Page 1 of 2 1 2 LastLast
Results 1 to 25 of 29
Thread: Command Line Build
    Apr 2018
    Eastern Time, USA
    163
    Command Line Build
    Is there a way to automatically create (or dump) a makefile to build a sketch from the command line, in linux?
    And within the IDE, is there a way to set a macro definition, i.e. like #define in a source file or -Dmacroname in gcc?
    Senior Member blackketter's Avatar
    May 2015
    San Francisco
    343
    Check out https://platformio.org for command-line builds. You can specify gcc options in the platformio.ini file for a given project.
    Apr 2018
    Eastern Time, USA
    163
    @blackketter I am sorry, that is not a good answer for me. I do not want to install more clutter, and I have no use or interest, none whatsoever, in a "a professional collaborative platform of embedded development". Uggh! I'm shaking at the thought of it.
    Again, I just want a simple make command line, that I can add switches to for conditional builds. The context is that I am deploying the project on a few different flavors of board.
    Senior Member brtaylor's Avatar
    Mar 2016
    Portland, OR
    702
    I'm a huge proponent of CMake. For my builds that have options, like which microcontroller to compile for, I use definitions so that I can choose between them on the command line. ie:
    cmake .. -DMCU=MK66FX1M0
    Which is a definition I'm using to select the MCU. CMake generates the appropriate Makefile and seems to do a good job caching builds, so compilation is quicker after the first one.
    3,316
    Quote Originally Posted by DrM View Post
    So what is wrong with the makefile in cores?
    Apr 2018
    Eastern Time, USA
    163
    @WMXZ Sounds great. Where is it in the tree? And, how do I use it?
    Do I just copy it into the directory with the .ino file, or do I need to edit the makefile?
    And how do I pass the switch for the conditional build? Is it just the usual CFLAGS=-Dsomething ?
    And does it produce a hex file, or does it flash the teensy?
    Thank you
    3,316
    Thank you
    Sorry, I thought you know how to read and use makefiles.
    I don't know your system, I'm not using linux, but it is in the directory where the Teensy cores files are. (either Teensy3 or Teensy4)
    Apr 2018
    Eastern Time, USA
    163
    I do indeed know how to read make files.
    I still don't know where this one is to be found.
    And sometimes makefiles are so complicated that it takes a long time to decipher what a particular makefile is doing and how to use it. And, I see from what is displayed on the ide that this a pretty complicated build
    A little specific guidance and would be a big help and likely save a lot of time,
    3,316
    Sure,
    where you install TD you will find the following path (Windows language)
    ....\hardware\teensy\avr\cores\teensy4
    where all the core filers of TD are (including the makefile) for T3.x use teensy3
    Apr 2018
    Eastern Time, USA
    163
    Good, thank you, presumably you meant teensy3, in any case I found it.
    It looks like it is setup for .c files and no obvious reference to the .ino files created by the ide.
    What needs to be done to process .ino files?
    Is it sufficient to simply add it to the objs (near the bottom of the makefile) analogous to the way the .c and .cpp files are added, or perhaps simply copy the .ino to a .c file?
    24,784
    Usually these steps.
    1: concatenate all .ino files together (if you have more than 1 .ino file) and rename to .cpp
    2: add #include "Arduino.h" at the top
    3: add function declarations as needed
    This 3rd step usually involves some trial and error (or recompile). Arduino's preprocessing scans the .ino files for all the functions you've created and automatically puts function prototype declarations at the top of converted .cpp, so functions can appear in any order in the files. Normally C++ requires you to declare a function prototype if you use the function name in any part of the file before the actual function.
    The exact details of how Arduino does this have changed over the years, so there isn't 1 simple and universal answer to this question.
    The other piece of magic Arduino does is finding all the #include lines you have typed (or which are inside of libraries) and it tries to infer which libraries you meant to use. The result is -I include lines while compiling code, and building those libraries, and the final linker command which puts them into your compiled code.
    For example if you include SD.h, Arduino's build system figures out you want the SD library, and inside the SD library it notices the SPI library is also needed. This too has changed over the years with different Arduino releases. It's quite a challenge and far beyond the scope of a makefile (but it is the domain of systems like autoconf) so you generally won't find makefiles which do this. Normally you have to edit the makefile for the libraries you want to build.
