Hi
I am having problems with can messages
i designed a car screen with nextion and teensy 3.2
It has worked quite well for me with different can IDs.
the problem is that I want to send multiple streams id for the same id of can that is to say that for an id of 1000 for example I can be receiving many messages using a byte with an id in each message
currently i have been using it like this
if ( CANbus.read(rxmsg) ) {
switch (rxmsg.id){
case 1000:
FAULT = (float)(rxmsg.buf[0]);
FAULTCOUNT = (float)(rxmsg.buf[1]);
FAULTCODES = (float)(rxmsg.buf[2]);
VANALOGSUPPLY = (float)(rxmsg.buf[3]);
AUX9_10STATUS = (float)(rxmsg.buf[4]);
DATAFLASHCHKSUM = (float)(rxmsg.buf[5]);
FUELCALC = (float)(rxmsg.buf[6]);
HWBLOCK1 = (float)(rxmsg.buf[7]);
now I want the id to be 1000 all the time but for rxmsg.buf [0] to contain the id of the message, in the ecu I use I can tell you that the id of the frame is 1 for example and assign it to byte 0
I have tried like this but it is not working for me
switch (rxmsg.buf[0]){
case 1:
somebody could help me?
thanks!
switch (rxmsg.id){
case 1000:
case 1:
thanks!
