TEENSY 4.1, proper SCK pin question
theDVSguy
Hello, Does anyone know the proper pin for the SCK line from a teensy 4.1 to an NRF24 module ?
I thought it was pin 13 but it seems when I use that pin the module works but I am getting errors but when I leave SCK unhooked from the Teensy, the nrf24 module looks offline .....here is the results I get below
nrf24 SCK - > 13 unplugged
13:33:15.886 -> RF24/examples/GettingStarted
13:33:15.886 -> *** PRESS 'T' to begin transmitting to the other node
13:33:15.886 -> SPI Speedz = 10 Mhz
13:33:15.886 -> STATUS = 0x00 RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=0 TX_FULL=0
13:33:15.886 -> RX_ADDR_P0-1 = 0x0000000000 0x0000000000
13:33:15.886 -> RX_ADDR_P2-5 = 0x00 0x00 0x00 0x00
13:33:15.886 -> TX_ADDR = 0x0000000000
13:33:15.886 -> RX_PW_P0-6 = 0x00 0x00 0x00 0x00 0x00 0x00
13:33:15.886 -> EN_AA = 0x00
13:33:15.886 -> EN_RXADDR = 0x00
13:33:15.886 -> RF_CH = 0x00
13:33:15.886 -> RF_SETUP = 0x00
13:33:15.886 -> CONFIG = 0x00
13:33:15.886 -> DYNPD/FEATURE = 0x00 0x00
13:33:15.886 -> Data Rate = 1MBPS
13:33:15.886 -> Model = nRF24L01
13:33:15.886 -> CRC Length = Disabled
13:33:15.886 -> PA Power = PA_MIN
13:33:15.886 -> Now sending
13:33:15.979 -> failed
13:33:15.979 -> Sent 7274202, Got response 0, Round-trip delay 100928 microseconds
13:33:17.011 -> Now sending
13:33:17.104 -> failed
13:33:17.104 -> Sent 8375444, Got response 0, Round-trip delay 95679 microseconds
13:33:18.089 -> Now sending
13:33:18.183 -> failed
13:33:18.183 -> Sent 9471437, Got response 0, Round-trip delay 95690 microseconds
nrf24 SCK - > 13 plugged
13:34:32.031 -> RF24/examples/GettingStarted
13:34:32.031 -> *** PRESS 'T' to begin transmitting to the other node
13:34:32.031 -> SPI Speedz = 10 Mhz
13:34:32.031 -> STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
13:34:32.031 -> RX_ADDR_P0-1 = 0x3a00000101 0x3130303030
13:34:32.031 -> RX_ADDR_P2-5 = 0xc3 0xc4 0xc5 0xc6
13:34:32.031 -> TX_ADDR = 0x3a00000101
13:34:32.031 -> RX_PW_P0-6 = 0x20 0x20 0x00 0x00 0x00 0x00
13:34:32.031 -> EN_AA = 0x00
13:34:32.031 -> EN_RXADDR = 0x02
13:34:32.031 -> RF_CH = 0x4c
13:34:32.031 -> RF_SETUP = 0x21
13:34:32.031 -> CONFIG = 0x0f
13:34:32.031 -> DYNPD/FEATURE = 0x00 0x00
13:34:32.031 -> Data Rate = 250KBPS
13:34:32.031 -> Model = nRF24L01+
13:34:32.031 -> CRC Length = 16 bits
13:34:32.031 -> PA Power = PA_MIN
13:34:32.031 -> Now sending
13:34:32.265 -> Failed, response timed out.
13:34:33.249 -> Now sending
13:34:33.437 -> Failed, response timed out.
13:34:34.468 -> Now sending
13:34:34.656 -> Failed, response timed out.
Also my pins are
CE = pin7
CSN = pin8
SCK = pin13
MO = pin11
MI = pin12
IRQ = no pin
Arduino Lib RF24 1.3.9
I'm pretty sure the problem is that the Tx and Rx aren't using the same addresses.
