defragster
Senior Member+
Good luck with the next set.
For sanity - power the new T_3.6 and watch it blink.
Then carefully get the 3.3V and GND to the pot and the middle line to one of the analog pins - A3 as in the sketch above - and run that to see the results.
Not sure if you are ordering it pinned? Probably not for use with Audio board.
Not good for real use - but with unpowered Teensy and solid wire ends through the pin holes and folded for secure decent 'contact' with just the pin hole plating then add power and the sketch and look for results.
