Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 66
Thread: Teensyduino 1.54 Beta #4
    Administrator Paul's Avatar
    Oct 2012
    418
    Here is a fourth beta test for Teensyduino 1.54.
    Edit: Links removed. Please use 1.54-beta9
    https://forum.pjrc.com/threads/67252...no-1-54-Beta-9
    Changes since Teensyduino 1.54-beta3:
    Update NativeEthernet
    Audio: Improve simultaneous WAV playing & add SimultaneousPlay test
    SD default to 16 MHz SPI clock
    Serial Monitor fix double spaced lines copied to clipboard
    Serial Monitor avoid auto horizontal scroll on very long lines
    Serial Monitor fix memory leak on MacOS
    Apr 2020
    switzerland
    10
    The link to the Catalina version doesn't seem to work!
    EDIT: seems to be working now!
    New York
    7,644
    Installed over beta3 on a Win10x64 without issue.
    Tested SD default to 16Mhz SPI Clock:
    a. BUILTIN_SDCARD on T4.1 Listfiles.ino worked at 16Mhz no problem as well as the ILI9341_t3_Slideshow. Both tested with a 512Gb SD Card.
    b, Tested a T3,2 with an external SDcard reader with a 32Gb SDcard and ran the ILI9341_t3_Slideshow. Images displayed correctly on a ILI9341 and no issue with reading SDcard
    Serial Monitor fix double spaced lines copied to clipboard:
    Initializing SD card...initialization done.
    LOG_0816.csv		4364
    OV7670.bmp		153666
    System Volume Information/
    	WPSettings.dat		12
    	IndexerVolumeGuid		76
    mtpindex.dat		0
    datalog.txt		5363
    LOG_0001.csv		86201
    LOG_0000-afternno.csv		121978
    LOG_00001.csv		65318
    LOG_62620.csv		183998
    perf.jpg		34910
    squirrel_dither.jpg		39057
    demo.jpg		40582
    num3.wav		289750
    num4.wav		260436
    num5.wav		276426
    num6.wav		260818
    num1.wav		300028
    num2.wav		266528
    done!
    Looks like still getting the extra lines on windows 10 while SerMon shows no extra lines
    25,208
    Quote Originally Posted by MovingAverage View Post
    Opps, sorry, my mistake, forgot to copy it over from my mac before uploading. I've uploaded the file just now.
    New York
    7,644
    While I don't have a mac at least I can verify thats its there and can be downloaded - at least on a Win10 machine
    9,723
    Tried the Linux Arm 64, it downloads, but if you try to run it, it gets a Bus error (core dumped) error.
    Downloaded twice. Actually I think maybe three times. Tried wget, but for some reason I ran the beta 2 version? So I tried loading up desktop with firefox to download... Got the crash, In process of wget again
    Still failed
    Should mention: This is an RPI4-8 running Ubuntu 64 bit... The Beta 2 ran.
    25,208
    Oh, not good. I had problems with my Jetson TX2 used the build that code, crashing during the build. It seemed to be working this time, but the truth is I haven't tested it in any way. That TX2 doesn't even have a monitor or keyboard connected right now. Might be a couple weeks until I can pull it out onto a workbench and try to figure out what's going wrong.
    9,723
    Understood - I thought I would try it out again. More curious to see if by some magic the inability to have the Arduino IDE launch the Teensy app in a working state to be able to program a teensy was resolved. I think the last details about this was in the beta 2 thread. (https://forum.pjrc.com/threads/64023...l=1#post257054)
    My guess the Jetson is quicker to do the stuff, but my setup for this is as I mentioned an RPI4-8 (the newest), with firmware that allows you to boot off of USB. I then have an SSD drive connected up to boot. At one point I had the Raspian OS 64 bit Beta installed. Not what state that is in now.
    Currently I installed the Ubuntu Server and then added the GUI...
    @mjs513 has a setup as well.
    25,208
    I retested this again on Windows 10 and I can't reproduce the problem.
    Any chance there might have been an instance of teensy_ports.exe running while you installed? The installer is supposed to stop if Windows reports any error writing, so I can't understand how, but maybe teensy_ports.exe didn't get updated?
    9,723
    I installed Beta4 on W10/64....
    Reprogrammed T3.2 with listfiles example with external reader:
    	WPSettings.dat		12
    LaikH.JPG		2801
    hallow.JPG		21026
    DRAKE.JPG		15775
    done!
    Update: If instead I choose the board under Serial ports and not under Teensy ports, than it Looks like I get single spacing...
    	WPSettings.dat		12
    LaikH.JPG		2801
    hallow.JPG		21026
    DRAKE.JPG		15775
    done!
    Apr 2020
    switzerland
    10
    I didn't really know where to post about it, but I made a new thread regarding an issue that I have since Teensyduino 1.52 and which is still present in this version. I tried to address that already in the betathread of 1.52 but wasn't really able to explain myself.
    I tried to list all the information and knowledge that I have regarding this problem, and would love if we could solve that! Here is the link to the thread
    Thanks for all the great work and help.
    25,208
    Ugh, tried again and this time I did get double spaced.
    Looks like I have more work to do on this issue....
    New York
    7,644
    	WPSettings.dat		12
    LaikH.JPG		2801
    hallow.JPG		21026
    DRAKE.JPG		15775
    done!
