Results 1 to 25 of 25
Thread: teensy 3.2/3.1 Problem...
    Dec 2020
    14
    i want to create this project.
    https://www.youtube.com/watch?v=oFEkNULnkzk
    A Teensy 3.2 / 3.1 is needed, for flashing I use the current Arduino IDE including the current Teensyduino.
    Compiling and then flashing runs without error messages. So everything seems to be fine.
    Unfortunately none of the connected LEDs light up.
    I tested it with three Teensy 3.2, but I don't think all three Teensy 3.2 are defective.
    Can someone help me?
    If more information is required, please write.
    13,507
    Have the lights strings been tested to work?
    Double checked all the wiring ?
    Is the source code as published? Same library versions? No compile warnings or erros in Verbose mode?
    Dec 2020
    14
    I tested the LEDs on a similar project, they work there.
    All connections are ok.
    As I have already written, there are no error messages.
    I've attached a picture with the settings in the Arduino IDE.
    13,507
    Yes, no errors was apparent or it would not have loaded ... but once 'warnings' is typed the 'or errors' follows Although I sometimes jump to SerMon during compile and the prior sketch is running when there was an error and it isn't noticed when I have the sound off I don't hear the restart - but assume it did.
    Just because the LEDs worked before doesn't mean they are ready and able to work after being reconfigured - but not sure how to suggest testing them, unless there is a simple demo sketch that could be run, but without seeing posted code that can't be suggested.
    Dec 2020
    14
    I tested the LEDs with a similar project called "Plasma Lamp".
    This was done with an Arduino Nano. Everything works without problems here. The same LED arrangement is used for the current project.
    So I can say with certainty that the LEDs work.
    Please have a look at the link I gave above.
    The circuit is also shown there. There is also a link to the code.
    23,786
    As a quick test, I programed that torchframe program onto a Teensy 3.2 and connected 8 WS2812B LEDs. The PCB I have here with 8 LEDs takes input from pin 1, so I just used a wire from pin 11 to 1 to make the connection. (fortunately, this program doesn't seem to do anything with pin 1, leaving the pin unconfigured, so wiring it to pin 11 isn't a conflict)
    The 8 LEDs all turn on bright white.
    I have no idea what this program is supposed to do. (Sorry, I really don't have time to watch a youtube video) But hopefully this quick test with known-good LEDs can help.
    The 8 LEDs I connected definitely do light up, as you can see in this photo. So perhaps you have some sort of wiring or other hardware issue which is preventing your LEDs from working? Maybe we could help spot the problem is you showed pictures of your wiring?
    23,786
    You might also have LEDs which can't accept a 3.3V signal. Most of the LEDs made in the last 2 years work fine with 3.3V signals. So do the very old ones from 2011-2013. Somewhere along the line, WS2812B LEDs were made which don't accept 3.3V signals. Those LEDs work with boards like Arduino Nano which have 5V signals, but they can't "see" the lower voltage signal from Teensy and all other modern boards which use 3.3V. With those LEDs, you need a buffer chip like 74HCT245 or 74AHCT125 to increase the signal voltage.
    But first, let us try to help you with the wiring. You might have a simple mistake or misunderstand which we can't guess from text. We can only see those sorts of things if you show photos of your wiring.
    Dec 2020
    14
    Well, the video only lasts 6 minutes. However thank you for your help.
    Can you please set the code here. Then I'll test with your code.
    23,786
    Quote Originally Posted by minigl View Post
    It's not my code. I ran the "torchframe" code linked from the youtube video's description.
    https://drive.google.com/file/d/1gsA...4zv-AsoM6/view
    That code has this on line 28, which is why I connected the LED signal wire to pin 11.
    #define LED_PIN     11
    23,786
    Looks like that code is also on github, perhaps a slightly newer version?
    https://github.com/evilgeniuslabs/torch
    But the copy I ran on the Teensy 3.2 you see in the photo was downloaded from the Google Drive link on the video description. It absolutely did turn the LEDs on very bright, as you can see in the photo.
    Not sure if that really helps you, but it's probably the best I can do. I've already given a couple blind guesses as to why your LEDs aren't turning on at all with Teensy 3.2. Really can't do anything more with so little info about how you're wiring the LEDs and which code you're actually running on Teensy.
    Dec 2020
    14
    Here the pictures of my wiring.
ID:	22744Click image for larger version.
ID:	22745Click image for larger version.
ID:	22746Click image for larger version.
