Results 1 to 4 of 4
Thread: Teensy 3.5 + wiz850IO hardware not detected
    Nov 2020
    3
    Hi all!
    First, my apologies for such a noob question, I am a beginner here, so bare with me. Y'alls help is greatly appreciated.
    I have a Teensy 3.5 with a Wiz850io module, and I am trying to run the Arduino example file 'DhcpAddressPrinter' to ensure I've hooked up everything properly. The Teensy 3.5 + wiz850io are hooked into a breadboard, and I have a CAT6 ethernet cable running from the wiz to my desktop's ethernet port.
    Unfortunately, I keep receiving the message in my serial monitor stating that an Ethernet shield was not found..
    I have been trying to figure out what is the cause of this issue, but I really don't know what to do at this point.
    Here are my connections
    3MOSI - 11MOSI0
    4SCLK - 13SCK0
    5SCNn - 10CS0
    6MISO - 12MISO0
    #include <Ethernet.h>
    //I just threw a random MAC address here
    byte mac[] = {
      0x09, 0xCA, 0x9C, 0xB9, 0xC3, 0xDD
      Ethernet.init(10);
      // You can use Ethernet.init(pin) to configure the CS pin
      //Ethernet.init(10);  // Most Arduino shields
      //Ethernet.init(5);   // MKR ETH shield
      //Ethernet.init(0);   // Teensy 2.0
      //Ethernet.init(20);  // Teensy++ 2.0
      //Ethernet.init(15);  // ESP8266 with Adafruit Featherwing Ethernet
      //Ethernet.init(33);  // ESP32 with Adafruit Featherwing Ethernet
      while (!Serial) {
        ; // wait for serial port to connect. Needed for native USB port only
      // start the Ethernet connection:
      Serial.println("Initialize Ethernet with DHCP:");
      if (Ethernet.begin(mac) == 0) {
        Serial.println("Failed to configure Ethernet using DHCP");
        if (Ethernet.hardwareStatus() == EthernetNoHardware) {
          Serial.println("Ethernet shield was not found.  Sorry, can't run without hardware. :(");
        } else if (Ethernet.linkStatus() == LinkOFF) {
          Serial.println("Ethernet cable is not connected.");
        // no point in carrying on, so do nothing forevermore:
        while (true) {
          delay(1);
      // print your local IP address:
      Serial.print("My IP address: ");
      Serial.println(Ethernet.localIP());
      switch (Ethernet.maintain()) {
        case 1:
          //renewed fail
          Serial.println("Error: renewed fail");
        case 2:
          //renewed success
          Serial.println("Renewed success");
          //print your local IP address:
        case 3:
          //rebind fail
          Serial.println("Error: rebind fail");
        case 4:
          //rebind success
          Serial.println("Rebind success");
        default:
          //nothing happened
    I've also attached a photo of my wiring. I feel like I'm missing something super obvious here.. any help would be greatly appreciated, thank y'all so much.
    PlClick image for larger version.
    25,217
    Difficult to see from the angle of the camera, but looks like the 3 wires might be on pins 9,10,11 rather than 10,11,12.
    Nov 2020
    3
    Wow, I really did live up to my introduction as a noob. Thanks for such a speedy response, that was indeed the issue.
    25,217
    Glad you got it working!
