Page 3 of 9 FirstFirst 1 2 3 4 5 ... LastLast
Results 51 to 75 of 207
Thread: Teensyduino 1.54 Beta #5
  1. #51
    3,060
    Looks like many of them would be easy to get awy from. Looks like many/most of them are under some form of #if to either RASPI or windows..
    the ones <time.h> or "time.h" are probably genuine system libraries while "Time.h" should be changed, and then one can get rid of the "Time.h" file
  2. #52
    7,928
    Most if not all of them will just work when deleting Time.h
    Even "TimeAlarms" seems to use it in the readme only?!? (did not look at the sourcecode)
  3. #53
    7,928
    @Paul, if you add a check to the 1.54 installer that allows an empty target directory (or at least an empty "... hardware/teensy/" directory) only, this would be way to have a clean install - (and you can get rid of Time.h) without having to delete something.
  4. #54
    23,731
    I completed the upgrade to MacOS Big Sur 11.0.1. Sure enough, just as Theremingenieur said in msg #40, this latest beta runs fine on Big Sur. Here's a screenshot from my freshly updated 13 inch Macbook Air.
    @daj59 - Did you try looking at the System Preferences > Security & Privacy settings, as I suggested on msg #43, to check if you've accidentally disallowed Teensyduino access to Documents or other things it needs?
  5. #55
    Jul 2019
    9
    Many thanks,
    The problem is updating to beta 11.1, it did indeed work fine on 11.01 release.
    I will wait till the next release, currently there are a few other things not working quite right apart from teenysduino, I might come off the beta program.
    David
    PaulStoffregen;261844]I completed the upgrade to MacOS Big Sur 11.0.1. Sure enough, , this latest beta runs fine on Big Sur. Here's a screenshot from my freshly updated 13 inch Macbook Air.
  6. #56
    23,731
    Ah, now I see. Today was my very first use of MacOS Big Sur. When I read msg #30 "latest big sur 11.1", I didn't manage to equate "11.1" to mean a beta version.
    I am going to keep support for MacOS, but I'm drawing the line at testing with Apple's betas. There's far too much work to do on the Teensy side to mess with those.
    In other news, it seems rEFInd Boot Manager is incompatible with Big Sur.
  7. #57
    Feb 2014
    Colmar, France
    2,598
    As I said in msg#40, the same applies to the 11.1 beta which is running here and which allowed me to take the screenshots of a working Teensyduino installation.
    But I second Paul, it's a waste of time to test at least with early Apple betas. I've too often seen that things were newly introduced first and then removed in later betas. And that's why Apple tells everybody to not install betas on production machines
  8. #58
    13,428
    @Paul - the teensy Command line utilty was updated for T_4.x - but presented text still suggest: "The usage text does say it's just for the 3.x series"
    I've seen two posts in recent days - it may be the download page or text in the code or both?
  9. #59
    23,731
    Updated the usage info.
    https://github.com/PaulStoffregen/te...dd80acd510c5bf
  10. #60
    Feb 2014
    Colmar, France
    2,598
    And everything works still in the (only hours old) Big Sur 11.1 beta 2 :
  11. #61
    23,731
    Unrelated to Teensy, I'm going to be happy when Apple releases 11.1. The bright red background on 11.0 kinda hurts my eyes. Yeah, I know it can be changed in System Preferences - but for the sake of screenshots while testing I always leave the default background.
    I'm still hoping to put off buying yet another Mac machine until the 2nd gen M1 chip.
  12. #62
    Feb 2014
    Colmar, France
    2,598
    I’m afraid you will be disappointed, Paul. 11.1 has by default still the red background. To protect myself from getting eye cancer, I replaced it manually...
  13. #63
    13,428
    A new Announcements Thread was created : TeensyDuino-New-Release-Thread-Subscribe-for-notice-of-future-releases
    When a New release of TeensyDuino is made an Admin can add a post like:
    TeensyDuino 1.53 has been released.
    For release notes and added information see :: pjrc.com/...Teensyduino-1-53-Released
    If seeing this email would be of interest then go to thread TeensyDuino-New-Release-Thread-Subscribe-for-notice-of-future-releases
    and :: Click Thread Tools and select : "Subscribe to this thread ..."
    >> It is a closed thread so it won't get pinged except for Admin release notes
  14. #64
    13,428
    @Paul - what's up with included lib :: T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\Adafruit_ NeoPixel
    Of course the raw Adafruit version does not work on Teensy, and of course they are updating it to include NRF's and whatever CPU of the month etc. And of course I got some of their NRF's so they put the LIB in sketchbook\libraries - and the build used it.
