Results 1 to 17 of 17
Thread: Problems with builtin sd card
    Junior Member rcmz's Avatar
    Nov 2020
    9
    Hello, I'm trying to make an portable music player with a teensy 3.6.
    I'm having some trouble with the builtin sd card reader.
    Most of the time, sd begins fails with the following errors codes :
    0x24 (SD_CARD_ERROR_DMA - DMA transfer failed)
    0X08 (SD_CARD_ERROR_CMD10 - Read CID data)
    Sometimes, out of nowhere, it works. It seem to have a better chance of succeeding if
    i try just after letting my teensy unplugged for a long time (maybe it's tired ?).
    To me that sounds like a hardware / wiring problem, but I'm new to this stuff.
    My teensy is soldered to an audio adaptor board and connected to a ssd1351
    oled screen through a breadboard.
    Here is my test code :
    include <SdFat.h>
        while (!Serial);
        SdFat sd;
        if (!sd.begin(BUILTIN_SDCARD)) {
            sd.initErrorPrint();
            Serial.println("success !");
    Do you have any idea of what could be going on ?
    23,486
    Are you using version 1.53?
    In 1.54 we're changing SD and switching to SdFat version 2 (until very recently called SdFat-beta). Might be worthwhile to uninstall SdFat and give the 1.54-beta5 a try.
    https://forum.pjrc.com/threads/64592...no-1-54-Beta-5
    Starting with 1.54-beta3, when you use SD, it's really using SdFat internally, and it's the newer SdFat. If you're starting a new project, probably best to get started on 1.54-beta5, so you don't end up building a lot of code which is likely to break with the upcoming 1.54 release.
    Nov 2020
    9
    Thanks for your response !
    I tried with this latest version of teensyduino,
    sadly it doesn't change anything :'-(
    Germany
    7,658
    Have you tried other cards?
    23,486
    I ran it here with the latest beta using Teensy 3.6 and a Samsung 32 EVO Plus in the built in SD socket. Uploaded 10 times. It printed "success !" every time.
    Nov 2020
    9
    I've tried with one other card, same thing.
    I will try with more once I get my hands on some.
    Germany
    7,658
    Maybe a connection is not good.
    Are there any wires between the Audioshield and the Teensy, or are you using pinheaders?
    Nov 2020
    9
    The audio shield is connected using pinheaders, but I haven't soldered every pin.
    Nov 2020
    9
    Well I gess that's good news !
    Germany
    7,658
    You should solder at least the needed pins (for the Audiochip and SD, GND and so on..)
    Nov 2020
    9
    Well I guess I will try that tomorow.
    But the internal SD is not suppose to interfere with the audio shield pins, am I correct ?
    Germany
    7,658
    Ah, of course..you're using a Teensy with inbuilt slot. No, in this case it is not needed.
    Nov 2020
    9
    oh ok,
    I should add that I seem to remeber that this problem was not happening a couple days ago. Could I have fried something while soldering / connecting something badly ?
    23,486
    Normally the audio shield should not have any impact on the built in SD socket on Teensy 3.6. None of the signals are shared, only power.
    Germany
    7,658
    SD cards can sometimes draw a lot of current. Maybe look there? Depends on what else you have connected...
    I remember I had similar problems, a long time ago. It helped to solder a 100uF cap to the Teensy 3v3+GND pins near the slot, but I'm not 100% sure if that was reason that it began working..
    Maybe it was just a problem with the slot and the repeated card-inserts solved it...
    @Paul, yes, I wrote this.
    Nov 2020
    9
    Well I guess the audio shield + oled screen could be too much of a power draw.
    Thanks I'll look in that direction tomorow !
    Nov 2020
    9
    Actually that story rings a bell, I migh have red one of your post previously ^^
