Hello all, I am in the process of converting my Arduino project to Teensy 4.1. I had actually had to halt the Arduino version because I quickly ran out of program memory for what I wanted to do. I found an ordered the Teensy 4.1 and have plenty of room to work with.
Everything, so far, works, the reason I am posting before going further is because I am fairly new to C, maybe about 2 years tinkering with an Uno. I think there may be an easier way to get things organized or some tricks that only a well experienced c programmer can know. I would like to store, and retrieve, some variables/setting in flash but couldn't in the Arduino version because of some bug/restriction in progmem preventing the possibility of doing that. Is this also prevented in Teensy 4.1? I would prefer that as opposed to SD storage.
I intend on altering the code to use more descriptive names than Page1, Page2, etc...
The font is written to screen using rows/columns based on font size, I think this could be more dynamic/universal and maybe added to a driver/library if it is not already done.
I appreciate all criticism! Here is my Code (2 files)
The second file is just for colors I didn't realize were already in the library
Any guidance would be appreciated.
Thank you in advance,
Jorge
ILI9341 W/Touch
By: japreja (Jorge Joaquin Pareja)
Version 1.0 - Basic screen and Option screen layout and setup
Parts Used:
* Teensy 4.1 - [URL]https://www.pjrc.com/store/teensy41.html[/URL]
* ILI9341 Display - [URL]https://www.amazon.com/gp/product/B087C3PP9G/[/URL]
Wiring is exactly as depicted on [URL]https://www.pjrc.com/store/display_ili9341_touch.html[/URL]
With this display and the smallest font, 6x8, we can get a total of 30 lines and 53 columns
of text with 1 pixel in between each letter. 6x53=318 and 2 pixels left over, 8x30=240 and
no pixels left over, provided that the width is the widest measurement of the display.
By defining:
screenWidth=320
screenHeight=240
fntWidth=6
fntHeight=8
we can use some simple division to determine the line and column to start writing on so
our letters dont overlap.
//#include <Adafruit_GFX.h>
#include <ILI9341_t3.h>
#include <XPT2046_Touchscreen.h>
#include "namedColors.h"
// This is calibration data for the raw touch data to the screen coordinates
#define TS_MINX 350
#define TS_MINY 300
#define TS_MAXX 3900
#define TS_MAXY 3800
// Device chip select pins
#define XPT_CS 8
#define TFT_CS 10
XPT2046_Touchscreen ts(XPT_CS);
// TFT Data/Command pin
#define TFT_DC 9
/// JJP Code follows, different display sizes will require modifications of this code, also
/// if you change the orientation.
const int screenWidth = 320;
const int screenHeight = 240;
//Font properties
const int fntWidth = 6;
const int fntHeight = 8;
// Screen Properties (Dynamicly created with values above)
const int screenMaxCharsPerLine = screenWidth/fntWidth;
const int screenMaxLines = screenHeight/fntHeight;
// padding in pixels, incase font is slightly off screen
const int cpadding = 0; //Column Padding
const int rpadding = 0; // Row/Line Padding
// 53 Columns (0 to 52) and 30 Rows (0 to 29) on a 320x240 display. I use this for calculating the
// columns for text placement using setCursor, default font 6x8!