    If you are hoping to craft a makefile which seamlessly "just works" with all .ino files, this automatic discovery of the required libraries isn't something makefiles are generally able to do. That's why tools like autoconf exist. Or maybe Cmake's more advanced features could do it? But if you also desire a small and simple makefile that's easy to read, I'm afraid seamlessly supporting all .ino files which include libraries with such a simple makefile is an impossible dream.
    Apr 2018
    Eastern Time, USA
    163
    Hi Paul, I thought I replied earlier but perhaps I forgot to click post. So apologies if this is a repeat.
    Is there a makefile that I could crib from? My includes are ADC.h, EEPROM.h and kinetis.h.
    When I started down this path, I was hoping the IDE would be capable of generating a makefile.
    Apr 2018
    Eastern Time, USA
    163
    Has anybody tried this:
    https://github.com/sudar/Arduino-Makefile
    It has a Teensy.mk
    Apr 2018
    Eastern Time, USA
    163
    A possible solution, command line arduino
    I found a possible answer, here
    https://forum.arduino.cc/index.php?topic=713456.0
    The following command seems to work, in so far as uploading or verifying,
    # arduino  --pref compiler.cpp.extra_flags=-Dsomething   [ --verify | --upload ]  myfile.ino
    The reply there says the --pref argument, compiler.cpp.extra_flags..., needs to be replaced by
    teensy41.build.flags.defs=-D__IMXRT1062__ -DTEENSYDUINO=153 -Dmyflag
    I am not sure what the specifics should be for the Teensy 3.2, and I have not checked whether the macro is being set.
    Can anyone clarify this, or suggest the exact command line for the Teensy 3.2?
    Germany
    1,594
    Maybe I misunderstand something, but couldn't you simply call the arduino builder? Here a makefile I generated for you with VisualTeensy in "Ino-mode". The makefile is for Win10. Depending on the OS you are using you might need to adjust paths backslashes shell commands etc.
    The important things is the FQBN. You find information how to assemble this online. Since this makefile uses the builder it will behave exactly as the IDE (which also uses the builder). I.e. it will compile *.inos, auto resolve the libraries etc...
    # Generated by VisualTeensy (https:\\github.com\luni64\VisualTeensy)
    # Board              Teensy 3.2 \ 3.1
    # USB Type           Serial
    # CPU Speed          96 MHz (overclock)
    # Optimize           Faster
    # Keyboard Layout    US English
    # 15.11.2020 15:19
    SHELL            := cmd.exe
    export SHELL
    SKETCH_NAME      := ttt_motor.ino
    BOARD_ID         := TEENSY32
    MCU              := mk20dx256
    BUILDER_BASE     := "C:\Program Files\Arduino\arduino-1.8.12"
    FLAGS            := -verbose=1 -warnings=all
    FQBN             := teensy:avr:teensy31:usb=serial,speed=96,opt=o2std,keys=en-us
    BUILD_PATH       := "C:\Users\lutz\source\Teensy\TeensySupport\ttt_motor\.vsteensy\build"
    BUILD_CACHE      := "C:\Users\lutz\source\Teensy\TeensySupport\ttt_motor\.vsteensy\cache"
    HARDWARE         := -hardware="C:\Program Files\Arduino\arduino-1.8.12/hardware"
    TOOLS            := -tools="C:\Program Files\Arduino\arduino-1.8.12\tools-builder"
    LIBRARIES        := -built-in-libraries="C:\Program Files\Arduino\arduino-1.8.12/libraries"
    LIBRARIES        := -libraries="C:\Users\lutz\Documents\Arduino\libraries"
    UPL_PJRC_B       := C:\PROGRA~1\Arduino\ARDUIN~1.12\hardware\tools
    UPL_TYCMD_B      := C:\toolchain\TyTools
    UPL_CLICMD_B     :=
    TARGET_HEX       := $(BUILD_PATH)/$(SKETCH_NAME).hex
    # BINARIES
    BUILDER     := $(BUILDER_BASE)/arduino-builder
    UPL_PJRC    := "$(UPL_PJRC_B)/teensy_post_compile" -test -file=$(SKETCH_NAME) -path=$(BUILD_PATH) -tools="$(UPL_PJRC_B)" -board=$(BOARD_ID) -reboot
    UPL_TYCMD   := $(UPL_TYCMD_B)/tyCommanderC upload $(TARGET_HEX) --autostart --wait --multi
    UPL_CLICMD  := $(UPL_CLICMD_B)/teensy_loader_cli -mmcu=$(MCU) -v $(TARGET_HEX)
    .PHONY:  all upload uploadTy uploadCLI clean
    all:
    	$(BUILDER) $(FLAGS) -build-path=$(BUILD_PATH) -build-cache=$(BUILD_CACHE) -fqbn=$(FQBN) $(HARDWARE) $(TOOLS) $(LIBRARIES) $(SKETCH_NAME)
    upload: all
    	$(UPL_PJRC)
    uploadTy: all
    	@$(UPL_TYCMD)
    uploadCLI: all
    	@$(UPL_CLICMD)
    clean:
    	@echo Cleaning user binaries...
