I am in need of a reset pin, and although any pin can technically be used and coded, The DP83825 IC (U6) shows RST on its pin 5. If there is no exposed Test-Point or pad for this pin, due to SMD components, I am comfortable in gently scraping away some of the trace coatings and soldering.
I am assuming that when the Teensy is reset, when programming, this RST line is activated. Is that a safe assumption? If so which IC is the U6? and its orientation? and can you point out the trace that I would need to tie into? Is the signal strong enough to be tied to additional chips?
Or do I have it all wrong in that the U6 IC is activating the reset and not the actual Teensy U1 IC?
Thank you!
Thank you!
