Results 1 to 5 of 5
Thread: range of the frequency control input in AudioFilterStateVariable
    May 2020
    9
    I Would like to know what is the range of the frequency control input in the AudioFilterStateVariable?
    and where is the filter control variable in the filter_variable.h/cpp code, since I don't see any input.
    Senior Member manicksan's Avatar
    Jun 2020
    Sweden
    221
    Line 90 in
    https://github.com/PaulStoffregen/Au...r_variable.cpp
    Is the function handling when the freq input is used.
    May 2020
    9
    I do not see it clearly,
    Well, when we put an envelope in that input the range varies from 0 to 1 (float), but I don't see in line 90 the transform from the range 0 to 1 to an integer int16_t.
    void AudioFilterStateVariable::update_variable(const int16_t *in, const int16_t *ctl, int16_t *lp, int16_t *bp, int16_t *hp)
    Jun 2020
    Sweden
    221
    Actually of what I understand the float value is never used between audio objects, float is not a good way of storing audio values because of its structure.
    The floats are only used to make it easier for a user perspective view, when controlling gains an other percentage stuff.
    That function is called from the update function line 205
    May 2020
    9
    perfect, thanks, then use the range of an integer [0..32767]