    Dec 2020
    14
    I also used the code from Github. It seems to be current.
    Did you also flash the code with the Arduino IDE?
    2,616
    How about trying the simple FastLED bllink example, testing with various values for NUM_LEDS. Following works for me with 8-LED neopixel stick on pin 11 with 3.3v and GND from T3.2.
    #include <FastLED.h>
    // How many leds in your strip?
    #define NUM_LEDS 4
    // For led chips like Neopixels, which have a data line, ground, and power, you just
    // need to define DATA_PIN.  For led chipsets that are SPI based (four wires - data, clock,
    // ground, and power), like the LPD8806 define both DATA_PIN and CLOCK_PIN
    #define DATA_PIN 11
    // Define the array of leds
    CRGB leds[NUM_LEDS];
      FastLED.addLeds<WS2812B, DATA_PIN, GRB>(leds, NUM_LEDS);
      // Turn the LEDs on, then pause
      for (int i = 0; i < NUM_LEDS; i++)leds[i] = CRGB::Red;
      FastLED.show();
      // Now turn the LEDs off, then pause
      for (int i = 0; i < NUM_LEDS; i++)leds[i] = CRGB::Black;
      FastLED.show();
    also works with pin 11, 5V, GND
    Dec 2020
    14
    I'll test that later with the code shown. Then contact me.
    Dec 2020
    14
    Ok, I increased the number of LEDs to 60 and everything works.
    Dec 2020
    14
    Here an picture...Click image for larger version.
    Dec 2020
    14
    So the "blink" code works. But why doesn't the code that I want to use in the project work? Does somebody still have an idea?
    Dec 2013
    East Stroudsburg PA.
    302
    Who knows obviously seems like a code issue perhaps you should show us the full code.
    Look up ^^^^^^ Forum Rule: Always post complete source code & details to reproduce any issue!
    23,786
    Quote Originally Posted by Chris O. View Post
    I believe it's either the "torchframe.ino" code from the Google Drive link on the video description (from msg #1) or the somewhat newer "torch.ino" copy on github (from msg #10). But yeah, for anyone coming late to this thread, or even reading since the beginning, it's hard to follow which code is actually being used.
    Can you be more specific about what is not working? In msg #1, you wrote "Unfortunately none of the connected LEDs light up". Is that still the case? In msg #6, I ran the "torchframe" code linked from msg #1 with 8 LEDs. You can see in my photo they definitely did light up.
    So are all the LEDs all staying unlit, or is something else about it not working?
    I hope you can understand how the imprecise nature of your writing is making it very difficult for any of us to help you effectively. Still, we're trying. Please, be more specific in every message about exactly which code you are using and what you expected it to do and how the results you observed differed from those expectations
    Remember, we're all trying to help you troubleshoot an electronic project over the internet, where we can't see and experience what you're doing. The better you communicate which things you are actually trying, with which code, and what actually happens (photos are best), the easier and better we can help. As you can see from the many replies, we do want to help you. Please do yourself a huge favor and write more specific messages, so we can better help you.
    Dec 2020
    14
    @Chris O.
    At the moment I don't know how to set a code or file here.
    It is the code from the following link:
    Dec 2020
    14
    @PaulStoffregen
    Sorry about the discrepancies.
    It is definitely the code from the following link: https://www.youtube.com/watch?v=oFEkNULnkzk
    So the Torchframe.ino code.
    All LEDs remain dark.
    And I've checked the wiring many times now.
    I don't see this as a problem because I'm a trained electronics technician. (Unfortunately no programmer, only Siemens S5 and S7)
    I also think it's nice that you want to help me.
    The one with the different code was my mistake.
    So it's the torchframe.ino code.
    2,616
    I've run both the torchframe sketch and the torch sketch (github), with 8-LED stick on pin 11 of T3.2. I have nothing else connected (no buttons, no IR receiver, nothing on A0 and A1). The torch sketch dimly lights up LEDS 4-7 (red). The torchframe sketch has activity on LEDS 2-7 (dim red, some random flashing).
    Random data from analogRead() of unconnected A0 and A1 on T3.2
    Dec 2020
    14
    @manitou
    8-LED stick?
    You mean an WS2812B Stripe with 8 LED`s?
    2,616
    @manitou
    8-LED stick?
    yes, as referenced in post #13. I did not change NUM_LEDS in either torch.ino (240) or torchframe.ino (378)
    Dec 2020
    14
    ok, that was it then.
