Results 1 to 4 of 4
Thread: Cannot get any audio from Teensy 4.1 and Rev D Audio Shield
    Nov 2020
    2
    I'm new here.
    Recently purchased a teensy 4.1 and Rev D Audio Shield.
    Teensy is working fine from the tests I have done but I am having no luck with the audio shield.
    I have run several test scripts to try to get some audio out but I can't seem to get it working.
    Does anyone have a simple test script for 4.1 and Rev D?
    H
    8,220
    From the examples, try Audio->Synthesis->Guitar
    Nov 2020
    2
    Thanks for your quick reply.
    Unfortunately, that still doesn't produce any audio.
    8,220
    Then you have done something wrong :-)
    I hope you used pin connectors and soldered them?
    With china plug-patch-cables it usually doesn't work.
    A photo would help.
