Results 1 to 8 of 8
Thread: Wavefolder possible?
    Is wavefolding possible to do with current audio library objects?
    I'm aware that there is no wavefolder objects, i'm trying to find if there is a cleaver way of doing is with the objects avaliable.
    Here is a good exemple of what wavefolder does:
    https://www.youtube.com/watch?v=JS18BX4yIPQ
    Jul 2020
    1,101
    effect waveshaper might be a possible approach, but I think this really needs a custom object to do the folding simply
    and efficiently.
    Jul 2020
    1,101
    I got bored and had a go at doing this...
    Created an AudioEffectWaveFolder class, here's the git hub links, but I've included at the end too.
    https://github.com/MarkTillotson/Aud...t_waveshaper.h
    https://github.com/MarkTillotson/Aud...waveshaper.cpp
    Its based on the AudioEffectMultiply, taking two inputs and multiplying them, the idea being one is the slow modulation control from
    an envelope or LFO, the other a signal to process. There's a gain of 16 so that modulation = 0.0625 will have unity gain and not
    trigger any folding, but higher values can (if the signal's high enough).
    The folding operation is applied to the result.
    Some 'scope shots:
    Here's the test script:
    //#include <effect_wavefolder.h>  // added to Audio.h in the branch now
    AudioOutputI2S         i2sout ;
    AudioSynthWaveform     sig ;   // signal to be modulated
    AudioSynthWaveform     mod  ;  // modulate the amplitude into folder
    AudioEffectWaveFolder  folder ;
    AudioConnection        c0 (mod, 0, folder, 0) ;
    AudioConnection        c1 (sig, 0, folder, 1) ;
    AudioConnection        c2 (folder, 0, i2sout, 0) ;
    AudioConnection        c3 (folder, 0, i2sout, 1) ;
    // The Audio Shield chip
    AudioControlSGTL5000 codec;
    void audio_setup()
      AudioMemory(4);
      sig.begin (0.99, 100, WAVEFORM_SINE) ;
      mod.begin (0.03, 5, WAVEFORM_SINE) ;
      mod.offset (0.0625) ;
      codec.enable();
      codec.volume(0.6);
      codec.lineOutLevel (13) ;  // turn up line out to max
    void loop () {}
    void setup ()
      Serial.begin (115200) ;
      audio_setup () ;
    And the implementation:
    effect_wavefolder.h
    /* Wavefolder effect for Teensy Audio library
     * Copyright (c) 2020, Mark Tillotson
     * THE SOFTWARE.
    #ifndef effect_wavefolder_h_
    #define effect_wavefolder_h_
    #include "Arduino.h"
    #include "AudioStream.h"
    class AudioEffectWaveFolder : public AudioStream
    public:
      AudioEffectWaveFolder() : AudioStream(2, inputQueueArray) {}
      virtual void update() ;
    private:
      audio_block_t * inputQueueArray[2] ;
    effect_wavefolder.cpp
     * THE SOFTWARE.
    #include "effect_wavefolder.h"
    void AudioEffectWaveFolder::update()
      audio_block_t * blocka = receiveWritable (0);
      if (!blocka)
        return;
      audio_block_t * blockb = receiveReadOnly (1);
      if (!blockb)
        release (blocka);
        return;
      int16_t * pa = blocka->data ;
      int16_t * pb = blockb->data ;
      for (int i = 0 ; i < AUDIO_BLOCK_SAMPLES ; i++)
        int32_t a12 = pa[i];
        int32_t b12 = pb[i];
        // scale upto 16 times input, so that can fold upto 16 times in each polarity
        int32_t s1 = (a12 * b12 + 0x400) >> 11 ;
        // if in a band where the sense needs to be reverse, detect this
        bool flip1 = ((s1 + 0x8000) >> 16) & 1 ;
        // reverse and truncate to 16 bits
        s1 = 0xFFFF & (flip1 ? -s1 : +s1) ;
        pa[i] = s1;
      transmit(blocka);
      release(blocka);
      release(blockb);
    I only saw it today, thank you for putting an effort on this !
    Will try it later today, when i'm back home.
    Just tested the wavefolder and sounds great! but i'm having some "clicks" here and there.
    Maybe i'm doing something wrong?
    I'm using the PT8211 audio codec. Could be this guy's fault?
    I also added a dc offset object, since i want to control the folder with a pot.
    here is my code (ugly i know), can someone spot something?
    [ CODE]
    #include <Smoothed.h> // Include the library
    AudioOutputPT8211 pt8211_1; //xy=788,362
    AudioSynthWaveformDc dc1; //xy=218.03125,732.53125
    AudioConnection c0 (dc1, 0, folder, 0) ;
    AudioConnection c2 (folder, 0, pt8211_1, 0) ;
    AudioConnection c3 (folder, 0, pt8211_1, 1) ;
    float mapf(float x, float in_min, float in_max, float out_min, float out_max)
    {return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;}
    #define SENSOR_PIN A0 // pin para smooth do folder
    Smoothed <float> smoothFolderKnob;
    AudioMemory(100);
    analogReadResolution(12);
    sig.begin (0.6, 100, WAVEFORM_SINE) ;
    smoothFolderKnob.begin(SMOOTHED_AVERAGE, 10);
    void loop () {
    float currentSensorValue = analogRead(SENSOR_PIN);
    smoothFolderKnob.add(currentSensorValue);
    float foldKnob = smoothFolderKnob.get();
    float foldKnobValue = mapf(foldKnob, 0, 4096, 0.0625, 16);// C1~C6
    float foldDC = mapf(foldKnobValue, 0.0625, 16, 0.06, 1.0);// C1~C6
    dc1.amplitude(foldDC);
    [ /CODE]
    Jul 2020
    1,101
    Quote Originally Posted by manatee View Post
    Sorry for the delay in replying. Recently been tidying up some old branches and spotted this.
    Its a bug in the folder, whenever the folder saw a sample value ending in 0x8000 it was glitching.
    Its fixed in the branch here: https://github.com/MarkTillotson/Aud...wavefolder.cpp
    I'm going to create a pull request for the wave folder effect as I've now added gui and documentation.
    Jul 2020
    1,101
    I note this has been merged now so should be available in the next Teensyduino release... Thanks manatee for spotting that
    click bug (it was visible on a 'scope occasionally, but easy to miss).
    Member garcho's Avatar
    May 2020
    Richmond, VA
    22
    Thanks for your efforts Mark, I look forward to trying this out, cheers