In both the Rx and Tx use this for the addresses:
const uint64_t pipes[2] = { 0xF0F0F0F0E1LL, 0xF0F0F0F0D2LL };
In the Rx:
  radio.openWritingPipe(pipes[0]);
  radio.openReadingPipe(1, pipes[1]);
and in Tx:
  radio.openWritingPipe(pipes[1]);
  radio.openReadingPipe(1, pipes[0]);
Pete
Thanks for the help but Im unclear.
I have this specified in both
byte addresses[][6] = {"00001"};
what do I need to edit in this ?
// Open a writing and reading pipe on each radio, with opposite addresses
if(radioNumber){
radio.openWritingPipe(addresses[1]);
radio.openReadingPipe(1,addresses[0]);
}else{
radio.openWritingPipe(addresses[0]);
radio.openReadingPipe(1,addresses[1]);
If these are the details of my radio
18:08:20.653 -> SPI Speedz = 10 Mhz
18:08:20.653 -> STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
18:08:20.653 -> RX_ADDR_P0-1 = 0x3a00000001 0x3130303030
18:08:20.653 -> RX_ADDR_P2-5 = 0x00 0x00 0x00 0x71
18:08:20.653 -> TX_ADDR = 0x3a00000001
18:08:20.653 -> RX_PW_P0-6 = 0x20 0x20 0x00 0x00 0x00 0x00
18:08:20.653 -> EN_AA = 0x00
18:08:20.653 -> EN_RXADDR = 0x02
18:08:20.653 -> RF_CH = 0x4c
18:08:20.653 -> RF_SETUP = 0x71
18:08:20.653 -> CONFIG = 0x0f
18:08:20.653 -> DYNPD/FEATURE = 0x00 0x00
18:08:20.653 -> Data Rate = 250KBPS
18:08:20.653 -> Model = nRF24L01+
18:08:20.653 -> CRC Length = 16 bits
18:08:20.653 -> PA Power = PA_MIN
Should I change it to this ?
const uint64_t addresses[2] = { 0x3130303030LL, 0x3a00000001LL };
Here is my updated code
* Getting Started example sketch for nRF24L01+ radios
* This is a very basic example of how to send data from one node to another
* Updated: Dec 2014 by TMRh20
#include "RF24.h"
//#define RF24_MOSI 11
//#define RF24_MISO 12
//#define RF24_SCLK 14
/****************** User Config ***************************/
/*** Set this radio as radio number 0 or 1 ***/
bool radioNumber = 1;
/* Hardware configuration: Set up nRF24L01 radio on SPI bus plus pins 7 & 8 */
RF24 radio(7,8); // CE, CSN
//const uint64_t addresses[2] = { 0x3130303030LL, 0x3a00000001LL };
//byte addresses[][6] = {"00001"};
//byte addresses[][6] = {"1Node","2Node"};
// Used to control whether this node is sending or receiving
bool role = 0; // 0 = pong back , 1 = ping out
// Start the SPI buss
SPI.setClockDivider( SPI_CLOCK_DIV16 ); // Set SPI clock to 4.5MHz, similar to 16M Arduino
// use alternate SPI pins for nrf24
//SPI.setMOSI(26);
//SPI.setMISO(1);
//SPI.setSCK(14);
SPI.begin();
while(!Serial) ; // wait for arduino serial monitor
delay(2000); // WNG - println's below started working after I put in this delay
Serial.println("RF24/examples/GettingStarted");
Serial.println("*** PRESS 'T' to begin transmitting to the other node");
radio.begin();
//radio.setRetries(1,0);
//radio.setCRCLength(RF24_CRC_16);
radio.setAutoAck(false);
//radio.setPayloadSize(sizeof(int));
//radio.openReadingPipe(1,addresses);
//radio.startListening();
//radio.setAutoAck(false);
// Start the radio, again set ti min & slow as I'm guessing while testing theire really close to each oth
radio.setPALevel(RF24_PA_MIN); // RF24_PA_MIN ,RF24_PA_LOW, RF24_PA_HIGH, RF24_PA_MAX
radio.setDataRate( RF24_250KBPS ); // RF24_250KBPS, RF24_1MBPS, RF24_2MBPS
if(radioNumber){
radio.openReadingPipe(1,pipes[0]);
}else{
radio.openReadingPipe(1,pipes[1]);
// Start the radio listening for data
radio.printDetails();
/****************** Ping Out Role ***************************/
if (role == 1) {
radio.stopListening(); // First, stop listening so we can talk.