    	@if exist .vsteensy\build rd /s/q .vsteensy\build
    	@md .vsteensy\build
    	@if exist .vsteensy\cache rd /s/q .vsteensy\cache"
    	@md .vsteensy\cache
    	@echo done
    9,425
    Probably the best way to answer some questions like this, is to simply run the Arduino build and see what command lines that are used.
    That is go in to preferences and turn on verbose compile and verbose upload and see what all of the commands are that are generated.
    You can also deduce what some of these settings would be by looking at the file boards.txt that Teensyduino installs for your specific board.
    Germany
    1,594
    I just saw that you want to pass additional defines to the compiler. This can also be done easily but you need to tweak platform.txt a little bit. Scroll down to the ##compile c++ files section and add {build.extra_flags} to the recipe (unfortunately the stock platform.txt doesn't define this).
    ## Compile c++ files
    recipe.cpp.o.pattern="{compiler.path}{build.toolch ain}{build.command.g++}" -c {build.extra_flags} {build.flags.optimize} {build.flags.common} {build.flags.dep} {build.flags.cpp} {build.flags.cpu} {build.flags.defs} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DF_CPU={build.fcpu} -D{build.usbtype} -DLAYOUT_{build.keylayout} "-I{build.path}/pch" {includes} "{source_file}" -o "{object_file}"
    With that, you can pass additional flags to the compiler by adding the -prefs option to the builder command line. Here a quick hack in the makefile from above (of course that should be done with some variables...)
    # BINARIES
    all:
    	$(BUILDER) $(FLAGS) -prefs=build.extra_flags=-DMY_DEFINE=42 -build-path=$(BUILD_PATH) -build-cache=$(BUILD_CACHE) -fqbn=$(FQBN) $(HARDWARE) $(TOOLS) $(LIBRARIES) $(SKETCH_NAME)
    And here a part of the compile output which shows that MY_DEFINE is actually passed to the compiler:
    sy\\TeensySupport\\ttt_motor\\.vsteensy\\build\\sketch\\ttt_motor.ino.cpp" -o "C:\\Users\\lutz\\source\\Teensy\\TeensySupport\\ttt_motor\\.vsteensy\\build\\sketch\\ttt_motor.ino.cpp.o"
    "C:\\Program Files\\Arduino\\arduino-1.8.12\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -DMY_DEFINE=42 -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=154 -DARDUINO=10600 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\lutz\\source\\Teensy\\TeensySupport\\ttt_motor\\.vsteensy\\build/pch" "-IC:\\Program Files\\Arduino\\arduino-1.8.12\\hardware\\teensy\\avr\\cores\\teensy3"
    Hope that helps...
    Apr 2018
    Eastern Time, USA
    163
    @KurtE that sounds like a simple approach, I was thinking along those lines, but did not find the switch for verbose in the gui.
    @luni that seems very interesting. Are build_path and build_cache specific to your project? I just have one ino file, with includes for adc and eeprom. Is there not a simple one liner for that using the arduino command?
    Germany
    1,594
    Honestly, I don't understand the question. This
    obviously IS a simple one liner? I'm afraid it won't get any simpler than calling the arduino builder with a bunch of parameters. It obviously needs some information about where to find libraries, tools, where to place the binaries and for which board and board settings it should compile. Here https://github.com/arduino/arduino-builder the doc about the available parameters.