    I got this 8 strip : protosupplies.com/.../ws2812-addressable-rgb-led-stick-module/
    CODE sample there uses : #include <Adafruit_NeoPixel.h>
    I removed the sketchbook\libraries copy of the updated library.
    But sample code calls things in an updated version so build breaks not having ColorHSV, gamma32 : strip.setPixelColor(i, strip.gamma32(strip.ColorHSV(pixelHue)));
    I got the strip working removing the gamma32 and making an INO local unClass'y copy of : uint32_t ColorHSV(uint16_t hue, uint8_t sat, uint8_t val) {
    It is working with hacked in (..., sat, val ) params like :: strip.setPixelColor(i, ColorHSV(pixelHue, 127, 127 ));
    Actual Errors using linked code from product:
    -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=154 -DARDUINO=10600 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IT:\\TEMP\\arduino_build_ws2812_leds.ino/pch" "-IT:\\arduino-1.8.13_t54\\hardware\\teensy\\avr\\cores\\teensy3" "-IT:\\arduino-1.8.13_t54\\hardware\\teensy\\avr\\libraries\\Adafruit_NeoPixel" "T:\\TEMP\\arduino_build_ws2812_leds.ino\\sketch\\ws2812_leds.ino.cpp" -o "T:\\TEMP\\arduino_build_ws2812_leds.ino\\sketch\\ws2812_leds.ino.cpp.o"
    T:\tCode\LEDS_WS\ws2812_leds\ws2812_leds.ino: In function 'void rainbow(int)':
    T:\tCode\LEDS_WS\ws2812_leds\ws2812_leds.ino:68:36: error: 'class Adafruit_NeoPixel' has no member named 'gamma32'
    T:\tCode\LEDS_WS\ws2812_leds\ws2812_leds.ino:68:50: error: 'class Adafruit_NeoPixel' has no member named 'ColorHSV'
    T:\tCode\LEDS_WS\ws2812_leds\ws2812_leds.ino: In function 'void theaterChaseRainbow(int)':
    T:\tCode\LEDS_WS\ws2812_leds\ws2812_leds.ino:83:32: error: 'class Adafruit_NeoPixel' has no member named 'gamma32'
             uint32_t color = strip.gamma32(strip.ColorHSV(hue)); // hue -> RGB
    T:\tCode\LEDS_WS\ws2812_leds\ws2812_leds.ino:83:46: error: 'class Adafruit_NeoPixel' has no member named 'ColorHSV'
    Using library Adafruit_NeoPixel at version 1.1.7 in folder: T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\Adafruit_NeoPixel
    exit status 1
    Reading the product page it notes:
    The program below uses the Adafruit NeoPixel library to exercise the stick.  It is a shortened version of the strandtest example program that is installed when the library is downloaded
    Using the Strandtest.INO of course works from the library installed with TeensyDuino 1.54b5 - given right pin # and # LEDS
  15. #65
    8,457
    I just happen to have an 8 led setup on my desk...
    Note: I have not tried the version installed by Teensyduino in awhile but instead have the Adafruit version installed.
    I ran the simple strand test with T3.6 and it runs. Note the Strandtest does not appear to play with all 8 of these LEDS when I set it to 8 count, works OK with set to 16...
    Next will try with T4.1... Appears to be working.
    May next check with Teensy version of library.
    EDIT - I removed the Adafruit version from my library folder and loaded up the strand test from the Teensy and it appears to run.
    @Paul - I am wondering if you wish for one of us to sync up to the Adafruit current code and/or do like some of the display drivers and no longer install it, but instead allow users to install directly from Adafruit either by github or Library Manager ?
  16. #66
    23,731
    Yeah, it's probably time to stop including an old copy of Adafruit_NeoPixel if Adafruit's latest is working well.
  17. #67
    8,457
    Hi Paul, I probably need to do some double checking. With the 8 pixel thingy I am seeing some semi add results with pixel addressing. But not 100% sure exactly how it is configured
    #define LED_PIN    6  // Pin used to address the LEDs
    #define LED_COUNT 8   // How many NeoPixels are attached to the Arduino?
    // Declare our NeoPixel strip object:
    Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
    void step() {
      Serial.println("Press any key to continue");
      while (Serial.read() == -1);
      while (Serial.read() != -1);
    //  Initialization
      while (!Serial && millis() < 5000) ;
      strip.begin();           // INITIALIZE NeoPixel strip object (REQUIRED)
      strip.show();            // Turn OFF all pixels ASAP
      strip.setBrightness(50); // Set BRIGHTNESS to about 1/5 (max = 255)
      step();
      for (uint8_t i = 0; i < LED_COUNT; i++) {
        strip.setPixelColor(i, strip.Color(127,   0,   0));         //  Set pixel's color (in RAM)
        strip.show();                          //  Update strip to match
        step();
    And looking at the pictures(left to right top to bottom) first one turns red, second one turns green, then Bright green...
