Results 1 to 3 of 3
Thread: AudioEffectChorus issue
    May 2020
    9
    I have configured the AudioEffectChorus as follows:
    //buffer delay
    short delayBuffer[AUDIO_BLOCK_SAMPLES*2];
    //in the setup()
    chorus1.begin(delayBuffer,AUDIO_BLOCK_SAMPLES*2,2) ;
    then I change the voices parameter from 1 to 8 in real time and I don't hear the sound change anything.
    Am I doing it the right way or am I missing something?
    Jul 2020
    680
    You want about 50ms delay, try 8*AUDIO_BLOCK_SAMPLES
    With 2 blocks worth of delay that's about the same delay as speaker multipath in a standard room, so
    its probably just going to acoustically enlarge the room slightly.
    May 2020
    9
    AudioEffect is a bit strange. The Chorus that I have seen usually have as parameters the number of voices, but also the type of LFO and the rate of the LFO
