Results 1 to 8 of 8
Thread: Teensy linux command line code upload
    We will have about ~150 teensies to manage. We will compile code, then distribute the code to the computers that host the teensy.
    How can we load code on the teensy from the command line. The UI is not availble.
    I saw arduino-cli, but I don't that it works with a teensy?
    Mar 2016
    Portland, OR
    646
    This is a command line uploader for Teensy:
    https://www.pjrc.com/teensy/loader_cli.html
    The cool thing with using Linux is that you can use the "-s" option, so you don't even need to press the program button.
    Oct 2019
    Calgary
    109
    Quote Originally Posted by brtaylor View Post
    Depending on which Teensy it is; I've yet to get the "-s" option to work with a Teensy 4.1. The usage text does say it's just for the 3.x series, but I was hoping!
    13,906
    TyCommander also has a command line version that may offer different or more usable command line parameters.
    Senior Member manicksan's Avatar
    Jun 2020
    Sweden
    277
    If I understand this correctly
    There are many computers each having a connected teensy and they are headless linux-based?
    Quote Originally Posted by manicksan View Post
    Yes, we need to update the code on the Teensy via ansible. (https://www.ansible.com/)
    Quick supplemental question:
    The export sequence export two ex files,
    project.ino.with_bootloader.yun.hex
    project.ino.yun.hex
    Which one do I want?
    Mar 2016
    Portland, OR
    646
    Quote Originally Posted by JasonH View Post
    project.ino.yun.hex
    Neither, since it's not built for Teensy. Try selecting the Teensy board, you'll only get one hex file.
    Excellent catch! I loaded the normal Arduino IDE by mistake. Thank you!
