bench\bench.ino: In function 'void loop()':
    T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\SdFat-beta\examples\bench\bench.ino:167:8: error: 'file' was not declared in this scope
       if (!file.open("bench.dat", O_RDWR | O_CREAT | O_TRUNC)) {
    T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\SdFat-beta\examples\bench\bench.ino:190:5: error: 'file' was not declared in this scope
         file.truncate(0);
    T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\SdFat-beta\examples\bench\bench.ino:233:5: error: 'file' was not declared in this scope
         file.rewind();
    T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\SdFat-beta\examples\bench\bench.ino:269:3: error: 'file' was not declared in this scope
       file.close();
    Using library SdFat-beta at version 2.0.0-beta.8 in folder: T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\SdFat-beta
    Changing this to #3 works for this disk and compiles:
    // SD_FAT_TYPE = 0 for SdFat/File as defined in SdFatConfig.h,
    // 1 for FAT16/FAT32, 2 for exFAT, 3 for FAT16/FAT32 and exFAT.
    #define SD_FAT_TYPE 0
    Read and write speed looks GOOD at 21 MB/s Write and 22 MB/s Read:
    Type any character to start
    FreeStack: 441472
    Type is exFAT
    Card size: 256.36 GB (GB = 1E9 bytes)
    OEM ID: 4V
    Product: SD
    Version: 1.0
    FILE_SIZE_MB = 5
    BUF_SIZE = 512 bytes
    Starting write test, please wait.
    write speed and latency
    speed,max,min,avg
    KB/Sec,usec,usec,usec
    21095.70,47,22,23
    21007.06,47,23,23
    Starting read test, please wait.
    read speed and latency
    speed,max,min,avg
    22725.82,23,22,22
    22829.59,23,22,22
    Done
    Then ran ...\teensy\avr\libraries\SdFat-beta\examples\ExFatFormatter\ExFatFormatter.ino
    That worked and above bench.ino gave similar results
  20. #45
    Feb 2018
    Corvallis, OR
    355
    Is there any chance of making the text entry box and "Send" button at the bottom of the Serial Plotter actually send data to the Teensy? The plotter is occasionally useful when I want to view an ADC input waveform without having to send the data to the PC and using a separate plotting program. It would be nice to be able to start and stop the Teensy output with command characters sent from the plotter instead of having to switch back to the Serial Monitor.
    Is this something outside the control of PJRC, or just a low-priority task?
  21. #46
    Feb 2018
    Corvallis, OR
    355
    I think I just answered my own question. Recalling the difficulties with double-spaced cut and pasted Serial Monitor output that disappeared when you choose the port from "serial ports" instead of "Teensy Ports", I switched to the "Serial Port" and lo and behold, text from the text box gets sent to the Teensy!
  22. #47
    15,501
    Good find that IDE SerMon Serial does that. Was going to suggest use TyCommander with DualSerial - let IDE Teensy SerMon OWN and do plotting and then the 2nd Serial in TyComm would allow command and also any debug spew.
  23. #48
    25,491
    Here is my latest attempt to fix the double spaced lines on copy to clipboard from the serial monitor on Windows.
    Extract this zip file and copy teensy_serialmon.exe to {Arduino}/hardware/tools, replacing the existing file. Windows probably won't let you replace it if the serial monitor is open. The default Arduino location is C:\Program Files (x86)\Arduino.
    I ran a quick test here on Windows 10 where it seems to work. Does this solve the double spaced lines on your Windows machine?
    Attached Files Attached Files
  24. #49
    15,501
    @Paul - that works here on Windows 10:
     Blink again - w/println - before bare println
     Blink again - w/println - after bare println - end loop.
    <EDIT> :: This is NOT new behavior - just put back another copy of that file from another 1.54 beta install - and it has the same ODD behavior
    Note: Text select to copy does odd shift of selected text - rather than inverse text color on highlight and stay steady - some lines toggle inverted text color to not visible?
    Movie too big - here are three frames ...
ID:	22444Click image for larger version.
ID:	22445Click image for larger version.
  25. #50
    7,863
    @Paul
    Seems to work for me here as well. This is a direct copy past from the serial monitor:
    LittleFS Test
    flash begin
    Flash ID: EF 70 18
    Flash size is 16.00 Mbyte
    attemping to mount existing media
    success
    started
    printDirectory
    FILE	PRINTOUTPUT1.txt		628
    FILE	PRINTOUTPUT2.txt		630
    FILE	file1.txt		32
    FILE	file10.txt		16
    FILE	file2.txt		32
    FILE	file20.txt		16
    FILE	file3.txt		32
    FILE	file30.txt		16
    FILE	mtpindex.dat		0
    DIR	structuredData /
    	FILE	logger.txt		480
    DIR	test1 /
    	FILE	file1.txt		16
    DIR	test2 /
    	FILE	file2.txt		16
    DIR	test3 /
    	FILE	file3.txt		16
    Disk Usuage:
    Bytes Used: 53248, Bytes Total:16777216
    Before always extra lines. So looks good from my test.
