Neutronned
Something a little different from my prior audio/LED projects - an inexpensive 241 LED circular array, driven by a Teensy 3.2 to create a pseudo plasma effect. I printed an enclosure with translucent PLA and the infill pattern diffuses the LEDs such that the light smears out in interesting patterns. Simple design, simple code and really nice effect.
// Ring Panel - a simple audio device that utilizes 241 LEDs in concentric rings.
// A Teensy 3.2 + the Teensy Audio Adapter is utilizes to sample the incoming
// stereo audio signal and generate the color pattern to be displayed. The left
// and right channels are mixed then run through the Teensy FFT audio library
// function to get 512 frequency bins of level information. The color pattern
// sums two adjacent bins (0+1, 1+2, etc.) to create a level value that controls
// the brightness of each of the 241 pixels. The display start with the lower
// frequencies in the center and moves outward.
// Note that the ring is mounted in a translucent 3D printed case that diffuses
// the LED output, creating a simulated plasma effect.
// Based on sample code from Adafruit and prior Teensy projects
// Rev 1.0 - Nov 18, 2020
#include <Adafruit_NeoPixel.h>
// ************************************************** * LED PARAMETERS
// pins on the Teensy that are connected to the NeoPixel strings
#define RING_LED_PIN 6
// Number of NeoPixels in each string
#define RING_LED_COUNT 241 // 241 LEDS in the ring
// Declare the two NeoPixel strip objects:
Adafruit_NeoPixel ring(RING_LED_COUNT, RING_LED_PIN, NEO_GRB + NEO_KHZ800);
// Argument 1 = Number of pixels in NeoPixel strip
// Argument 2 = Arduino pin number (most are valid)
// Argument 3 = Pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
// NEO_RGBW Pixels are wired for RGBW bitstream (NeoPixel RGBW products)
#define BRIGHTNESS 64 // default brightness
// ************************************************** * AUDIO ADAPTER PARAMETERS
const int my_input = AUDIO_INPUT_LINEIN; // use line input from adapter board
AudioInputI2S linein; //The line input pads on the Audio Adapter
AudioMixer4 mixer; // mix the L & R channels
AudioAnalyzeFFT1024 my_FFT; // Compute a 1024 point FFT
AudioConnection patchCord1(linein, 0, mixer, 0); // send L to mixer input 0
AudioConnection patchCord2(linein, 1, mixer, 1); // send R to mixer input 1
AudioConnection patchCord3(mixer, my_FFT); // send mixed signal to FFT object
AudioOutputI2S audio_output; // output to the adapter's headphones & line-out
AudioControlSGTL5000 audio_adapter; // object for audio adapter control signals
int colorBase = 0; // the last color wheel position value for the head LEDs
int pixelHue = 0 ; // value of the calculated color
byte saturation = 255 ;
byte bright = 0 ;
// ************************************************** ******************** SETUP
delay(1000); // 1 sec delay on power up or reset - let's voltages stabilize
// configure the LED ring
ring.begin(); // initialize the NeoPixel object
ring.show(); // Turn off all pixels
ring.setBrightness(BRIGHTNESS); // Set default brightness
// configure the Audio adapter
// Audio connections require memory to work. For more
AudioMemory(12);
// Enable the audio shield and set the output volume.
audio_adapter.enable();
audio_adapter.inputSelect(my_input);
audio_adapter.volume(0.5);
// Configure the window algorithm to use for the FFT
my_FFT.windowFunction(AudioWindowHanning1024);
// FFT ************************************************** ****************** FFT
// FFTs are sampled in the background, so process when done
if (my_FFT.available()) {
// the FFT function creates 512 discrete frequency bins.
// LED Display ************************************************** ** LED Display
for (int i = 0; i < RING_LED_COUNT; i++){ // cycle through the ring LEDs
// this will shift the colors
colorBase++;
// calculate the color - somewhat hand-tuned
pixelHue = ((colorBase + (i * 65536L / RING_LED_COUNT)) % 65536L);
// set brightness based on the summed levels of two adjacent frequency bins
// 50 is set as minimum so the LEDs are just barely on at low audio levels
bright = 50 + 215 * my_FFT.read(i*2, i*2+1) * (i / 5);
// set the specfic LED to the calculated color and brightness
ring.setPixelColor(RING_LED_COUNT - i - 1, ring.gamma32(ring.ColorHSV(pixelHue, saturation, bright)));
// all new LED values are set - time to display them!
ring.show();
