// Converted from the WavFilePlay from the Teensy release:
// hardware/teensy/avr/libraries/Audio/examples/WavFilePlayer/WavFilePlayer.ino
// Simple RAW file player example for the prop shield to use the Analog DAC
// and prop shield amplifier to play mono sounds.
// http://www.pjrc.com/teensy/gui/?info=AudioOutputAnalog
// On the prop shield, pin 6 selects the serial flash memory controller,
// and pin 5 enables the amplifier.
AudioPlaySerialflashRaw playFlashRaw1; //xy=149,388
AudioMixer4 mixer1; //xy=445,386
AudioOutputAnalog dac1; //xy=591,379
AudioConnection patchCord1(playFlashRaw1, 0, mixer1, 0);
AudioConnection patchCord2(mixer1, dac1);
#define PROP_AMP_ENABLE 5
#define FLASH_CHIP_SELECT 6
#define VOLUME_POT A1
// wait up to 3 seconds for the Serial device to become available
long unsigned debug_start = millis ();
while (!Serial && ((millis () - debug_start) <= 3000))
Serial.println ("Start prop shield RAW player");
// Enable the amplifier on the prop shield
pinMode(PROP_AMP_ENABLE, OUTPUT);
digitalWrite(PROP_AMP_ENABLE, HIGH);
// Audio connections require memory to work. For more
AudioMemory(8);
// Set initial volume
// mixer1.gain(0, 0.5f);
// uncomment these lines if you have a potentiometer or trimpot
// on the pin A1 to control the volume, and comment out the
// above line
float vol = analogRead(VOLUME_POT);
mixer1.gain(0, vol / 1024.0f);
// Start SerialFlash
if (!SerialFlash.begin(FLASH_CHIP_SELECT)) {
while (1)
Serial.println ("Cannot access SPI Flash chip");
delay (1000);
Serial.print("Playing file: ");
Serial.println(filename);
// Start playing the file. This sketch continues to
// run while the file plays.
playFlashRaw1.play(filename);
// A brief delay for the library read RAW info
delay(5);
// Simply wait for the file to finish playing.
while (playFlashRaw1.isPlaying()) {
playFile("SDTEST1.RAW"); // filenames are always uppercase 8.3 format
playFile("SDTEST2.RAW");
playFile("SDTEST3.RAW");
playFile("SDTEST4.RAW");
delay(1500);