Serial.println(F("Now sending"));
unsigned long start_time = micros(); // Take the time, and send it. This will block until complete
if (!radio.write( &start_time, sizeof(unsigned long) )){
Serial.println(F("failed"));
radio.startListening(); // Now, continue listening
unsigned long started_waiting_at = micros(); // Set up a timeout period, get the current microseconds
boolean timeout = false; // Set up a variable to indicate if a response was received or not
while ( ! radio.available() ){ // While nothing is received
if (micros() - started_waiting_at > 200000 ){ // If waited longer than 200ms, indicate timeout and exit while loop
timeout = true;
if ( timeout ){ // Describe the results
Serial.println(F("Failed, response timed out."));
}else{
unsigned long got_time; // Grab the response, compare, and send to debugging spew
radio.read( &got_time, sizeof(unsigned long) );
unsigned long end_time = micros();
// Spew it
Serial.print(F("Sent "));
Serial.print(start_time);
Serial.print(F(", Got response "));
Serial.print(got_time);
Serial.print(F(", Round-trip delay "));
Serial.print(end_time-start_time);
Serial.println(F(" microseconds"));
// Try again 1s later
/****************** Pong Back Role ***************************/
if ( role == 0 )
if( radio.available()){
// Variable for the received timestamp
while (radio.available()) { // While there is data ready
radio.read( &got_time, sizeof(unsigned long) ); // Get the payload
radio.write( &got_time, sizeof(unsigned long) ); // Send the final one back.
radio.startListening(); // Now, resume listening so we catch the next packets.
Serial.print(F("Sent response "));
Serial.println(got_time);
/****************** Change Roles via Serial Commands ***************************/
if ( Serial.available() )
char c = toupper(Serial.read());
if ( c == 'T' && role == 0 ){
Serial.println(F("sssss*** CHANGING TO TRANSMIT ROLE -- PRESS 'R' TO SWITCH BACK qqqqqqqqqqqqqqqq"));
role = 1; // Become the primary transmitter (ping out)
}else
if ( c == 'R' && role == 1 ){
Serial.println(F("sssssss*** CHANGING TO RECEIVE ROLE -- PRESS 'T' TO SWITCH BACK"));
role = 0; // Become the primary receiver (pong back)
} // Loop
Still getting this error
18:16:14.328 -> RF24/examples/GettingStarted
18:16:14.328 -> *** PRESS 'T' to begin transmitting to the other node
18:16:14.375 -> SPI Speedz = 10 Mhz
18:16:14.375 -> STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
18:16:14.375 -> RX_ADDR_P0-1 = 0xf0f0f0f0e1 0xf0f0f0f0d2
18:16:14.375 -> RX_ADDR_P2-5 = 0x00 0x00 0x00 0x71
18:16:14.375 -> TX_ADDR = 0xf0f0f0f0e1
18:16:14.375 -> RX_PW_P0-6 = 0x20 0x20 0x00 0x00 0x00 0x00
18:16:14.375 -> EN_AA = 0x00
18:16:14.375 -> EN_RXADDR = 0x02
18:16:14.375 -> RF_CH = 0x4c
18:16:14.375 -> RF_SETUP = 0x71
18:16:14.375 -> CONFIG = 0x0f
18:16:14.375 -> DYNPD/FEATURE = 0x00 0x00
18:16:14.375 -> Data Rate = 250KBPS
18:16:14.375 -> Model = nRF24L01+
18:16:14.375 -> CRC Length = 16 bits
18:16:14.375 -> PA Power = PA_MIN
18:16:17.640 -> sssss*** CHANGING TO TRANSMIT ROLE -- PRESS 'R' TO SWITCH BACK qqqqqqqqqqqqqqqq
18:16:17.640 -> Now sending
18:16:17.857 -> Failed, response timed out.
