milovan vujicic
Hi Paul,
I'm adding the Teensy4.1 schematic to use IMX1062 chip on my custom board. I'm having a hard time to understand how to burn the bootloader and firmware on IMX.
There are many explanation for boot configuration, but I want to do everything only via usb otg1 port like in the Teensy4.1 board. Is it possible? I duplicated the teensy circuit to the custom board as it is. I added a MKL02Z32VFG4 to the board like in the Teensy board.
Or should I add JTAG header to the board for flashing the firmware and bootloader?
Would you like to let me know the best solution for programming the firmware and burning the bootloader on my custom board? Where can I find the reference design for it?
Thanks in advance
Milovan.
Thanks in advance
Milovan.
