Results 1 to 10 of 10
Thread: Can't change 7 segment display
    Aug 2019
    17
    I can get the MAX7219 to initially put numbers on the 7 seg digits, but if I change any value it either turns completely off or completely on (all lights lit 8.8.8.8.8.
    I tried to make a timer that counts seconds, but it turned off, then on, then off, etc. every second.
    There must be something to do besides calling setDigit.
    Where can I look for an example?
    25,502
    Quote Originally Posted by jsureke View Post
    In Arduino, click File > Examples > LedControl > LCDemo7Segment
    Aug 2019
    17
    That doesn't even work. It starts working but it doesn't show all the changes and it doesn't loop a second time. I must have faulty components.
    Germany
    9,619
    Quite possible that it is just a problem with the connections.
    If we had a photo, we could take a look
    Aug 2019
    17
    I just learned that the chip is really finiky.
    a problem with the connections.If we had a photo, we could take a look
    This prototype isn't the best looking solder job. I'm just going to start over.
    25,502
    Which Teensy are you using? (if I were to dig out my MAX7219, which one should I test....)
    Aug 2019
    17
    I have a Teensy 3.5 and an Arduino Mega. Multiple boards, multiple sketches, alll with the same results, so it has to be the hardware.
    I do know that I didn't use the capacitors on the 5v that some people say are needed, so I'm scrapping all of this and starting over, but I'm using a socket this time, so I don't kill my chip. Not that they are all that expensive, but waiting on delivery is a pain.
    25,502
    I found that old MAX7219 test board, plugged in a Teensy 4.1, and ran the LCDemo7Segment example.
    It seems to work fine...
    25,502
    Yup, probably hardware.
    Since it was still on my workbench, I plugged in a Teensy 3.5 just to make sure.
    On this test board the MAX7219 runs from VIN (5V). There are only 5 wires between the MAX7219 and Teensy: 5V, GND, and 3 signals. The MAX7219 seems to do fine with the 3.3V signals when running from only 5V.
    15,520
    I just got one of these :: protosupplies.com/product/max7219-8-digit-7-segment-socketed-red-display-module/
    Plugged into a T_4.1 it is working with :: ...\hardware\teensy\avr\libraries\LedControl\examp les\LCDemo7Segment\LCDemo7Segment.ino
    Had to extend the running digits to cover all 7 - but it is working. Also 5V VIN and data/control lines from 3.3V T_4.1.
Tags for this Thread