18:16:18.875 -> Now sending
18:16:19.045 -> Failed, response timed out.
18:16:20.064 -> sssssss*** CHANGING TO RECEIVE ROLE -- PRESS 'T' TO SWITCH BACK
18:16:21.918 -> sssss*** CHANGING TO TRANSMIT ROLE -- PRESS 'R' TO SWITCH BACK qqqqqqqqqqqqqqqq
18:16:21.918 -> Now sending
18:16:22.088 -> Failed, response timed out.
18:16:23.076 -> Now sending
18:16:23.308 -> Failed, response timed out.
18:16:24.280 -> Now sending
Another problem is that Tx and Rx don't set the payload size. The default payload size is 32 bytes but the code is only sending 4 bytes.
After the radio.begin() statement, add this line to both Tx and Rx:
  radio.setPayloadSize(sizeof(unsigned long));
I've got the code working here so if that one fix doesn't sort things out, I'll post the code I'm using.
Pete
P.S. FYI, I'm using a T3.2 and T4.1 for my testing
Ya I think my codes a dud ;( I tried it didnt work. I am trying to go from a T4.1 to Mega.....its killing me....I would totally appreciate a code set that you have confirmed works
and any suggestions that I might need to run it on both T4.1 and Mega.....totally appreciate the help el_supremo ;)
I'm using this code on both Teensys with slight modifications for the transmitter and receiver.
I set both of them to start up as a receiver (role = 0) and then type T in one of them to get things going. I've also slowed the message rate from one a second to one every five seconds to make it easier to keep track of them.
The radioNumber must be set to 1 in one of the processors and to 0 in the other. If you've wired the NRF24l01 the same way in both processors, no other changes should be required.
Once they are both uploaded, type T in one of them and it should send a message to the other every 5 seconds.
// Tx
#include "RF24.h"
  radio.begin();
  if(radioNumber) {
  if (role == 1) {
    if (!radio.write( &start_time, sizeof(unsigned long) )) {
    while ( ! radio.available() ) { // While nothing is received
      if (micros() - started_waiting_at > 200000 ) { // If waited longer than 200ms, indicate timeout and exit while loop
        timeout = true;
    if ( timeout ) { // Describe the results
// Spew it
// Try again 5s later
    delay(5000);
  if ( role == 0 )
    if( radio.available()) {
  if ( Serial.available() ) {
    if ( c == 'T' && role == 0 ) {
    } else if ( c == 'R' && role == 1 ) {
} // Loop
Pete
Thanks Pete.....so I did as you instructed...
I took 1 copy and am running it on the T4.1 as is....radio 1...
I took 1 copy and changed the ce,csn number and changed the radio to 0..
I hit T on the Mega...I have a blank screen
on the T4.1 I just have the radio details.....
not sure I am doing this correctly
You should have radio details on both screens unless the RF24 library for the Mega is different than the T4.1.
If it really does work for a few lines, i.e. the sender sometimes looks like this:
Now sending
Sent 5597214, Got response 5597214, Round-trip delay 1784 microseconds
Now sending
Sent 10599568, Got response 10599568, Round-trip delay 1786 microseconds
Now sending
Sent 15601923, Got response 15601923, Round-trip delay 1787 microseconds
and receiver looks like this:
Sent response 5597214
Sent response 10599568
Sent response 15601923
then maybe there's a loose wire.
Pete
