Results 1 to 8 of 8
Thread: SD Socket / Footprint
    Sep 2020
    16
    I want to integrate the Audio Shield into a custom board.
    Does anybody know what SD socket is used?
    Maybe with a footprint for Target or KiCad?
    Or at best: Is there a PCB layout (Target or KiCad) available for the Audio Shield?
    Germany
    7,612
    You can use any - they need to be compatible to SD - not Teensy
    Just make your layout compatible to the socket you use.
    Sep 2020
    16
    I don't want to be insolent....
    Can you tell me how to connect Pin 10..13 from Teensy to the SD-Card (DAT2, DAT3/CD, CMD, CLK, DAT0, DAT1)?
    Germany
    7,612
    You can find the schematics on this page: https://www.pjrc.com/store/teensy3_audio.html
    Does this answer your question ?
    I use Eagle - the SD-Socket-Libs show the pins (names).. I guess it's the same for Target or Kicad(?)
    Germany
    7,612
    Sep 2020
    16
    The second link helps a lot, thank you!
    My diagram looks like:
    Teensy <----> SD Socket
    10-(CS) <---> 2(CS)
    11-(MOSI) <---> 7(DAT0, Data Out)
    12-(MISO) <---> 3(CMD, Data In)
    13-(SCK) <---> 5(CLK)
    I'm not really sure about MOSI&MISO. Are they connected MOSI to Data Out(like above) or are they being crossed?
    23,432
    Maybe this diagram of the connector we use on the audio shield and Teensy 3.5, 3.6, 4.1 can help?
    This is a top view where the SD card inserts from the right hand side with its pins facing down.
    SO means MISO
    SI means MOSI
    Here's a nice pinout diagram I found with a quick Google search which might help you visualize together with the connector.
    Sep 2020
    16
    The right connection is:
    Teensy4.0 <----> SD Socket
    10-(CS) <---> 2(CS)
    11-(MOSI) <---> 3(CMD, Data In)
    12-(MISO) <---> 7(DAT0, Data Out)
    Thank you Paul, thank you Frank!