    Will rerun with T3.6... Then go back to your version to see if same? Then maybe grab another Neopixel Bar or ring I have sitting around.
    EDIT::: My mistake, did not know these were RGBW leds (Cool) , so now back to Adafruit library...
  18. #68
    8,457
    Actually I am not sure where you are grabbing the version you are putting into the releases right now? It for sure does not match what is in your github project: https://github.com/PaulStoffregen/Adafruit_NeoPixel
    The sources don't match nor the github one does not compile for T4.x...
  19. #69
    13,428
    See post #64 :: Latest ( update here dated 11/29/2020 ) :: "the raw Adafruit version does not work on Teensy"
    Question "what's up with included lib" :: Was because I tried to add the needed Class parts and got bad fails with the quick paste. Didn't go as far as 'CodeCompare' as the diffs looked significant with all the AdaF added boards just paging from the top.
    So it either needs:
    > Teensy Tweaks into AdaFruit to drop it from TD
    > AdaF Tweaks into TeensyDuino
    > or just a known deficient library.
    About once a month I spend 5 minutes thinking about the Adafruit NRF Sense / CLUE boards for a project - and Library Manager updated a Dozen or more AdaFruit libraries, so they are a moving target
  20. #70
    8,457
    Note: I have the Adafruit version installed through the library manager: 1.2.0 - The library manager does not show me any updates available on it...
    Also WinMerge of my grab of their github and the released version appear to be the same.
    I went to the website you mentioned and downloaded their sketch:
    // A basic everyday NeoPixel strip test program.
    #define LED_PIN    1  // Pin used to address the LEDs
    Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRBW + NEO_KHZ800);
    //  Initialization
    //  Main
      // Fill along the length of the strip in various colors...
      colorWipe(strip.Color(255,   0,   0), 50); // Red
      colorWipe(strip.Color(  0, 255,   0), 50); // Green
      colorWipe(strip.Color(  0,   0, 255), 50); // Blue
      // Do a theater marquee effect in various colors...
      theaterChase(strip.Color(127, 127, 127), 50); // White, half brightness
      theaterChase(strip.Color(127,   0,   0), 50); // Red, half brightness
      theaterChase(strip.Color(  0,   0, 127), 50); // Blue, half brightness
      rainbow(10);             // Flowing rainbow cycle along the whole strip
      theaterChaseRainbow(50); // Rainbow-enhanced theaterChase variant
    // Fill strip pixels one after another with a color.
    void colorWipe(uint32_t color, int wait) {
      for(int i=0; i<strip.numPixels(); i++) { // For each pixel in strip...
        strip.setPixelColor(i, color);         //  Set pixel's color (in RAM)
        delay(wait);                           //  Pause for a moment
    // Theater-marquee-style chasing lights.
    void theaterChase(uint32_t color, int wait) {
      for(int a=0; a<10; a++) {  // Repeat 10 times...
        for(int b=0; b<3; b++) { //  'b' counts from 0 to 2...
          strip.clear();         //   Set all pixels in RAM to 0 (off)
          // 'c' counts up from 'b' to end of strip in steps of 3...
          for(int c=b; c<strip.numPixels(); c += 3) {
            strip.setPixelColor(c, color); // Set pixel 'c' to value 'color'
          strip.show(); // Update strip with new contents
    // Rainbow cycle along whole strip.
    void rainbow(int wait) {
      for(long firstPixelHue = 0; firstPixelHue < 5*65536; firstPixelHue += 256) {
          int pixelHue = firstPixelHue + (i * 65536L / strip.numPixels());
    // Rainbow-enhanced theater marquee. Pass delay time (in ms) between frames.
    void theaterChaseRainbow(int wait) {
      int firstPixelHue = 0;     // First pixel starts at red (hue 0)
      for(int a=0; a<30; a++) {  // Repeat 30 times...
            int      hue   = firstPixelHue + c * 65536L / strip.numPixels();
          firstPixelHue += 65536 / 90; // One cycle of color wheel over 90 frames
    Edited it to use pin 1 and RGBW
    Build looks like using right libraries:
    ultiple libraries were found for "Adafruit_NeoPixel.h"
     Used: C:\Users\kurte\Documents\Arduino\libraries\Adafruit_NeoPixel
     Not used: C:\arduino-1.8.13\hardware\teensy\avr\libraries\Adafruit_NeoPixel
    Using library Adafruit_NeoPixel at version 1.7.0 in folder: C:\Users\kurte\Documents\Arduino\libraries\Adafruit_NeoPixel
    "C:\\arduino-1.8.13\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-size" -A "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_584113/zzz.ino.elf"
    Sketch uses 25052 bytes (0%) of program storage space. Maximum is 8126464 bytes.
