Teensy 4.0 + mcp23017 blink
Hi all,
I'm trying to get my MCP23017 working with a teensy.
I've hooked it up on a breadboard, the wire scanner finds it on 0x20, so I'm assuming all my wiring is correct.
I see posts here and there where people put 2 4.7kO resistors between scl > teensy 19 and sda > teensy 18 but that didn't do anything for me.
Also tried 3.3v and 5v.
I wrote a very simple blink sketch to test it out. I haven't connected an LED, I'm just measuring voltage at the ports.
It's always in a low range. First I tried just one port but I just put it all in a loop so I could test all the ports.
#include "Adafruit_MCP23017.h"
Adafruit_MCP23017 mcp;
int led = 13;
  while(!Serial);
  Serial.begin (9600);
  Serial.println("Start:");
  pinMode(led, OUTPUT);
  mcp.begin(0x20);
  for(int i = 0; i < 16; i++) {
    mcp.pinMode(i, OUTPUT);
  for(int i = 0; i < 16 i++) {
    mcp.digitalWrite(i, HIGH);
  digitalWrite(led, HIGH);
    mcp.digitalWrite(i, LOW);
  digitalWrite(led, LOW);
I had it working before, including a button and rotary encoder but now I can't even get this to work.
I tried another chip, same result (scanner finds it, ports do nothing)
Did I fry both chips?
Any ideas?
Thanks a lot!
I can't find the edit button for this post :)
But where I wrote scl > gnd and sda > gnd I meant scl > teensy 19 and sda > teensy 18.
Also, here is a picture of my setup.
I also tried attaching an LED ofcourse and strangely enough I noticed it lighting up reaaaally lightly when I only connected the ground and nothing on the other leg.
Is static electricity interfering with my mcp?
The teensy is hooked to my macbook with one of those usb-c hubs. I unhooked my laptop from power and it did seem to change something in measured values on each port.
The mcp reset pin gets a constant voltage it seems. Is that how it should work? Is something that looks constant on my multimeter constant enough or could it be resetting?
Thanks again !
Post #1 edited to : put 2 4.7kO resistors between scl > teensy 19 and sda > teensy 18
Just checking - the added 4.7K resistors are from Pin to 3.3V as Pull Ups correct?
I don't have them added at the moment, the same breadboard worked before. Now I don't have extra resistors anywhere.
I don't know how they should work either, but when I tried I just placed them between sci and 19 and sda and 18.
I don't fully understand pullup resistors but I guess I have to make a connection between sci => 19 and 19 => teensy 3.3v? Or 5v when I put everything on 5v?
With a Teensy 4.0 / 4.1 not touching 5V at anytime is the best bet.
But yes a [ Pullup resistor goes PIN# to 3.3V while that same PIN# also goes to the Device ], for both SCL and SDA. Only one set of pullups are needed on each i2c set of devices, some devices have them built in, but if not then adding the resistor is needed on Teensy. And for the 3.3V AFAIK using 2.2K is generally good for most speeds at 3.3V.
Alas, no luck with added resistors and putting it on 3.3v.
Sorry for the wire mess, I didn't have proper colored breadboard wires anymore.
pin 18/19 go through 2.2k resistors to the same V as the rest. (Picture is still 4.7k but I just tried 2.2)
Mcp is still found on 0x20 with the scanner example.
I added an LED w resistor to MCP port GPB0, and am calling it with mcp.digitalWrite(8, HIGH); Tested the led on 3.3v, it works.
Finding it with the Scanner is a promising start ...
No specific idea of the behavior of that MCP ... but one general thing to try is to delay before the device begin - and with the speed of the Teensy is might not hurt to try the following :
  Serial.begin (9600);  // This line of code actually does nothing - but if it did after the while() would not make sense
  while(!Serial);
  [B]delay( 1100); // random delay - the Teensy may power up faster than the i2c device can handle[/B]
  mcp.begin(0x20);
    [B]delay( 50 );  // Fast Teensy may be swamping the i2c device?[/B]
The picture does look easier to read - but wires aren't my specialty (shorter wouldn't hurt) to see what else my be present - others may see something.
The delay before .begin was noted as a common 'guess' some devices that makes the difference.
Knowing the device responds to Scanner suggests it is powered wired mostly correct - but AdaFruit ref or others may help if not.
I'd confirm a touch of 3.3V on the expected (yellow ?) LED side makes it light up to prove breadboard is connecting and the polarity is right.
the led works, I think I'll try to use shorter lines.
Thanks!
Is there a common ground connecting those seperate proto boards?
All the wiring was correct, but thanks for checking it out!
I have it working! I found a sketch using purely the wire library. I ran this and it works like a charm. Even without pullup resistors and on 5v.
It appears I have problems with my teensyduino install, maybe because I also have platformio running and there are conflicting libraries or something..
I still prefer to use the adafruit mcp23017 library but at least I know that it's a software problem.
#include "Wire.h"
void setup(){
 //Send initial configuration to MCP23017
 Wire.begin();
 Wire.beginTransmission(0x20); //opcode/address of chip
 Wire.send(0x12); //iocon
 Wire.send(0x20); //disable sequential addresses
 Wire.endTransmission();
 Wire.send(0x00); //iodira
 Wire.send(0x00); //all 0's, all outputs
 Wire.send(0x00);
void turnOnLED()
 Wire.send(0x12); // gpioa
 Wire.send(0xff);  // all high
 Wire.send(0xff);
void turnOffLED()
 Wire.send(0x00); // all low
 Wire.send(0x00);
void loop(){
 turnOnLED();
 digitalWrite(13, HIGH);
 turnOffLED();
 digitalWrite(13, LOW);
Ok wow. I've got it working with the adafruit library.
it works when I do mcp.begin() instead of mcp.begin(0x20). The address should be an int instead of a hexadecial number!
Anything > 7 is set to 7. So, instead of using the i2c address you have to use the 3 bit mcp address, 0 - 7.
Only took me about 3 evenings pffff.
