Results 1 to 3 of 3
Thread: Load hex file from SD Card?
    Is it possible to load code (in the form of a hex file) into a T4 from an SD card and have the T4 behave as if the code were loaded through the USB interface? I'm using a custom PCB that includes a T4 and an SD card adapter. I'm providing the boards to remote collaborators (artists) with limited technical skills. Instead of trying to talk them through the process of installing a firmware update using the Teensy Loader, I'd like to just send them an SD card with a new hex file on it.
    Thanks!
    May 2015
    USA
    840
    You might be able to adapt the "flasher4" code to do this.
    https://forum.pjrc.com/threads/29607...e-air-updates/
    Thanks! That looks like a possibility, but will probably require more adaptation (and time) than I can afford to invest right now. I was hoping for something more "turn-key".
