Hello!
Currently, I'm trying to get the individual x,y-values I draw on my TFT Display (ILI9341) and store them in an array. My plan is to send them to Audio Shield's arbitrary wave synthesizer. My code so far:
Whenever I run the code, it only registers the first dot I draw and won't move on.. Also, it wont draw any more dots with the for-loop in it. I would appreciate any kind of help! Thank you.
#include <ILI9341_t3.h>
#include <font_Arial.h> // from ILI9341_t3
#define CS_PIN 8
#define TFT_DC 9
#define TFT_CS 10
// MOSI=11, MISO=12, SCK=13
XPT2046_Touchscreen ts(CS_PIN);
#define TIRQ_PIN 2
//XPT2046_Touchscreen ts(CS_PIN); // Param 2 - NULL - No interrupts
//XPT2046_Touchscreen ts(CS_PIN, 255); // Param 2 - 255 - No interrupts
//XPT2046_Touchscreen ts(CS_PIN, TIRQ_PIN); // Param 2 - Touch IRQ Pin - interrupt enabled polling
int width = 4;
int16_t anArray_X[257] = {0};
int16_t anArray_Y[257] = {0};
byte arrayIndex_X = 0;
byte arrayIndex_Y = 0;
Serial.begin(38400);
tft.begin();
tft.setRotation(1);
ts.begin();
ts.setRotation(1);
while (!Serial && (millis() <= 1000));
boolean wastouched = true;
boolean istouched = ts.touched();
if (istouched) {
int X, Y;
TS_Point p = ts.getPoint(); // point getter function
X = p.x - 231;
X = map(X, 3482, 0, 0, 320);
// Serial.print("X:");
// Serial.print(p.x);
// Serial.println();
Y = p.y - 360;
Y = map(Y, 3465, 0, 0, 240);
tft.fillCircle(X, Y, width, CL(255, 0, 0)); // CL stands for color --> RGB values
for (arrayIndex_Y = 0; arrayIndex_Y <= 256; arrayIndex_Y++) {
anArray_Y[arrayIndex_Y] = Y;
Serial.print("Array Y:");
Serial.print(anArray_Y[arrayIndex_Y]);
// Serial.print("Y:");
// Serial.print(p.y);
/* for (arrayIndex_X = 0; arrayIndex_X <= 256; arrayIndex_X++) {
// anArray_X[arrayIndex_X] = X;
Serial.print("Array X:");
Serial.print(anArray_X[arrayIndex_X]);
