Results 1 to 4 of 4
Thread: Issue Modifying the SimpleDrum Example - Any help appreciated
    Nov 2020
    2
    I have connected a Read() function that reads from a 32 key 64 switch keyboard by reading the rows and columns
    When I call that function in the SimpleDrum example no sound is generated. I am not using any pins shared with the audio shield. I honestly have no idea what the issue is. I would also like to add that the Serial Monitor displays no information when Read() is called. Any help would be greatly appreciated
    AudioSynthSimpleDrum     drum2;          //xy=399,244
    AudioSynthSimpleDrum     drum3;          //xy=424,310
    AudioSynthSimpleDrum     drum1;          //xy=431,197
    AudioSynthSimpleDrum     drum4;          //xy=464,374
    AudioMixer4              mixer1;         //xy=737,265
    AudioOutputI2S           i2s1;           //xy=979,214
    AudioConnection          patchCord1(drum2, 0, mixer1, 1);
    AudioConnection          patchCord2(drum3, 0, mixer1, 2);
    AudioConnection          patchCord3(drum1, 0, mixer1, 0);
    AudioConnection          patchCord4(drum4, 0, mixer1, 3);
    AudioConnection          patchCord5(mixer1, 0, i2s1, 0);
    AudioConnection          patchCord6(mixer1, 0, i2s1, 1);
    AudioControlSGTL5000     sgtl5000_1;     //xy=930,518
    static uint32_t next;
    boolean keyTable[8][8];
    byte cols[] = {24,25,26,27,28,29,30,31};
    byte rows[] = {32,33,34,35,36,37,38,39};
      // audio library init
      AudioMemory(15);
      next = millis() + 1000;
      AudioNoInterrupts();
      drum1.frequency(60);
      drum1.length(1500);
      drum1.secondMix(0.0);
      drum1.pitchMod(0.55);
      drum2.frequency(60);
      drum2.length(300);
      drum2.secondMix(0.0);
      drum2.pitchMod(1.0);
      drum3.frequency(550);
      drum3.length(400);
      drum3.secondMix(1.0);
      drum3.pitchMod(0.5);
      drum4.frequency(1200);
      drum4.length(150);
      drum4.secondMix(0.0);
      drum4.pitchMod(0.0);
      sgtl5000_1.enable();
      sgtl5000_1.volume(0.5);
      AudioInterrupts();
      static uint32_t num = 0;
      if(millis() == next)
        switch(num % 4)
          case 0:
            drum1.noteOn();
          case 1:
            drum2.noteOn();
          case 2:
            drum3.noteOn();
          case 3:
            drum4.noteOn();
        num++;
        Serial.print("Diagnostics: ");
        Serial.print(AudioProcessorUsageMax());
        Serial.print(" ");
        Serial.println(AudioMemoryUsageMax());
        AudioProcessorUsageMaxReset();
      Read();
    void Read()
      for(int i = 0; i < 8; i++)
        //change pinMode
        pinMode(cols[i], OUTPUT);
        delay(10);
        digitalWrite(cols[i], HIGH); //write the col high
        for(int j = 0; j < 8; j++)
          pinMode(rows[j], INPUT_PULLDOWN);
          delay(10);
          keyTable[j][i] = digitalRead(rows[j]);
          if(digitalRead(rows[j]) == HIGH && digitalRead(cols[i] == HIGH))// if the current key is pressed
            Serial.println("Played?");
            //Velocity calculation
            drum1.noteOn();
          pinMode(rows[j], INPUT);
        pinMode(cols[i], INPUT);
    1,543
    There's a parenthesis in the wrong place. It should be:
          if(digitalRead(rows[j]) == HIGH && digitalRead(cols[i]) == HIGH)// if the current key is pressed
    Pete
    Nov 2020
    2
    Wow! Thank you for the help. I have a follow up question, is the reason it didn't work was because I was providing digitalRead with a boolean type that I would guess is always false? Instead of a pin number? Or does this cause some kind of run time error?
    1,543
    The value of HIGH is probably 1 and cols[i] is never 1 so the result is FALSE which is zero. The result will be that it will try to read pin 0. In a test on a T4.1 the result of reading pin 0 with nothing connected was also zero.
    So, the if statement as a whole would never evaluate to true. It is an error but it won't cause a specific run-time error, other than it won't work as expected.
    The compiler doesn't generate a warning.
    Pete
