Results 1 to 12 of 12
Thread: Teensy 4 RTC - prevent loader from changing time
    Dec 2020
    3
    I'm moving up from my trusty 3.2 to 4.0. The changes in Serial ports and in the RTC have caused me a few headaches, mostly solved. What I cannot solve is how to stop teensyduino from setting the RTC every time I upload a sketch. In my application I'm setting the time to UTC and calculating the timezone time in the part of the country I'm currently in. My understanding was that when the time is initially set, teensy loader would not change it but that is not what is happening. Every time I upload, it sets the time to the PC time. I'm testing using the example sketch TimeTeensy3.
    Thanks.
     * TimeRTC.pde
     * example code illustrating Time library with Real Time Clock.
    #include <TimeLib.h>
    void setup()  {
      // set the Time library to use Teensy 3.0's RTC to keep time
      while (!Serial);  // Wait for Arduino Serial Monitor to open
      if (timeStatus()!= timeSet) {
        Serial.println("Unable to sync with the RTC");
        Serial.println("RTC has set the system time");
      if (Serial.available()) {
        time_t t = processSyncMessage();
        if (t != 0) {
          Teensy3Clock.set(t); // set the RTC
          setTime(t);
      digitalClockDisplay();
    void digitalClockDisplay() {
      // digital clock display of the time
      Serial.print(hour());
      printDigits(minute());
      printDigits(second());
      Serial.print(" ");
      Serial.print(day());
      Serial.print(" ");
      Serial.print(month());
      Serial.print(" ");
      Serial.print(year());
    time_t getTeensy3Time()
      return Teensy3Clock.get();
    /*  code to process time sync messages from the serial port   */
    #define TIME_HEADER  "T"   // Header tag for serial time sync message
    unsigned long processSyncMessage() {
      unsigned long pctime = 0L;
      const unsigned long DEFAULT_TIME = 1357041600; // Jan 1 2013
      if(Serial.find(TIME_HEADER)) {
         pctime = Serial.parseInt();
         return pctime;
         if( pctime < DEFAULT_TIME) { // check the value is a valid time (greater than Jan 1 2013)
           pctime = 0L; // return 0 to indicate that the time is not valid
      return pctime;
    void printDigits(int digits){
      // utility function for digital clock display: prints preceding colon and leading 0
      Serial.print(":");
      if(digits < 10)
        Serial.print('0');
      Serial.print(digits);
    Oct 2019
    Calgary
    93
    Have you tried using the command line version of the loader? From admittedly just a quick glance, I can't see any code in there that sets the target's time on loading. You would have to compile the loader for your platform.
    13,445
    Or you can use TyCommander - it doesn't have the time set code during upload which has not yet been made public -it has a thread and github.com/Koromix/tytools
    It is interesting it sees the time as set and then still over writes it, not seen a way to disable.
    Assuming you have an RTC battery on the T_4.0? - Does it maintain the time if unplugged and plugged back in? I haven't worked with that lately - but when I checked last my onboard cell was dead so it wouldn't hold time. Tested that after a post noted it consumes more power from the cell than a T_3.2 does.
    Oct 2019
    Calgary
    93
    Curiosity got the better of me. The command line loader definitely does not reset the time when uploading a new sketch. It does require pressing the button on the T4.1 to start the download; the soft reset option didn't want to work (the comments do say that it's only for the T3.x boards but I was hoping!).
    13,445
    Didn't expect it had the more recent time fix - but it has been updated with last TD release it seems to support T_4.1 as well. But that code is public - so if it had the time set during upload it could be added to TyCommander.
    Can you link or show where you saw the "T-3.2" only text? @Paul will want to fix that AFAIK.
    Oct 2019
    Calgary
    93
    I missed that. And as I've had the same dollar store CR2032 cell in a T4.0 setup since October of last year I was a bit concerned. So I just measured its in circuit voltage and it's still reading 3V and keeping the time backed up. Maybe I just got lucky.
    Oct 2019
    Calgary
    93
    It was in the usage text from the program itself (source line #43 in teensy_loader_cli.c):
    earth:~/Documents/src/teensy_loader_cli $ ./teensy_loader_cli
    Filename must be specified
    Usage: teensy_loader_cli --mcu=<MCU> [-w] [-h] [-n] [-b] [-v] <file.hex>
    	-w : Wait for device to appear
    	-r : Use hard reboot if device not online
    	-s : Use soft reboot if device not online (Teensy3.x only)
    	-n : No reboot after programming
    	-b : Boot only, do not program
    	-v : Verbose output
    Use `teensy_loader_cli --list-mcus` to list supported MCUs.
    For more information, please visit:
    http://www.pjrc.com/teensy/loader_cli.html
    13,445
    Quote Originally Posted by Silverlock View Post
    Has it been otherwise powered? Mine was in one of the beta units and battery was empty. It had been parked more than used - and off/on as the T_4.1 went through and out of Beta and mostly since it released.
    Oct 2019
    Calgary
    93
    It does see main power for several hours pretty much every day. But even so it's been off for at least 12 hours a day through all that time, and that's a very conservative estimate.
    13,445
    	-v : Verbose output
    Also > At a glance that text "-s : Use soft reboot if device not online" seems like maybe it should read :: "-s : Use soft reboot if device online" - Where offline implies a soft reboot wouldn't work?
    @Paul might see that here - but might be worth a link on the TD 1.54 Beta 5 thread?
    Dec 2020
    3
    The time is kept perfectly on power down, but updated only on upload of a sketch.
    I'm using PlatformIO and Teensyduino - is there some code in teensyduino where I can disable updating the RTC?
    Or can I integrate Tycommander with PlatformIO so the uplaod is through the PlatformIO/VSCode IDE?
    Dec 2020
    3
    For anyone finding this post in a search, this is how I solved my issue:
    I installed TyTools to C:\TyTools
    Added these lines in platformio.ini:
    upload_protocol = custom
    upload_command = C:\TyTools\tycmd.exe upload -B $UPLOAD_PORT $SOURCE
    build_flags = -DUSB_SERIAL_HID -DLAYOUT_US_ENGLISH
    I found PlatformIO uses it's own copy of C:\Arduino\hardware\teensy\avr\cores and libraries at C:\Users\xxxx\.platformio\packages\framework-arduinoteensy
    This isn't updated with a new version of teensyduino
    So I created symlinks in C:\Users\xxxx\.platformio\packages\framework-arduinoteensy
    C:\Arduino\hardware\teensy\avr>mklink /J C:\Users\xxxx\.platformio\packages\framework-arduinoteensy\cores cores
    C:\Arduino\hardware\teensy\avr>mklink /J C:\Users\xxxx\.platformio\packages\framework-arduinoteensy\libraries libraries
    (My Arduino installation is in the root of C: , xxxx is your user name)