int tftCol[screenMaxCharsPerLine];
int tftRow[screenMaxLines];
void cls(int color, int rotation, int tsRotation); // Set some defaults
// Menu Settings and Variables
byte mIndex = 5; // Menu/Page index
byte pIndex = 5; // previous page index
byte cIndex = 5; // current page index, 5 is currently default for main menu/screen
String sversion = "V1.0";
String sYes = "Yes";
String sNo = "No";
void setup(void){
tft.begin();
ts.begin();
// setup easy access for text positions
for (byte i = 0; i < screenMaxCharsPerLine; i++){
tftCol[i] = (cpadding+(i*fntWidth));
for (byte i = 0; i < screenMaxLines; i++){
tftRow[i] = (rpadding+(i*fntHeight));
tft.fillScreen(c_black);
// set the text color, and the background color so that new text will cover over any old text
// without having to blank the entire screen
tft.setTextColor(c_white, c_black); // white text on black background, prevents having to redraw the entire screen, just overwrite a location with spaces
tft.setTextWrap(false); // disable wrapping of text
cls(c_black, 3, 1); // cls(color, screen orientation, touchscreen orientation)
void loop(){
layoutScreen();
/* CUSTOM FUNCTIONS BELOW
* From my previous code for a 128x128 screen
void checkTouch(){
if(ts.bufferEmpty()){
return;
// just testing, menu is not yet selectable
TS_Point p = ts.getPoint();
p.x = map(p.x, TS_MINX, TS_MAXX, 0, screenWidth);
p.y = map(p.y, TS_MINY, TS_MAXY, 0, screenHeight);
String sx = "X = " + String(p.x) + " ";
String sy = "Y = " + String(p.y) + " ";
pl(sx, 14, 10);
pl(sy, 15, 10);
void layoutScreen(){
drawMenu(mIndex);
switch(mIndex){
case 1:
Page1();
case 2:
Page2();
case 3:
Page3();
case 4:
Page4();
case 5:
Page5();
default:
Page5();
void Page1(){
tft.setTextColor(c_black, c_yellow);
pl("Page 1", 2, 0);
void Page2(){
pl("Page 2", 2, 0);
void Page3(){
pl("Page 3", 2, 0);
void Page4(){
pl("Page 4", 2, 0);
void Page5(){ // Main Screen Page
pl("Page 5 - Startup Screen", 2, 0);
checkTouch();
void drawMenu(byte index){
String page0 = " P1 ";
String page1 = " P2 ";
String page2 = " P3 ";
String page3 = " P4 ";
cIndex = index;
tft.setTextColor(c_white, c_blue);
if(pIndex != cIndex)
cls(c_black, 3, 1);
pIndex = cIndex;
if(index == 1)
tft.setTextColor(c_black, c_red);
pl(page0, 0, 1);
pl(page1, 0, 6);
pl(page2, 0, 11);
pl(page3, 0, 16);
else if(index == 2)
pl(page0, 0, 1);
pl(page1, 0, 6);
pl(page2, 0, 11);
pl(page3, 0, 16);
else if(index == 3)
pl(page0, 0, 1);
pl(page1, 0, 6);
pl(page2, 0, 11);
pl(page3, 0, 16);
else if(index == 4)
// Page 4
pl(page0, 0, 1);
pl(page1, 0, 6);
pl(page2, 0, 11);
pl(page3, 0, 16);
else if(index == 5)
// menu item not selected
pl(page0, 0, 1);
pl(page1, 0, 6);
pl(page2, 0, 11);
pl(page3, 0, 16);
void uprint(String txt, int fg_color, int bg_color, int lineNumber, int columnNumber){
tft.setTextColor(fg_color, bg_color);
pl(txt, lineNumber, columnNumber);
// Print a string based on line and column number calculated in the arrays
void pl(String txt, int lineNumber, int columnNumber){
tft.setCursor(tftCol[columnNumber], tftRow[lineNumber]);
tft.print(txt);
// Clear the screen with screen rotation
void cls(int color = c_black, int rotation = 3, int tsRotation = 1){
tft.setRotation(rotation);
ts.setRotation(tsRotation);
tft.fillScreen(color);
#define c_black 0x0000
#define c_white 0xFFFF
#define c_red 0xF800
#define c_green 0x07E0
#define c_blue 0x001F
#define c_cyan 0x07FF
#define c_magenta 0xF81F
#define c_yellow 0xFFE0
#define c_orange 0xFC00
// from https://cgit.freedesktop.org/xorg/app/rgb/tree/rgb.txt
// converted with http://www.rinkydinkelectronics.com/calc_rgb565.php
#define c_AliceBlue 0xF0F8FF
#define c_Snow 0xFFFAFA
Jorge
