Hi all.
I use Tlc59711 led drive to drive bi-color leds with teensy 4. I have uploaded default example sketch, changed clock and data pins to those, where my Tlc59711 is wired (clock 15 pin, data 14 pin). At start the library was working and the lights on leds appeared. However after some code manipulations this library stopped to work and my teensy started to disconnect from PC after my attempts to upload new sketch. Later, I returned to unedited default example code but teensy still doesn't work and IDE shows error:
"No Teensy boards were found on any USB ports of your computer.
Please press the PROGRAM MODE BUTTON on your Teensy to upload your sketch. An error occurred while uploading the sketch".
I disconnected teensy from periphery, also uploaded a blink sketch. Blink sketch loads successfully. However when trying to load a default adafruit Tlc59711 test sketch - the issue is still there, board is disconnecting right after second attempt of sketch uploading.
I tried this sketch example with spare teensy 3.2 - it uploads as usual. Is it possible that I have damaged a 4.0 board? Other sketches get there without a problems.
#include "Adafruit_TLC59711.h"
// How many boards do you have chained?
#define NUM_TLC59711 1
#define data 11
#define clock 13
Adafruit_TLC59711 tlc = Adafruit_TLC59711(NUM_TLC59711, clock, data);
//Adafruit_TLC59711 tlc = Adafruit_TLC59711(NUM_TLC59711);
Serial.println("TLC59711 test");
pinMode(10, OUTPUT);
tlc.begin();
tlc.write();
colorWipe(65535, 0, 0, 100); // "Red" (depending on your LED wiring)
delay(200);
colorWipe(0, 65535, 0, 100); // "Green" (depending on your LED wiring)
delay(200);
colorWipe(0, 0, 65535, 100); // "Blue" (depending on your LED wiring)
delay(200);
increaseBrightness();
// Fill the dots one after the other with a color
void colorWipe(uint16_t r, uint16_t g, uint16_t b, uint8_t wait) {
for(uint16_t i=0; i<8*NUM_TLC59711; i++) {
tlc.setLED(i, r, g, b);
tlc.write();
delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
uint32_t i, j;
for(j=0; j<65535; j+=10) { // 1 cycle of all colors on wheel
for(i=0; i < 4*NUM_TLC59711; i++) {
Wheel(i, ((i * 65535 / (4*NUM_TLC59711)) + j) & 65535);
tlc.write();
delay(wait);
// Input a value 0 to 4095 to get a color value.
// The colours are a transition r - g - b - back to r.
void Wheel(uint8_t ledn, uint16_t WheelPos) {
if(WheelPos < 21845) {
tlc.setLED(ledn, 3*WheelPos, 65535 - 3*WheelPos, 0);
} else if(WheelPos < 43690) {
WheelPos -= 21845;
tlc.setLED(ledn, 65535 - 3*WheelPos, 0, 3*WheelPos);
WheelPos -= 43690;
tlc.setLED(ledn, 0, 3*WheelPos, 65535 - 3*WheelPos);
//All RGB Channels on full colour
//Cycles trough all brightness settings from 0 up to 127
void increaseBrightness(){
tlc.setLED(i, 65535, 65535, 65535);
for(int i = 0; i < 128; i++){
tlc.simpleSetBrightness(i);
tlc.write();