    	WPSettings.dat		12
    LaikH.JPG		2801
    hallow.JPG		21026
    DRAKE.JPG		15775
    done!
    I installed clean copy of Arduino-1.8.13 along with beta4. Can confirm what @KurtE posted on the SerMon issue with Win10x64
    As long as you "choosing the board under Serial ports and not under Teensy ports, than it Looks like I get single spacing...". If you choose Serial under TeensyPorts you get the double space. Tested with Builtin_sdcard on a T4.1
    9,723
    Just thought I would mention I again tried the SD Card list program (listfiles) External SPI reader works on both T3.2 and T4 (Sparkfun unit...)
    Neither one will read the Samsung 32 EVO disk... Fails to initialize.
    BUT if I build T4 with BUILTIN_SDCARD - it works with the EVO card...
    9,723
    @Paul and others...
    And again something completely random...
    Over the last few days, been hit again with people needing to increase the RX and/or TX buffers of Serial ports to get there stuff to work. Fixed it for T4... Wondering if worth it for T3.x/LC -
    So far I hacked up the same type changes for Serial 1 (have not done 2-8 yet) as not sure if this is something desired or not
    I pushed up the changes into the branch: https://github.com/KurtE/cores/tree/...ialX_AddMemory
    Again only Serial1 done so far. Question is, is it worth completing?
    Also would probably need some help testing once completed.
    15,259
    Win 10 install of TD 1.54 b4 no problem here - compiled the active sketch Audio w/SD on T_3.2 as before.
    @KurtE - speaking of Random. Question: Did the rewrite of UART_Serial# result in no alloc of buffers for unused Serial#'s?
    If not: With the Dynamic alloc of UART Serial# buffer working. Could it only alloc() the default buffer on Serial#.begin() [when a null *buff?] And if larger buffer wanted then do the ..._AddMemory() before .begin() to get a single buffer of desired size - and resulting in a non-null *buff when .begin() happens?
    9,723
    Quick update here. I have been outputting some debug information in the code and output:
    Initializing SD card...CardBegin Error: 12
    SDFAT Cardbegin failed
    initialization failed!
    done!
    Press any key to rerun
    I believe that error code is:0X12,SD_CARD_ERROR_CMD58 - Read OCR register
    Which in SdSpiCard.cpp there is code:
      // if SD2 read OCR register to check for SDHC card
      if (type() == SD_CARD_TYPE_SD2) {
        if (cardCommand(CMD58, 0)) {
          error(SD_CARD_ERROR_CMD58);
          goto fail;
        if ((spiReceive() & 0XC0) == 0XC0) {
    So it looks like this command is failing...
    25,208
    FWIW, I've done nearly all my testing with this card. It has always worked. But I've only tested it in SPI mode with PJRC's 3 shields having SD sockets (audio, wiz820, and SD adaptor for Teensy 2.0).
    9,723
    It should be setup now that only those Serial objects that are used are brought into the sketch. including the event objects and the like.
    Earlier when we discussed the idea of adding memory to the buffers. There were those that did not want to use malloc or the like, but instead have static buffers as to make it easier to see if their sketch is running low on memory. At one point I thought about adding simple addMemory...(nullptr, 128) it would do the malloc for you... But I am pretty sure punted as the caller could have done that as well.
    9,723
    The one that I have had issues with is:
    Sorry image is quick and dirty...
    25,208
    Is it this card?
    https://www.amazon.com/Samsung-Micro.../dp/B06XWN9Q99
    If so, I'll buy a couple and test here.
    (and is it just me, or does the existence of 512GB and 1TB micro SD cards seem kinda surreal?)
    9,723
    Yep that is the one, It showed I purchased it back in July 2018
    25,208
    The card that was giving me occasional startup trouble was also a Samsung "EVO Select U1". It was 128GB. I sent a package to Bill Greiman with hardware for testing and I included that troublesome card, so it's no longer here.
    I just looked through my collection of cards. The Samsung ones I have are "EVO Plus U1" or "EVO Select U3". I currently don't have any "EVO Select U1" cards. Will get 2 of those from Amazon soon.
    Info I can find online suggests U1 means 10 Mbyte/sec and U3 means 30 Mbyte/sec. I have no idea what the difference between Plus vs Select is, other than the color. But I did find at least some conversation claiming there is a substantial difference between "EVO+" and "EVO Plus".
    25,208
    Here are 2 different Amazon page with cards that look identical. Both seems to be EVO Select U1.
    https://www.amazon.com/Samsung-Selec...dp/B01DOB6Y5Q/
    https://www.amazon.com/Samsung-Micro...dp/B06XWN9Q99/
    But one is part number "MB-ME32DA/AM", the other is "MB-ME32GA/AM". I have no idea if the "D" vs "G" is meaningful.
    Any idea if the card you're using is either if "DA/AM" or "GA/AM", or maybe even a 3rd part number that also looks identical?
    9,723
    Looks like mb-me32g on the back of the card.
    As for the real differences the one that I don't have says(about twice as expensive): Up to 80MB/s transfer speed
    The one I have says: Ultra-fast read write speeds: Up to 95MB/S Read and 20MB/S Write Speeds;