    Of course you need to adjust the paths and parameters to your environment. The makefile I posted above obviously uses my setup but since you mentioned that you are familiar with makefiles I assumed that it shouldn't be difficult to translate to your environment. You can also call the builder manually from the shell or from a bash script if you prefer. Just give it the correct parameters and it will compile your inos. You can compile for your different boards/options by simply calling the builder with different FQBNs. I suggest to also use a different build_path per board to have the hex files separated.
    Apr 2018
    Eastern Time, USA
    163
    @luni
    You have these lines in your make file. I am wondering how they would translate to my project, or if they are needed.
    Germany
    1,594
    These define where the builder stores the binaries and the cache file. You can choose any path you like for them. Did you read the documentation I linked in the last post?
    Apr 2018
    Eastern Time, USA
    163
    What? Read the document?
    Actually, i didn't notice the link. I'll take a look at it. Thank you
    Senior Member manicksan's Avatar
    Jun 2020
    Sweden
    294
    as you stated in post Yesterday, 02:53 PM #14
    why not use this mode of Arduino IDE?
    they have some undocumented arguments as well
    look at:
    https://github.com/arduino/Arduino/b...ineParser.java
    there is for example a --buildpath argument that you can use to select where the output files should go,
    using this makes it easier to debug some stuff
    to use the buildpath the directory must exist before running arduino --buildpath [path]
    and the build flags should be:
    --pref build.flags.cpp=
    or
    --pref teensy41.build.flags.cpp=
    if you want to specify the target
    if you look at hardware\teensy\avr\boards.txt in arduino install folder
    you can see the build flags there
    in windows you should use arduino_debug instead of arduino if you want to see any output
    also using the --verbose argument shows compile outputs
    example: on windows 10 (verified)
    arduino_debug --verbose --board teensy:avr:teensy40 --pref "build.flags.cpp=-D USB_MIDI_AUDIO_SERIAL -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing" --verify sketch_oct10a.ino
    example: on ubuntu (verified)
    arduino --verbose --board teensy:avr:teensy40 --pref 'build.flags.cpp=-D USB_MIDI_AUDIO_SERIAL -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing' --verify sketch_oct10a.ino
    Germany
    1,594
    Isn't it a bit tedious and error prone to read out all those flags from boards.txt manually? Also some of those flags have dependencies which makes it even more complicated. The builder extracts them automatically by providing the FQBN. You just need to add your additional flags. Maybe your Arduino command also supports FQBNs instead of the raw defines?
    Jun 2020
    Sweden
    294
    I just wanted do describe where I found the "build.flags.cpp" flag from
    I did some testing and found out that you should use it like this:
    on windows
    arduino_debug --verbose --board teensy:avr:teensy40:usb=serialmidiaudio --verify sketch_oct10a.ino
    on ubuntu/linux also maybe macos
    on macos catalina (here it needs the buildpath otherwise teensyloader was not able to read the .hex file)
    note that you need to create the buildTemp folder beforehand,
    also the GUI splash screen seems to load with all initiations included which means it's taking longer time
    '/Applications/Teensyduino.app/Contents/MacOS/Arduino' --verbose --board teensy:avr:teensy40:usb=serialmidiaudio --buildpath ~/Documents/Arduino/buildTemp --verify ~/Documents/Arduino/sketch_oct18b/sketch_oct18b.ino
    so the build flag is not needed (only if you want to use additional global include files/global definitions)
    I was missing the usb=mode
    where mode can be: (yet again taken from the boards.txt file)
    mode          description (as in the menu)
    serial
    serial2       Dual Serial
    serial3       Triple Serial
    keyboard
    touch         Keyboard + Touch Screen
    hidtouch      Keyboard + Mouse + Touch Screen
    hid           Keyboard + Mouse + Joystick
    serialhid     Serial + Keyboard + Mouse + Joystick
    midi
    midi4
    midi16
    serialmidi
    serialmidi4
    serialmidi16
    audio
    serialmidiaudio
    serialmidi16audio
    mtp                 MTP Disk (Experimental)
    rawhid
    flightsim
    flightsimjoystick
    disable