    Global variables use 45748 bytes (8%) of dynamic memory, leaving 478540 bytes for local variables. Maximum is 524288 bytes.
    C:\Program Files\TyQt\TyCommanderC.exe upload --autostart --wait --multi C:\Users\kurte\AppData\Local\Temp\arduino_build_584113/zzz.ino.TEENSY41.hex
    Waiting for user selection
    and it appears to be running fine. (I also just verified that it will compile for T3.6 as well)
  21. #71
    13,428
    Opened IDE and updated Adafruit Neopixel is 1.7.0 here:
    Maybe 1.2.0 is a typo as build above shows: Using library Adafruit_NeoPixel at version 1.7.0 in folder: C:\Users\kurte\Documents\Arduino\libraries\Adafrui t_NeoPixel
  22. #72
    13,428
    More Oddity - with AdaF neopixel in and latest 1.7.0, neither of these compile to T_3.6 ::TD strandtest nor included :: T:\tCode\libraries\Adafruit_NeoPixel\examples\stra ndtest\strandtest.ino
    >> Same strip IDE compiles and runs this fine on AdaFruit NRF Bluefruit Sense with latest AdaFruit_NeoPixel lib installed.
    <EDIT>:: Doing a T_3.6 BUILD IN IDE WORKS TOO !?!?!?! Building in SubLimeText is where the error is coming from?
    This line in both errors - this from AdaFruit build with T_3.6:: starting with this > Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
    T:\TEMP\arduino_build_strandtest.ino\sketch\strandtest.ino.cpp.o: In function `rainbow(int)':
    T:\tCode\libraries\Adafruit_NeoPixel\examples\strandtest/strandtest.ino:120: undefined reference to `Adafruit_NeoPixel::ColorHSV(unsigned short, unsigned char, unsigned char)'
    T:\tCode\libraries\Adafruit_NeoPixel\examples\strandtest/strandtest.ino:120: undefined reference to `Adafruit_NeoPixel::gamma32(unsigned long)'
    T:\TEMP\arduino_build_strandtest.ino\sketch\strandtest.ino.cpp.o: In function `theaterChaseRainbow(int)':
    T:\tCode\libraries\Adafruit_NeoPixel\examples\strandtest/strandtest.ino:139: undefined reference to `Adafruit_NeoPixel::ColorHSV(unsigned short, unsigned char, unsigned char)'
    T:\tCode\libraries\Adafruit_NeoPixel\examples\strandtest/strandtest.ino:139: undefined reference to `Adafruit_NeoPixel::gamma32(unsigned long)'
    T:\TEMP\arduino_build_strandtest.ino\sketch\strandtest.ino.cpp.o: In function `__static_initialization_and_destruction_0':
    T:\tCode\libraries\Adafruit_NeoPixel\examples\strandtest/strandtest.ino:26: undefined reference to `Adafruit_NeoPixel::Adafruit_NeoPixel(unsigned short, unsigned short, unsigned short)'
    Multiple libraries were found for "Adafruit_NeoPixel.h"
     Used: T:\tCode\libraries\Adafruit_NeoPixel
     Not used: T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\Adafruit_NeoPixel
    Using library Adafruit_NeoPixel at version 1.7.0 in folder: T:\tCode\libraries\Adafruit_NeoPixel
    exit status 1
    The TeensyDuino strandtest doesn't use those new exotic functions and only errors on the constructor as above:
    T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\Adafruit_NeoPixel\examples\strandtest/strandtest.ino:17: undefined reference to `Adafruit_NeoPixel::Adafruit_NeoPixel(unsigned short, unsigned short, unsigned short)'
    exit status 1
  23. #73
  24. #74
    13,428
    Just updated above ... for some reason SublimeText has failed to duplicate and build for first time?
    It is working on T_3.6 when built from IDE ????
  25. #75
    13,428
    FIXED with CLEAN build! There was something stuck in TEMP build cache from last try it seems and linking didn't see the new lib?
    Indeed - building :: T:\tCode\libraries\Adafruit_NeoPixel\examples\strandtest\strandtest.ino
    Works on T_3.6 and T_4.1 and T_4.0 ( on FRDM 4236 ) all on Pin #33 AND a T_3.2 on pin #6
    >> So the 'deal' is ::
    This TeensyDuino library seems to be removable :: T:\arduino-1.8.13_t54\hardware\teensy\avr\libraries\Adafruit_ NeoPixel\
    Thanks for followup @KurtE : I wonder if AdaF NeoPixel was update from the NOV update to the version 1.7.0 today? Something put bad 'cached' build files in TEMP
